Factory Resets Listing
This is a sticky topic.
    Re: Factory Resets Listing
    I have a Vizio TV set E322AR
    My problem is that the backlight turn on only for a few sec. then turn off
    You can see Vizio logo for this time only then nothing, complet off
    No cap damages, no visual issues
    Any adea
      LG Service Menu / Mode Access
      If a "universal" remote (ie: 1056B01 / JP1) can be programmed with a 3 to 5 digit code to EMULATE the original user remote for most TVs and other devices, can it be programmed to emulate a "Master Service Remote"? I have LG 32LH20R and NONE of the online postings using the original consumer remote (menu + menu, etc.) have accessed to service menu mode.
        Hello all!
        I have a Samsung un65hu7200 curved screen smart tv. I would like to get into the service mode to try to hone in on the display issue I'm having. Of all the service mode suggestions I've seen, none of them apply to the remote that goes with this TV. There is no mute button, no number keypad, or any of the buttons mentioned in this thread that are on this remote with the exception of the power button. Any ideas?
        Thanks a bunch,
        Christine
        Christine
          I got myself into a bit of trouble. I entered service mode on a Philips 46pfl5505d and explored the options. At one point, the tv started cycling colors and gradients. It doesn't seem to respond to any remote or physical buttons. Unplugged it for half an hour. Plugged it back, turned it on, and it displayed the Philips splash screen, followed by going right back to the cycling.
          I'm hoping there's some sort of button combo to get out? It doesn't display any text.
            UPDATE: Crisis averted. Broadened my search and found http://www.supportforum.philips.com/...hrough-colours
            Down then up worked
              Service menu for TEAC and Akura using a CV306 board is: "input" on the remote, followed by 2580 ( in that order) on the remote. This is the code to get into the service menu on a Teac set which uses a slightly different version of the CV306 board but it works fine for the Akura set as well ( and probably other sets using a CV 306 board).
              This gives reset options when opened.
              Hope this is of help
              Johnboy183
                excellet info! thanks OP
                  hi does anybody know the service menu access code for tevion lcd42031d
                  its made in germany by siemmsen cant find any info or even chassis manufacturer its sold under other names like medion
                    do you know what the mainboard number is as it maybe used in other sets you maybe able to use a diffrent code.
                      heres the numbers main lable V420B1 -LO4
                      ON SMALL LABEL :TV221 071204005
                      V07129 DVBT 20080123
                      the last number is prob date of manufacture
                        the first number relates to the tcon board the mainboard is the one with the tuner ans scaart sockets on etc.
                          i understand.
                          but both of these labels are on the main board
                          as you say the one with hdmi and tuner
                          thanks vince
                            i understand.
                            thanks vince
                            The only hits on google relate too a tcon board maybe try to upload a picture of the board you will have to use imgur for now to upload the picture and maybe one of the more experieneced members may reconise the board and know a service code
                              cleaned my glasses! now the panel number is:p/no, 303c4201073
                              MHDV4201ZC01-01B This is printed on board not on white paper label
                              thanks again
                                tevion factory menu found lcd 42031d
                                to access press vol set to 15,
                                then quickly press r,g,b,y,text buttons ,factory menu comes up ,
                                as does text so exit text with text button first.
                                unless theres another page to the f menu theres no lvds panel setting ,
                                like on the samsungs ,theres normaly more than one page in the s menu,
                                for pic geometry ect, but as yet cant find it, any ideas please
                                  Originally posted by notallbad View Post
                                  It is my understanding that it is impossible to enter the service menu from the stock remote on any LG TV!
                                  But you really need to provide the model number.
                                  I just did it on my my LG 50PG25 Plazma.
                                  Hold down the MENU keys on both the remotes at the same time while the TV is on. Then enter 4 digit PIN code. Mine was 0000. There are others and they are listed on-line. Hope that helps.
                                    Not sure if in this already or not:
                                    SAMSUNG LE40M86BD
                                    Thanks to Alastair E:
                                    https://www.badcaps.net/forum/showpo...4&postcount=39
                                    set in stdby, Info, Menu, Mute, Power, select options, then Panel type/size.
                                    enter and go through list. select right one, then press enter.
                                    Simples!
                                      Helped me out. Thanks
                                        LG TV pictures upside down.
                                        https://www.badcaps.net/forum/showpo...09&postcount=7
                                        Thanks to dick_barton
                                          so will you need the lg service remote control? The remote that came with the tv wont work.
