Factory Resets Listing
This is a sticky topic.
  • nomoresonys
    • 12276
    • U.S.
    #121
    Re: Factory Resets Listing
    Code R_J posted:
    Default Re: Vizio M50-C1/M65-C1 Service menu
    Try this:
    Do the following steps rapidly:
    1. Press “MENU”;
    2. Press”1”+”9” +”9” +”9”;
    3. Press ”last”;
    • elpiko
      • May 2020
      • 25
      • Seychelles
      #122
      i have supra snart tv sled43cfhdsm1606 it get to the home screen but display a message unfortunately android.process.media has stop even if you press ok to close the message it come back so you cannot do anything at this point . is there a hot key to press while the tv is booting up to get to a reset screen like most android devices?
      • amansilla
        • May 2020
        • 6
        I believe a factory reset on Toshibas can be done pressing the on/off bottom when turning it on
        • daveb9999
          • Mar 2017
          • england
          #124
          Originally posted by tom66
          Some of mine:
          Vestel (most):
          Menu 4725 then select "RESET"
          Samsung (European):
          Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
          LG/Zenith:
          Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
          NEC:
          While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
          To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
          I vote for sticky!
          top work Tom !!! you,ve saved me many times over already !!
          • Nernder
            • Jan 2021
            • England
            #125
            HI Im curious if its possible to do a factory reset on a Toshiba LED SMART tv only using the remote the model number is 50L9450EE
            Long story short, Is I bought the tv to repair. It had a common error message of "USB over current status detected" Which required pulling an IC off the mainboard.
            Now... I wound up pulling 3 IC's of the main board. the final being the one that managed to get rid of the error and fix the tv. Everything was fine, albiet I couldnt use the USB ports...
            The problem was that when i tried to reset the Android user account it is now stuck in the log on screen. This wouldnt be a problem if I could connect a mouse and navigate..lol but i pulled the IC that allows a usb connection. The buttons on the TV also dont seem to work (Am guessing one of the other 2 ICs had something to do with that.)
            I now have a great tv that is stuck on the android log in screen. IF i could bypass Android kitkat all together and use HDMI that would be fine... Im hoping I can reset the TV and it will allow me to use the remote to navigate. As currently the only think i can do with the remote is change the volume.
            Any help would be greatly appreciated. BTW i have also looked for the mainboard, but cant find it AT ALL..grrr
            • alfatv
              • Sep 2020
              • 353
              Vizio E60-C3 - Menu 3481 to enter factory mode menu, but not very useful
              • georgeciurea17@gmail.com
                • Oct 2021
                #127
                do you know how to enter in service menu on JVC FireTV?
                I have jvc 49cf890 and I need serice menu
                Thank you
                • lotas
                  • Jan 2016
                  • 4753
                  • Russia
                  #128
                  Thank you
                  You have a 17mb170 chassis, try this.
                  • amennone
                    • Feb 2015
                    • 63
                    • italy
                    #129
                    Master TL550
                    Main TP.S506.PC821
                    Service mode
                    • IamEngineer
                      • Dec 2022
                      • Slovakia
                      #130
                      Samsung UE40D5520, eeprom was reset, new firmware through USB. Now it need some service setings, but Ihave not idea how to set in service menu . Type, local set, front vlor option. There is not this TV model in listing
                      • RinusB
                        • Sep 2017
                        • 17
                        RCA TV Service Menu
                        TV on: Menu-1 -1-4-7 (as above post)
                        To save the settings turn off TV with remote or on set.
                          LCD LED TV Service Menu Codes
                          TCL LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          10-31-2024, 03:58 AM
                        • RRice25541
                          Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                          by RRice25541
                          So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                          the color is all outa wack, like the settings have been corupted,
                          I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                          so
                          The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                          when i bring up the menu and type the pass codes to access either mode the menu disappears...
                          05-13-2022, 10:44 PM
                        • howardc64
                          M557-G0 no WiFi/Bt no WIFIVendor file?
                          by howardc64
                          Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                          • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                          • Service Menu shows many Bt/Wifi info missing
                          • Vizio app shows no WIFIVendor file
                          Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                          • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                          10-15-2024, 01:12 PM
                        • dxz
                          lenovo thinkpad e480 problem
                          by dxz
                          howdy yall,
                          back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
                          the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
                          and im wondering if my current problem is due to the flash/patch ive done:
                          im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...
                          06-16-2023, 04:10 PM
                        • Retro140
                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                          by Retro140
                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                          06-18-2023, 06:13 PM
