Re: Factory Resets Listing
RCA TV Service Menu
TV on: Menu-1 -1-4-7 (as above post)
To save the settings turn off TV with remote or on set.
This is a sticky topic.
Samsung UE40D5520, eeprom was reset, new firmware through USB. Now it need some service setings, but Ihave not idea how to set in service menu . Type, local set, front vlor option. There is not this TV model in listingAttached Filesif you find these attachements useful please consider making a small donation to the site
Master TL550
Main TP.S506.PC821
Service modeLeave a comment:
You have a 17mb170 chassis, try this.Attached Filesif you find these attachements useful please consider making a small donation to the site
do you know how to enter in service menu on JVC FireTV?
I have jvc 49cf890 and I need serice menu
Thank youLeave a comment:
Vizio E60-C3 - Menu 3481 to enter factory mode menu, but not very usefulLeave a comment:
HI Im curious if its possible to do a factory reset on a Toshiba LED SMART tv only using the remote the model number is 50L9450EE
Long story short, Is I bought the tv to repair. It had a common error message of "USB over current status detected" Which required pulling an IC off the mainboard.
Now... I wound up pulling 3 IC's of the main board. the final being the one that managed to get rid of the error and fix the tv. Everything was fine, albiet I couldnt use the USB ports...
The problem was that when i tried to reset the Android user account it is now stuck in the log on screen. This wouldnt be a problem if I could connect a mouse and navigate..lol but i pulled the IC that allows a usb connection. The buttons on the TV also dont seem to work (Am guessing one of the other 2 ICs had something to do with that.)
I now have a great tv that is stuck on the android log in screen. IF i could bypass Android kitkat all together and use HDMI that would be fine... Im hoping I can reset the TV and it will allow me to use the remote to navigate. As currently the only think i can do with the remote is change the volume.
Any help would be greatly appreciated. BTW i have also looked for the mainboard, but cant find it AT ALL..grrrLeave a comment:
top work Tom !!! you,ve saved me many times over already !!Some of mine:
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
I vote for sticky!Leave a comment:
I believe a factory reset on Toshibas can be done pressing the on/off bottom when turning it onLeave a comment:
i have supra snart tv sled43cfhdsm1606 it get to the home screen but display a message unfortunately android.process.media has stop even if you press ok to close the message it come back so you cannot do anything at this point . is there a hot key to press while the tv is booting up to get to a reset screen like most android devices?Leave a comment:
Code R_J posted:
Default Re: Vizio M50-C1/M65-C1 Service menu
Try this:
Do the following steps rapidly:
1. Press “MENU”;
2. Press”1”+”9” +”9” +”9”;
3. Press ”last”;Last edited by nomoresonys; 05-07-2020, 06:15 PM.Leave a comment:
so good........ny :Philips LED LCD
Modal :22PFL 4407
Code :MENU+2580
Sr. No. :44
Company :LG TV:
Modal :none
Code :press "Menu" buttons on remote and TV panel simultaneously for a few seconds
Sr. No. :43
Company :LG TV:
Modal :none
Code :Press and hold*buttons on remote as well as TV panel for a few seconds
Sr. No. :42
Company :Samsung TV
Modal :none
Code :First power off your TV using the remote, then press following buttons quickly on the remote: Info + Settings + Mute + Power Mute + 1 + 8 + 2 + Power Mute + 1 + 1 + 9 + Power Display/Info + Menu + Mute + Power Display/Info + P.STD + Mute + Power P.STD + Help + Sleep + Power P.STD + Menu + Sleep + Power Sleep + P.STD + Mute + Power
Sr. No. :41
Company :Samsung TV
Modal :none
Code :Mute + 1 + 1 + 9 + Enter
Sr. No. :40
Company :Sony TV
Modal :none
Code :First power off your TV using the remote, then press following buttons quickly on your TV remote: Display (or i+) + 5 + Volume Up + Power
Sr. No. :39
Company :Toshiba LCD, LED
Modal :none
Code :1. Press the {MENU} button on the remote. 2. Highlight the "Picture" icon. 3. Press the {9} {3} {0} {1} buttons on the remote control. The Service Menu will be displayed with the following Modes: "Options" - "Adjustments" - "Selections" 4. Use the {OK} button to access and navigate through these Modes 5. To change values use {VOL +} {VOL-) {P+} {P-} 6. To exit, press the {MENU} button
Sr. No. :38
Company :LG LCD
Modal :none
Code :1 POWER ONLY 2 IN.STOP 3 IN.START 4 EZ.ADJ Intercode 0000 7777 0413 8741 8743 8878
Sr. No. :37
Company :VIDEOCON TV
Modal :none
Code :MENU +6483
Sr. No. :36
Modal :none
Code :MENU +1147
Sr. No. :35
Modal :none
Code
esign mode MENU +1982 SERVICE mode menu +1947
Sr. No. :34
Modal :none
Code
esign mode MENU +0203 SERVICE mode MENU +0323
Sr. No. :33
Company :VIDEOCON LCD
Modal :none
Code :MENU+SOUNDS POP UP+8532
Sr. No. :32
Modal :none
Code :MENU+123
Sr. No. :31
Company :CHINA
Modal :none
Code :PRESS MENU BUTTON picture contrast NOW PRESS 9705
Sr. No. :30
Company :TELEFUNKEN
Modal :all model
Code :MENU+4725
Sr. No. :29
Company :Jumper board
Modal :V56U V56J.11.2
Code :INPUT+0000
Sr. No. :28
Code :INPUT+2580
Sr. No. :27
Modal :TP.HV320.PB801
Code :MENU +1147
Sr. No. :26
Company :None
Modal :Jumper board
Code :Menu+8896
Sr. No. :25
Company :China
Modal :None
Code :mute+6483
Sr. No. :24
Company :China
Modal :None
Code :source+0000.
Sr. No. :23
Company :China
Modal :None
Code :source+menu+0000.
Sr. No. :22
Company :China
Modal :None
Code :source+3138
Sr. No. :21
Company :China
Modal :None
Code :source+2580
Sr. No. :20
Company :China
Modal :None
Code :menu+audio balance +1969
Sr. No. :19
Company :China
Modal :None
Code :menu+audio balance +0532
Sr. No. :18
Company :China
Modal :None
Code :menu / c- / 8532
Sr. No. :17
Company :China
Modal :None
Code :menu/ v+ / c- / 8532
Sr. No. :16
Company :China
Modal :None
Code :menu+8893
Sr. No. :15
Company :China
Modal :None
Code :menu+8896
Sr. No. :14
Company :China
Modal :None
Code :menu+2387
Sr. No. :13
Company :china
Modal :none
Code :menu+8202
Sr. No. :12
Company :china
Modal :none
Code :menu+2383
Sr. No. :11
Company :china
Modal :none
Code :menu+1183
Sr. No. :10
Company :china
Modal :none
Code :menu+1199
Sr. No. :9
Company :china
Modal :none
Code :menu+1167
Sr. No. :8
Company :china
Modal :none
Code :menu+1187
Sr. No. :7
Company :china
Modal :none
Code :menu+0000
Sr. No. :6
Company :china
Modal :none
Code :menu+1999
Sr. No. :5
Company :china
Modal :none
Code :menu+123
Sr. No. :4
Company :china
Modal :none
Code :menu+7343
Sr. No. :3
Company :china
Modal :none
Code :menu+4725
Sr. No. :2
Company :china
Modal :none
Code :menu+1147
Sr. No. :1
Company :SHARP LCD LED TV
Modal :None
Code :unplug the power cable. * Then while pressing the {INPUT} & {VOL -} buttons on the set , plug the power cable back into the outlet. * When it powers up you will see a little "k" appear in brackets. * Then on the TV,Leave a comment:
LED TV SERVICE MENU WITH BOARD NAME:-
1. VS.TP53U71.2 = Input 208
2. VS.TP53U61.2 = Input 208ed Tv
3. VS.TP53L62.2 = Menu1147
4. T.VST59.031 = Menu 1147
5. T.R83.031 = MENU 1147
6. TP.HV320/PB813 = MENU 1147
7. TP.HV320/PB801 = MENU 1147
8. TR.85.03 = MENU 1147
9. T.VST59.031.A81A8 = MENU 1147
10. T.VST59.031 = MENU 1147
11. T56J.11.2 = MENU 1147, NPUT 2580, Input 0000, Menu 8892, Av 208, AV308
12. T.VST29.03 = MENU 1147
13. SKR.03 = MENU 1147
14. SKR.801 = MENU 1147
15. T5964.81 = MENU 1147
16. TP.MS.338.PC821 = MENU 1147
17. LAD.MV59S.G = MENU 7710
18. T.VST29.61.C = MENU 1147
19. 5800-A8M260-0020 Input 3195
20. 350016386 = MENU 2008
21. CVMV26L-A-20 = Input 2580
22. CV182L-B = Input 2580
23. SP208ESA HK-7050A-V208 =Menu 7050
24. 35017414 rev-01 = Menu 2008
25. TVST 59.A5 = MENU 1147
26. CV181L-Y Input 2580
27. T.VST59.62 = MENU 1147
28. JUG7.820.531-3 = Input 3133
29. 35016445 REV-01 Menu 2008
30 T.VST59S.73 = MENU 1147
31. TP.VST59.P83 = MENU 1147
32. T.MT 8223.33 = MENU 1147
33. TMS.18VG.81B = MENU 1147
34. T.MS.18VG.71A = ENU 1147
35. 40.TBI.TO7-MABE HG = Menu / Contrast 1950 or 9735
36. TP.MS1306.PB772 = Menu / Contrast 1950 or 9735
37. CV309H-V = Input 2580
38. TP.VST59.PB819 Menu 2008
39. CV56BH.242 Menu 2580
40. TP.MS.608.P82 Source/Input 1147
CHANGHONG SERVICE MENU CODE:-
1. Input 3138
2. Input 1125
3. Input 42580
4. Input 3138
5. Menu 1125
6. Menu 1149
7. Menu 2580
8. Menu 0816
ECOSTAR SERVICE MENU CODE:-
1. Menu 2008
2. Menu 2508
3. Menu 8002
4. Menu 8202
ORIENT SERVICE MENU CODE:-
1. Input 2580, 2588
2. Source 2588, 2580
HAIER SERVICE MENU CODE:-
1. Menu 1147
2. Menu 8202
3. 8823
4. Menu 4578
5. + High Light Audio+8893
6. Menu/Exit +1999+OK
TCL SERVICE MENU CODE:-
1. Menu + Contrast + 9735 or 1950
SUM SUNG SERVICE MENU CODE:-
1. On Standby Press Mute + 182 + Power
2. Turn Off, Info, Menu, Mute, Power
LG SERVICE MENU:-
1. Press and hold the menu button until 4 Digit password Display open
2. 8741
3. 0413
4. 0000
5. 8878
6. 7777
7. 8743
VIDEO CON SERVICE MENU:-
1. Menu 123
2. Menu 0323
3. Menu 1147
4. Menu 1947
5. Menu 6483
6. Menu + Sound + 8532
ONIDA SERVICE MENU:-
1. Source 2580
2. Menu + Vol+ + 8532
3. Menu, Pic, Cont, 9735
4. Menu, Pic, Cont, 1950
INTEX SERVICE MENU:-
1. LED 1601 = MENU 13
2. LED 1602 = MENU 8896
3. LED 1602N = MENU 8896
4. LED 1600 = INPUT 2580
5. LED 1611-VT13 = Source + 6964
6. LES/9HD08-B013 = Input + 2580
7. LED TV2110 = Menu+8896
8. Led 2200 FHD= Menu + 1147
9. Led 2202 FHD= Menu + 1147
10. Led 2410 FHD= Menu + 8202
11. Led 2800 FHD= Menu + 1147
CHINA UNIVERSAL LED TV BOARD SERVICE MENU:-
1. Menu+208
2. Menu+0101
3. Menu+710
4. Menu+1234
5. Menu+4711
6. Menu+4725
7. Menu+5880
8. Menu+6181
9. Menu+7050
10. Menu+7168
11. Menu+7343
12. Menu+7710
13. Menu+8093
14. Menu+8500
15. Menu+8202
16. Menu+8593
17. Menu+8896
18. Menu+8893
19. Menu+9301
20. Menu+9380
21. Menu+9385
22. Menu+9527
23. Menu+9735
24. Menu+9883
25. Input+1147
26. Input+2580
27. Input+0000
28. Input+208
29. Input+308
30. Source 0000
31. Source 2283
32. Source 2285
33. Source 2580
34. Source 2585
35. Source 2587
36. Source 3137
37. Source 3138
38. Source 3195
39. Source 6483
40. Source 7343
41. Source 6483
42. Menu+0000
43. Menu+1147
44. Menu+1150
45. Menu+1167
46. Menu+1185
47. Menu+1187
48. Menu+1189
49. Menu+1199
50. Menu+1150
51. Menu+1173
52. Menu+1999
53. Menu+2008
54. Menu+2383
55. Menu+2387
56. Menu+2508
57. Menu+2580
58. Menu+2588
59. Menu+2611
60. Menu+2880
61. Menu+2888
LCD/LED TV Service Menu Code with Board Name:
CV338H- A32: Menu 1147
CV338H- A42: Menu 1147
CV338H- A50: Menu 2580
CV628H-T42: Menu 1147
CV628H-B42: Menu 1147
CV950H-A42: Source 2580
MSD338ST V5.0: Source 2580
TP.HV310.PB801: Menu 1147
TP.HV320.PB801: Menu 1147
TP.HV510.PC821: Source 2580
TP.HV530.PC821: Source 2580
TP.MS338.PB801: Menu 1147
TP.MS338.PB802: Menu 1147
TP.MS338.PC821: Menu 1147
TP.MS338.PB822: Menu 1147
TP.MS338.P818: Menu 1147
TP.MS338.PB818: Menu 1147
TP.MS358.PB801: Menu 1147
TP.MS608.PB831: Menu 1147
Tp.MS608.P83: Menu 1147
Tp.MS608.P82: Input/Source 1147
TP.MS628.PC821: Menu 1147, Menu 2580
TP.MS628.PB803: Menu 1147, Menu 2580
TP.MS628.PB831: Menu 1147
TP.MS628 PD65: Menu 1147, Menu 2580
TP.MT5505.PC801: Menu 1147
TP.MT5507.PC821: Menu 1147
TP.MT5507.PB801: Menu 1147
TP.RT2984T.PC821: Menu 1147, Menu 2580
TP.RT2982.PC821: Menu 1147, Menu 2580
TP.RT2982.PB801:
TP.R69 PD64:
T.MS608.61: Source 2580
T.MS608.81: Source 2580
VS.SP33811.2: Input/Source 208
ZP.VST6A338.PB818: Source 2580
T.R83.031: Menu 1147
T.R85.031: Menu 1147
TR.85.03 Menu 1147
T56J.11.2 Menu 1147
VS.Tp53U61.2: Input 208
VS.Tp53U71.2: Input 208
VS.TP56L62.2: Menu 1147
T.VST59.031: Menu 1147
TP.VST59s.PB813 Menu 1147
CV56BL-L: Input 2580
CV56BL-Q24: Input 2580
CV56BL-Y24: Input 2580
SKR.03: Menu 1147
SKR.801 Menu 1147
SKR.816: Menu 1147
SKR.819: Menu 1147
LAD.MV56U.A36 Menu 1147
LAD.MV56U.A48 Menu 1147
LAD.MV56U.A75 Menu 1147
LAD.MV56U.B48 Menu 1147
LAD.MV56U.C36 Menu 1147
LAD.MV59S.I Menu 7710
LAD.MV59S.G Menu 7710
LAD.MV59S.Q Menu 7710
LAD.MV9.R: Menu 710
LAD.MV9.P: Menu 1147
T.VST29.03 Menu 1147
T.V56.03 Menu 1147
T.VST59.031 .A81 A8 Menu 1147
T5964.81 Menu 1147
T.VST29.61 C Menu 1147
CVMV26L-A-20 Input 2580
CV182L_B Input 2580
SP208ESA HK-7050A-V2.08-E Menu 7050
T.MS18VG.72 Menu 1147
T.VST59.A5 Menu 1147
CV181 L-Y Input 2580
T.VST.29.61 C Menu 1147
T.VST59.62 Menu 1147
T.VST59S. 73 Menu 1147
TP.VST59.P83 Menu 1147
T.MT8223.3B Menu 1147
T.MS.18VG.81 B Menu 1147
T.MS18VG.71A Menu 1147
CV309H-X Source 2580
CV56BH-Q28: Input 2580
CV56BH-Q32: Input 2580
CV56BH-Q42: Input 2580
CV56XH-U32: Input 208
CV56XH-U42: Input 208
CV56XH-U50: Input 208
🌹🌹🌹🌹🌹🌹🌹🌹🌹🌹🌹🌹Leave a comment:
TCL LED TV SERVICE MODE Access to the service menu (all the adjustments on your own risk !!):
In the picture settings menu, select "Contrast" and at this point tsify dialing the following:
1950 - general service menu (Design Menu)
9735 or 6428 - subsection Factory Menu
9705 - subsection Service menu
6405 - subsection Hotel menu
6425 - another (separate) menu, nothing new, but there is quick access to the reset (reset All and reset Shop)Leave a comment:
All Service Code
Sr. No. :177
Company :
Modal :
Code :
Sr. No. :161
Company :MI
Modal :None
Code :Insert Ac Plug Relese STb from Tv Power Key Then Press & Hold Power & OK Keys In Remote Now TV Will Open With Service Mode For Software Instalation Also Fallow Same Method
Sr. No. :160
Company :MI India
Modal :NOne
Code :Press the Menu button and then the right arrow button on the your remote, and then arrow down to the Sound settings. Arrow right and enter the Advanced Audio Settings, and arrow down to the Balance section. Make sure it is set to 0. Type "1969" on your remote. Your TV will leave the menu screen, and a green "M" will appear in the upper left corner of your screen. Press the Menu button to access the service menu. The 'Factory' tab at the top will be highlighted in yellow
Sr. No. :159
Company :Panasonic
Modal :Hotel MOde On Off
Code :How to enter to Hotel Mode 1. Purpose Restrict a function for hotels. 2. Access command to the Hotel mode setup menu. In order to display the Hotel mode setup menu, please enter the following command (within 2 second). [TV] : Vol [Down] + [REMOTE] : INPUT (3 times) Self-check indication and forced to factory shipment setting Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds. Exit Disconnect the AC cord from wall outlet.
Sr. No. :158
Company :Panasonic
Modal :Self Check
Code :Self Check Mode 1. Press the �MENU� button (on the remote control) and the �VOL DOWN� button on the LCD panel. 2. Press ON/OFF button on the panel to Exit. Hotel Mode Adjustment 1. Press the �VOLUME DOWN� button on the TV panel and simultaneously press the INPUT button on the remote control 3 times to enter Hotel Mode. 2. Set Hotel mode �on/off�, then press �EXIT� to come out.
Sr. No. :157
Company :Panasonic
Modal :TH-32A300DX
Code :While pressing [VOLUME ( - )] button of the main unit, press [INFO] button of the remote control three times within 2 seconds.
Sr. No. :132
Company :Vision Quest
Modal :all
Code :Input/Source 2580
Sr. No. :131
Company :Veste/
Modal :all
Code :Menu 4725 then select "RESET
Sr. No. :130
Company :Symphony
Modal :all
Sr. No. :129
Company :Toshiba
Modal :all
Code :On Menu, select "Installation", then " System Information" press the right arrow button. ("System Information" will change to "Factory Reset" or something similar) • Adjust the volume to zero, press the mute twice from the remote and press the menu button on the TV (fourth button from the bottom and marked p and decree it shares) to exit, the menu shut the TV • Press the Menu, Highlight the Picture, Press 9301, ok
Sr. No. :128
Company :Supra
Modal :all
Code :INPUT, 3, 1,3,8,MENU-1147,INPUT-2580,MENU-1147,MENU-2008,MENU-7050,INPUT-2580,"Menu", "Red", "Green", "Yellow", "Cyan,"MENU" - dial 2008,SOURCE - 3, 1,9,5, MENU -1, 1,4,7. Exit EXIT,
Sr. No. :127
Company :Videocon
Modal :all
Code :Menu 123 • Menu 0323 • Menu 1147 • Menu 1947 • Menu 6483 • Menu+Sound+8532
Sr. No. :126
Company :LG
Modal :all
Code :• Press and Hold the Menu button until 4 digit password displayed: • 8741 • 0413 • 0000 • 8878 • 7777 • 8743
Sr. No. :125
Company :Samsung
Modal :all
Code :• On Standby Press Mute+182+Power • Turn OFF, Info, Menu, Mute, Power
Sr. No. :124
Company :TCL
Modal :all
Code :• Menu+Contrast+9735 or 1950 • With the TV on, Select Home Select Setting and OK A 5121 Select System and OK Select About and OK, System info for TV will be displayed Use the remote and press the following sequence: Up, Right, Down, Right, Up Press the Fast Forward button 3 times Press the Rewind button 2 times
Sr. No. :123
Company :Haier
Modal :all
Code :• Menu 1147 • Menu 8202 • Menu 8893 • Menu 4578 • Menu+Highlight Audio+8893 • Press "MENU/EXIT"; Press 1999; Press "OK"
Sr. No. :122
Company :Orient
Modal :none
Code :• Input 2580, 2588 • Source 2588, 2580
Sr. No. :121
Company :Orient
Modal :none
Sr. No. :120
Company :Ecostar
Modal :none
Code :• Menu 2008 • Menu 2508 • Menu 8002 •Leave a comment:
Menu 8202
Sr. No. :119
Company :Changhong Ruba
Modal :none
Code :• Source 3138 • Source 1125 • Source 42580 • Source 3130 • Menu 1125 • Menu 1147 • Menu 2580 • Menu 0816
Sr. No. :118
Company :Board Name
Modal :40-T31TOT-MAB2HG
Code :Menu. Contrast 1950 or 9735
Sr. No. :117
Company :Board Name
Modal :SP208ESA HK-7050A-V2.08-E
Code :Menu 7050
Sr. No. :116
Company :Board Name
Modal :350016386
Code :Menu 2008
Sr. No. :115
Company :Board Name
Modal :5800-A8M260-0020
Code :Source 3195
Sr. No. :114
Company :Board Name
Modal :LAD.MV59S.G
Code :Menu 7710
Sr. No. :113
Company :Board Name
Modal :T56J.11.2
Code :Menu 1147, Input 2580, Input 0000, Menu 8896, AV 208, AV 308
Sr. No. :112
Company :Board Name
Modal :TP.VST59s.PB813
Code :Menu 1147
Sr. No. :111
Company :Board Name
Modal :T.R85.031
Code :Menu 1147
Sr. No. :110
Company :Board Name
Modal :T.R83.031
Code :Menu 1147
Sr. No. :109
Company :Board Name
Modal :T.VST59.031
Code :Menu 1147
Sr. No. :108
Company :Board Name
Modal :VS.TP56L62.2
Code :Menu 1147
Sr. No. :107
Company :Board Name
Modal :VS.Tp53U61.2
Code :Input 208
Sr. No. :106
Company :Board Name
Modal :VS.Tp53U71.2
Code :Input 208
Sr. No. :105
Company :China Universal Board
Modal :Jumper Board
Code :• Source 2585 • Source 2587 • Source 3137 • Source 3138 • Source 3195 • Source 6483 • Source 7343 • Mute 6483
Sr. No. :104
Modal :Jumper Board
Code :• Input 208 • Source/Input 308 • Input 3195 • Source 0000 • Source 2283 • source 2285 • Source 2580 • Source 2583
Sr. No. :103
Modal :Jumper Board
Code :• Menu 8893 • Menu 8896 • Menu 9301 • Menu 9380 • Menu 9385 • Menu 9527 • Menu 9735 • Menu 9883 • Input 1147 • Input 2580 • Input 0000
Sr. No. :102
Modal :Jumper Board
Code :Menu 0000 • Menu 208 • Menu 0101 • Menu 710 • Menu 1234 • Menu 4711 • Menu 4725 • Menu 5880 • Menu 6181 • Menu 7050 • Menu 7168 • Menu 7343 • Menu 7710 • Menu 8093 • Menu 8500 • Menu 8202 • Menu 8593
Sr. No. :101
Modal :Jumper Board
Code :Menu 2888
Sr. No. :100
Modal :Jumper Board
Code :Menu 2880
Sr. No. :99
Modal :Jumper Board
Code :Menu 2611
Sr. No. :98
Modal :Jumper Board
Code :Menu 2588
Sr. No. :97
Modal :Jumper Board
Code :Menu 2580
Sr. No. :96
Modal :Jumper Board
Code :Menu 2508
Sr. No. :95
Modal :Jumper Board
Code :Menu 2387
Sr. No. :94
Modal :Jumper Board
Code :Menu 2383
Sr. No. :93
Modal :Jumper Board
Code :Menu 2008
Sr. No. :92
Modal :Jumper Board
Code :Menu 1999
Sr. No. :91
Modal :Jumper Board
Code :Menu 1973
Sr. No. :90
Modal :Jumper Board
Code :Menu 1950
Sr. No. :89
Modal :Jumper Board
Code :Menu 1199
Sr. No. :88
Modal :Jumper Board
Code :Menu 1197
Sr. No. :87
Modal :Jumper Board
Code :Menu 1187
Sr. No. :86
Modal :Jumper Board
Code :Menu 1185
Sr. No. :85
Modal :Jumper Board
Code :Menu 1167
Sr. No. :84
Modal :Jumper Board
Code :Menu 1150
Sr. No. :83
Modal :Jumper Board
Code :Menu 1147
Sr. No. :82
Company :NEC
Modal :none
Code :While powering ON, hold "MENU" or "INPUT" on TV,
Sr. No. :81
Company :Insignia USA
Modal :none
Code :Input 2580 (TV is on)
Sr. No. :80
Company :Hisense
Modal :none
Code :“Parental ” enter 0000 then select “Clean All ~
Sr. No. :79
Company :COBY
Modal :none
Code :menu, Hi-Lite “audio” then enter 8893 Mode/Source 2580
Sr. No. :78
Company :Samsung and Sony Service
Modal :CV628-B42 CV338-B42 and CV338-A50 Boards
Code :Source 2580 Source 2583 Source 2587 Also other china universal boards service mode Menu 1147 Menu 1183Leave a comment:
Menu 1185 Menu 1187
Sr. No. :77
Company :MI
Modal :ALL
Code :INSERT AC PLUG ...RELEASE STB. FROM TV POWER KEY THEN PRESS & HOLD POWER &OK KEYS IN REMOT ...........SOFTWEAR INSTT. SAME METHHOD
Sr. No. :76
Company :Element
Modal :none
Code :Menu 0000 > menu 1147
Sr. No. :75
Company
ynex
Modal :none
Code :Source/Input 2580 Hold Vol down on TV and hold the (#1) button on remote
Sr. No. :74
Company :Beston led
Modal :none
Code :menu1147 input 2580
Sr. No. :73
Company :ONIDA
Modal :none
Code :MENU + 2008
Sr. No. :72
Company :Singer
Modal :none
Code :press the sequence on the remote control: 1, MUTE, RECALL, MUTE. 1, MUTE, DISPLAY MUTE
Sr. No. :71
Company :samsung LCD
Modal :none
Code :INFO, MENU, MUTE, POWER ON
Sr. No. :70
Company :Haier
Modal :HTR20 20" CRT TV
Code :Press MENU buton on TV pannel andMENU buton on remote control at the same time
Sr. No. :69
Company :Haier LCD
Modal :HL40XP1
Code : Press Menu button, press the key 8893, and Press “OK”
Sr. No. :68
Company :China lcd
Modal :none
Code :Press SLEEP→PIC→DSP→MENU button on the remote (2)Press MENU => Q.VIEW => MUTE to enter (3) "PRESET"."Ch ,press 2483
Sr. No. :67
Company :Beko - LCD
Modal :none
Code : Menu- 9, 3, 0, 1
Sr. No. :66
Company :seconmo AOC TV
Modal :none
Code :mode adjust volume to zero, press mute key and press number key 9 8 7 6
Sr. No. :65
Company :Haier
Modal :none
Code :1. Press “MENU/EXIT”; 2. Press”1”+”9” +”9” +”9”; 3. Press “OK”
Sr. No. :64
Company :Vestel
Modal :none
Code :Menu 4725 then select "RESET" Vision Quest Source / Input 2580 Vizio menu under “Help” tab is Factory Default enter 0000
Sr. No. :63
Company :Toshiba
Modal :none
Code :Menu, select “Installation”, then “ System Information” press the right arrow button. (“System Information” will change to “Factory Reset” or something similar)
Sr. No. :62
Company :Symphony
Modal :none
Code :Source/input 2580
Sr. No. :61
Company :Sony
Modal :none
Code :Hold “arrow up” on Remote and push power button on TV (TV is ON)
Sr. No. :60
Company :Sharp
Modal :none
Code :Menu, 1999 Menu, 3481 Menu, 1147 While holding [ VOL– & INPUT ] buttons on TV plug in set when “K ” appears push (VOL– & CHANNEL-)
Sr. No. :59
Company :Seiki
Modal :none
Code :Menu 0000
Sr. No. :58
Company :Samsung
Modal :none
Code :Mute 182 power Samsung (European) Power off, Info - Menu - Mute - Powe
Sr. No. :57
Company :Sanyo
Modal :none
Code :Hold VOL Down on TV, press and hold #1 button on remote, VOL will jump to halfway and set shuts off. Turn back on have 1st time setup screen
Sr. No. :56
Company :Panasonic
Modal :none
Code :Hold [ VOL— ] on TV, press and hold menu button on remote
Sr. No. :55
Company :Mitsubishi
Modal :none
Code :Menu 123 or Menu 2470 (TV is on) NEC While powering ON, hold "MENU" or "INPUT" on TV
Sr. No. :54
Company
ynex
Modal :none
Sr. No. :53
Company :PANASONIC
Modal :TH-32A300DX
Code : Menu+1950
Sr. No. :52
Company :Micromax LCD/LED
Modal :none
Code :3) Service Menu - Random stuff Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 0 and 5 in series, Service Menu will appear in the left top of screen
Sr. No. :51
Modal :none
Code :2) Factory Menu - Access to color calibration & WB settings Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 3 and 5 in series, Factory Menu will appear in the left top of screen
Sr. No. :50
Modal :none
Code :1) Design Menu - Can access all other modes through this - Access to Overscan and other settings Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 1, 9, 5 and 0 in series, Design Menu will appear in the left top of screen
Sr. No. :49
Company :samsung led/lcd
Modal :none
Code :power info menu mute power
Sr. No. :48
Company :LLOYD
Modal :none
Code :menu+1147
Sr. No. :47
Company :LLOYD
Modal :none
Code :menu+sound balance+1969
Sr. No. :46
Company :Philips LED LCD
Modal :24PFL3457
Code :MENU+1950
Sr. No. :45
CompaLeave a comment:
ny :Philips LED LCD
Modal :22PFL 4407
Code :MENU+2580
Sr. No. :44
Company :LG TV:
Modal :none
Sr. No. :43
Company :LG TV:
Modal :none
Sr. No. :42
Company :Samsung TV
Modal :none
Sr. No. :41
Company :Samsung TV
Modal :none
Sr. No. :40
Company :Sony TV
Modal :none
Sr. No. :39
Modal :none
Sr. No. :38
Company :LG LCD
Modal :none
Sr. No. :37
Modal :none
Code :MENU +6483
Sr. No. :36
Modal :none
Code :MENU +1147
Sr. No. :35
Modal :none
Code
Sr. No. :34
Modal :none
Code
Sr. No. :33
Modal :none
Sr. No. :32
Modal :none
Code :MENU+123
Sr. No. :31
Company :CHINA
Modal :none
Sr. No. :30
Company :TELEFUNKEN
Modal :all model
Code :MENU+4725
Sr. No. :29
Code :INPUT+0000
Sr. No. :28
Code :INPUT+2580
Sr. No. :27
Code :MENU +1147
Sr. No. :26
Company :None
Modal :Jumper board
Code :Menu+8896
Sr. No. :25
Company :China
Modal :None
Code :mute+6483
Sr. No. :24
Company :China
Modal :None
Code :source+0000.
Sr. No. :23
Company :China
Modal :None
Sr. No. :22
Company :China
Modal :None
Code :source+3138
Sr. No. :21
Company :China
Modal :None
Code :source+2580
Sr. No. :20
Company :China
Modal :None
Sr. No. :19
Company :China
Modal :None
Sr. No. :18
Company :China
Modal :None
Sr. No. :17
Company :China
Modal :None
Sr. No. :16
Company :China
Modal :None
Code :menu+8893
Sr. No. :15
Company :China
Modal :None
Code :menu+8896
Sr. No. :14
Company :China
Modal :None
Code :menu+2387
Sr. No. :13
Company :china
Modal :none
Code :menu+8202
Sr. No. :12
Company :china
Modal :none
Code :menu+2383
Sr. No. :11
Company :china
Modal :none
Code :menu+1183
Sr. No. :10
Company :china
Modal :none
Code :menu+1199
Sr. No. :9
Company :china
Modal :none
Code :menu+1167
Sr. No. :8
Company :china
Modal :none
Code :menu+1187
Sr. No. :7
Company :china
Modal :none
Code :menu+0000
Sr. No. :6
Company :china
Modal :none
Code :menu+1999
Sr. No. :5
Company :china
Modal :none
Code :menu+123
Sr. No. :4
Company :china
Modal :none
Code :menu+7343
Sr. No. :3
Company :china
Modal :none
Code :menu+4725
Sr. No. :2
Company :china
Modal :none
Code :menu+1147
Sr. No. :1
Modal :None
i need a bios bin file for aspire 4743 series board code JE43-CP MB 10277-1M 48.4NI01Leave a comment:
ALL LCD LED TV SERVICE MENU CODES
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RRice25541So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
the color is all outa wack, like the settings have been corupted,
I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
so
The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
when i bring up the menu and type the pass codes to access either mode the menu disappears... -
by howardc64Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
- TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
- Service Menu shows many Bt/Wifi info missing
- Vizio app shows no WIFIVendor file
- Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
by dxzhowdy yall,
back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
and im wondering if my current problem is due to the flash/patch ive done:
im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...-
Channel: BIOS Requests ONLY!
by Retro140Hello,
So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button... - Loading...
