Factory Resets Listing
This is a sticky topic.
  • Gavino_varne
    Gavino
    • Oct 2017
    • 5
    • India
    #101
    Re: Factory Resets Listing
    Can some one please help with some guidance here please. how do i reset my Skyhi television which is not going any further than android screen. Pleeeeese help
    • dukatell
      • Mar 2010
      #102
      Does anyone know how to get into maintenance menu for Sceptre E555BV-FM or X505BV-FM my picture is upside down and negative thanks in advance.
      • steves7839
        • Nov 2014
        • 200
        I have a Samsung UN65KU650D curved 4K LED TV I need to reset. It has a 5-way power joystick on the rear. The remote is mini sized and has a scroll wheel and few buttons but no number keypad. Is there a reset procedure for this set?
        • CraigR
          • Dec 2013
          • 969
          55" Vizio SmarCast E55-E1
          Locate the buttons on the side of the TV, you should find 4 of them. The bottom two would be input and volume down, these are the two we need.
          You would need to press these two together for 5-10 seconds, until a bar appears on the top of the TV. Then, you need to press the input button (the bottom button) for 5 seconds, until the screen goes black. This would cause a factory reset to the unit.
          • Hosin0
            • Apr 2018
            • 8
            • تركيا
            #105
            Originally posted by budm
            From drpj23:https://www.badcaps.net/forum/showth...483#post296483 post 5
            A little googling to the service mode
            Vizio Service Menu Method 1
            1. Turn The TV off.
            2. Press and hold the {CH +} & {CH -} buttons on the TV.
            3. Then press and release the {POWER} button on the TV.
            4. Release the {CH +} & {CH -} buttons.
            5. Now press the {MENU} button on the remote.
            6. You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
            7. Press and hold the {MENU} button for few seconds.
            8. The Service Menu will be displayed.
            Vizio Service Menu Method 2
            1. Turn The TV off.
            3. Then press and hold the {POWER} button on the TV.
            4. Keep all three buttons pressed for few seconds.
            Vizio Service Menu Method 3
            1. Press and hold the {EXIT} button on the remote for 3 seconds then release it.
            2. Then press the {1} {2} {3} buttons on the remote.
            3. To exit, press the {EXIT} button.
            GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
            VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
            VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
            Push "Menu" on remote and then push "Vol-" and "Input" on keypad
            GV46 / P50HDM / P50HDTV10A
            Press "Ch-" and "Ch+" buttons together once on keypad
            GV42 / L42 / VP42HDTV10A / VP50 / VX37
            Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
            P42
            Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
            VM60P
            Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
            The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
            GV47
            Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
            SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
            VO320EP8 / VO370M / VO420E / VP504 / VP505
            Press "Menu," and then press "2," "4," "8," "9."
            VA19 / VA22LF / VA220E / VA26
            Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
            VA320E / VA320M / VA370M / VT420M / VT470M
            Press "Menu" and then press the following combination: "1," "9," "9," "1"
            VW22 / VS370E
            Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
            swanky
            • Hosin0
              • Apr 2018
              • 8
              • تركيا
              #106
              Спасибо, брат
              • lookimback
                • Aug 2013
                • 1489
                Polaroid 50GSR3000 (probably others too) service menu:
                press menu then 1147
                ------------signature starts here------------
                • frankstv
                  • Jun 2014
                  awsome information
                  • captainKKK
                    • Sep 2018
                    • 287
                    Pardon if repeats.....
                    Service Mode / Factory Mode Entry Procedure to different brand Televisions.
                    Chinese Sets
                    Hold down (Volume down) on set and press 'Recall' on remote.
                    'Recall' is the button that activates the channel number and clock onscreen.
                    After you have made your changes, in most cases, pressing 'POWER' on the remote will clear (Exit) the factory mode.
                    On some models pressing the 'AV' button will revert things to normal operation.
                    In rare cases, the sequence first described above (Vol - on set and recall on remote) will have to be repeated at least once more.
                    If none of the above methods works, try using a universal remote - best one that has a LOT of in-built models.
                    Search through the available models looking for any that suddenly causes the set to change channels.
                    Lock this setting into the remote and press '2'.
                    Factory mode should appear.
                    COBY
                    Enter menu, Hi-Lite “audio” then enter 8893 Mode/Source 2580 select “Other setting”, select “Shipment” then Yes
                    To exit the service menu “Power Off”.
                    Dynex
                    Source/Input 2580
                    Hold Vol down on TV and hold the (#1) button on remote, Vol will jump to halfway and set shuts off.
                    Turn back on have 1st time setup screen.
                    Source/Input 2580 > menu 1999 (TV is on)
                    Element
                    Menu 0000 > menu 1147
                    Haier
                    Pull up menu, Hi-Lite “audio” then enter 8893.
                    Hisense
                    In customer menu go to “Parental” enter 0000 then select “Clean All”.
                    Power the set OFF and back ON and first time setup menu will be there.
                    For some models, same as above model except in menu it is labeled “Lock”.
                    Insignia
                    Input 2580 (TV is on)
                    LG / Zenith
                    Hold MENU on TV and MENU on remote for 5 to 10 seconds, then select reset option.
                    Mitsubishi
                    Menu 123 or Menu 2470 (TV is on)
                    NEC
                    While powering ON, hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
                    To reset to factory > on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
                    Panasonic
                    Hold [VOL--] on TV, press and hold menu button on remote.
                    Philips
                    Push Menu, select “Features” then select “Current software Info” push 062596-info on remote then push info again; red “Initialize” appears and changes color then complete.
                    Push power button to exit.
                    Polaroid
                    Hold [VOL--] and [CHANNEL--] or hold [VOL+] and [CHANNEL+] (TV is on)
                    Proscan
                    In customer menu go to setup, select parental control menu, enter 0000 then select “clear channel list”.
                    RCA
                    Menu 1147
                    Sanyo
                    Hold VOL Down on TV, press and hold #1 button on remote, VOL will jump to halfway and set shuts off.
                    Samsung
                    Mute 182 power (TV is off)
                    (On some models, Factory Reset is on this menu, on some, you must go into the “Options” submenu)
                    Most newer Samsung TVs have an easy to access reset method.
                    Press and hold the Exit Button on the Remote for at least 10 seconds until a reset screen appears.
                    Follow the on screen prompts to reset the TV.
                    Samsung (European)
                    Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
                    Seiki
                    Menu 0000
                    Sharp
                    (Note – On Sharp models, you will need to look through the menus to find the reset option)
                    Menu, 1999
                    Menu, 3481
                    Menu, 1147
                    While holding [VOL– & INPUT] buttons on TV plug in set when “K” appears push (VOL– & CHANNEL-)
                    Sony
                    Hold “arrow up” on Remote and push power button on TV (TV is ON)
                    Symphony
                    Source/input 2580
                    Toshiba
                    On Menu, select “Installation”, then “System Information” press the right arrow button.
                    (“System Information” will change to “Factory Reset” or something similar) follow on-screen instructions
                    Vestel
                    Menu 4725 then select "RESET"
                    Vision Quest
                    Source / Input 2580
                    Vizio
                    In customer menu under “Help” tab is Factory Default enter 0000
                    [If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.]
                    • egypt
                      • Mar 2019
                      • 6
                      • alxsandria
                      #110
                      Bravo led32 bed11 main-hk.t.rda8501p538
                      • Farasa
                        • Jul 2016
                        • 47
                        • South-Africa
                        #111
                        Hello all
                        I urgently need Service menu for Sinotec led tv.....thanks in advance
                        • mccloud
                          • Jul 2018
                          • 6
                          • Philippines
                          #112
                          i need a bios bin file for aspire 4743 series board code JE43-CP MB 10277-1M 48.4NI01
                          • mospeada
                            • Feb 2020
                            Sceptre X322BV-HDR
                            Menu 1147
                            • sardarshams
                              • Jan 2017
                              • 9
                              • iran
                              #114
                              ny :Philips LED LCD
                              Modal :22PFL 4407
                              Code :MENU+2580
                              Sr. No. :44
                              Company :LG TV:
                              Modal :none
                              Code :press "Menu" buttons on remote and TV panel simultaneously for a few seconds
                              Sr. No. :43
                              Company :LG TV:
                              Modal :none
                              Code :Press and hold*buttons on remote as well as TV panel for a few seconds
                              Sr. No. :42
                              Company :Samsung TV
                              Modal :none
                              Code :First power off your TV using the remote, then press following buttons quickly on the remote: Info + Settings + Mute + Power Mute + 1 + 8 + 2 + Power Mute + 1 + 1 + 9 + Power Display/Info + Menu + Mute + Power Display/Info + P.STD + Mute + Power P.STD + Help + Sleep + Power P.STD + Menu + Sleep + Power Sleep + P.STD + Mute + Power
                              Sr. No. :41
                              Company :Samsung TV
                              Modal :none
                              Code :Mute + 1 + 1 + 9 + Enter
                              Sr. No. :40
                              Company :Sony TV
                              Modal :none
                              Code :First power off your TV using the remote, then press following buttons quickly on your TV remote: Display (or i+) + 5 + Volume Up + Power
                              Sr. No. :39
                              Company :Toshiba LCD, LED
                              Modal :none
                              Code :1. Press the {MENU} button on the remote. 2. Highlight the "Picture" icon. 3. Press the {9} {3} {0} {1} buttons on the remote control. The Service Menu will be displayed with the following Modes: "Options" - "Adjustments" - "Selections" 4. Use the {OK} button to access and navigate through these Modes 5. To change values use {VOL +} {VOL-) {P+} {P-} 6. To exit, press the {MENU} button
                              Sr. No. :38
                              Company :LG LCD
                              Modal :none
                              Code :1 POWER ONLY 2 IN.STOP 3 IN.START 4 EZ.ADJ Intercode 0000 7777 0413 8741 8743 8878
                              Sr. No. :37
                              Company :VIDEOCON TV
                              Modal :none
                              Code :MENU +6483
                              Sr. No. :36
                              Modal :none
                              Code :MENU +1147
                              Sr. No. :35
                              Modal :none
                              Code esign mode MENU +1982 SERVICE mode menu +1947
                              Sr. No. :34
                              Modal :none
                              Code esign mode MENU +0203 SERVICE mode MENU +0323
                              Sr. No. :33
                              Company :VIDEOCON LCD
                              Modal :none
                              Code :MENU+SOUNDS POP UP+8532
                              Sr. No. :32
                              Modal :none
                              Code :MENU+123
                              Sr. No. :31
                              Company :CHINA
                              Modal :none
                              Code :PRESS MENU BUTTON picture contrast NOW PRESS 9705
                              Sr. No. :30
                              Company :TELEFUNKEN
                              Modal :all model
                              Code :MENU+4725
                              Sr. No. :29
                              Company :Jumper board
                              Modal :V56U V56J.11.2
                              Code :INPUT+0000
                              Sr. No. :28
                              Code :INPUT+2580
                              Sr. No. :27
                              Modal :TP.HV320.PB801
                              Code :MENU +1147
                              Sr. No. :26
                              Company :None
                              Modal :Jumper board
                              Code :Menu+8896
                              Sr. No. :25
                              Company :China
                              Modal :None
                              Code :mute+6483
                              Sr. No. :24
                              Company :China
                              Modal :None
                              Code :source+0000.
                              Sr. No. :23
                              Company :China
                              Modal :None
                              Code :source+menu+0000.
                              Sr. No. :22
                              Company :China
                              Modal :None
                              Code :source+3138
                              Sr. No. :21
                              Company :China
                              Modal :None
                              Code :source+2580
                              Sr. No. :20
                              Company :China
                              Modal :None
                              Code :menu+audio balance +1969
                              Sr. No. :19
                              Company :China
                              Modal :None
                              Code :menu+audio balance +0532
                              Sr. No. :18
                              Company :China
                              Modal :None
                              Code :menu / c- / 8532
                              Sr. No. :17
                              Company :China
                              Modal :None
                              Code :menu/ v+ / c- / 8532
                              Sr. No. :16
                              Company :China
                              Modal :None
                              Code :menu+8893
                              Sr. No. :15
                              Company :China
                              Modal :None
                              Code :menu+8896
                              Sr. No. :14
                              Company :China
                              Modal :None
                              Code :menu+2387
                              Sr. No. :13
                              Company :china
                              Modal :none
                              Code :menu+8202
                              Sr. No. :12
                              Company :china
                              Modal :none
                              Code :menu+2383
                              Sr. No. :11
                              Company :china
                              Modal :none
                              Code :menu+1183
                              Sr. No. :10
                              Company :china
                              Modal :none
                              Code :menu+1199
                              Sr. No. :9
                              Company :china
                              Modal :none
                              Code :menu+1167
                              Sr. No. :8
                              Company :china
                              Modal :none
                              Code :menu+1187
                              Sr. No. :7
                              Company :china
                              Modal :none
                              Code :menu+0000
                              Sr. No. :6
                              Company :china
                              Modal :none
                              Code :menu+1999
                              Sr. No. :5
                              Company :china
                              Modal :none
                              Code :menu+123
                              Sr. No. :4
                              Company :china
                              Modal :none
                              Code :menu+7343
                              Sr. No. :3
                              Company :china
                              Modal :none
                              Code :menu+4725
                              Sr. No. :2
                              Company :china
                              Modal :none
                              Code :menu+1147
                              Sr. No. :1
                              Company :SHARP LCD LED TV
                              Modal :None
                              Code :unplug the power cable. * Then while pressing the {INPUT} & {VOL -} buttons on the set , plug the power cable back into the outlet. * When it powers up you will see a little "k" appear in brackets. * Then on the TV,
                              Skype id :sardar.shams3
                              Telegram id : @Sardar59
                              • sardarshams
                                • Jan 2017
                                • 9
                                • iran
                                #115
                                Menu 1185 Menu 1187
                                Sr. No. :77
                                Company :MI
                                Modal :ALL
                                Code :INSERT AC PLUG ...RELEASE STB. FROM TV POWER KEY THEN PRESS & HOLD POWER &OK KEYS IN REMOT ...........SOFTWEAR INSTT. SAME METHHOD
                                Sr. No. :76
                                Company :Element
                                Modal :none
                                Code :Menu 0000 > menu 1147
                                Sr. No. :75
                                Company ynex
                                Modal :none
                                Code :Source/Input 2580 Hold Vol down on TV and hold the (#1) button on remote
                                Sr. No. :74
                                Company :Beston led
                                Modal :none
                                Code :menu1147 input 2580
                                Sr. No. :73
                                Company :ONIDA
                                Modal :none
                                Code :MENU + 2008
                                Sr. No. :72
                                Company :Singer
                                Modal :none
                                Code :press the sequence on the remote control: 1, MUTE, RECALL, MUTE. 1, MUTE, DISPLAY MUTE
                                Sr. No. :71
                                Company :samsung LCD
                                Modal :none
                                Code :INFO, MENU, MUTE, POWER ON
                                Sr. No. :70
                                Company :Haier
                                Modal :HTR20 20" CRT TV
                                Code :Press MENU buton on TV pannel andMENU buton on remote control at the same time
                                Sr. No. :69
                                Company :Haier LCD
                                Modal :HL40XP1
                                Code : Press Menu button, press the key 8893, and Press “OK”
                                Sr. No. :68
                                Company :China lcd
                                Modal :none
                                Code :Press SLEEP→PIC→DSP→MENU button on the remote (2)Press MENU => Q.VIEW => MUTE to enter (3) "PRESET"."Ch ,press 2483
                                Sr. No. :67
                                Company :Beko - LCD
                                Modal :none
                                Code : Menu- 9, 3, 0, 1
                                Sr. No. :66
                                Company :seconmo AOC TV
                                Modal :none
                                Code :mode adjust volume to zero, press mute key and press number key 9 8 7 6
                                Sr. No. :65
                                Company :Haier
                                Modal :none
                                Code :1. Press “MENU/EXIT”; 2. Press”1”+”9” +”9” +”9”; 3. Press “OK”
                                Sr. No. :64
                                Company :Vestel
                                Modal :none
                                Code :Menu 4725 then select "RESET" Vision Quest Source / Input 2580 Vizio menu under “Help” tab is Factory Default enter 0000
                                Sr. No. :63
                                Company :Toshiba
                                Modal :none
                                Code :Menu, select “Installation”, then “ System Information” press the right arrow button. (“System Information” will change to “Factory Reset” or something similar)
                                Sr. No. :62
                                Company :Symphony
                                Modal :none
                                Code :Source/input 2580
                                Sr. No. :61
                                Company :Sony
                                Modal :none
                                Code :Hold “arrow up” on Remote and push power button on TV (TV is ON)
                                Sr. No. :60
                                Company :Sharp
                                Modal :none
                                Code :Menu, 1999 Menu, 3481 Menu, 1147 While holding [ VOL– & INPUT ] buttons on TV plug in set when “K ” appears push (VOL– & CHANNEL-)
                                Sr. No. :59
                                Company :Seiki
                                Modal :none
                                Code :Menu 0000
                                Sr. No. :58
                                Company :Samsung
                                Modal :none
                                Code :Mute 182 power Samsung (European) Power off, Info - Menu - Mute - Powe
                                Sr. No. :57
                                Company :Sanyo
                                Modal :none
                                Code :Hold VOL Down on TV, press and hold #1 button on remote, VOL will jump to halfway and set shuts off. Turn back on have 1st time setup screen
                                Sr. No. :56
                                Company :Panasonic
                                Modal :none
                                Code :Hold [ VOL— ] on TV, press and hold menu button on remote
                                Sr. No. :55
                                Company :Mitsubishi
                                Modal :none
                                Code :Menu 123 or Menu 2470 (TV is on) NEC While powering ON, hold "MENU" or "INPUT" on TV
                                Sr. No. :54
                                Company ynex
                                Modal :none
                                Sr. No. :53
                                Company :PANASONIC
                                Modal :TH-32A300DX
                                Code : Menu+1950
                                Sr. No. :52
                                Company :Micromax LCD/LED
                                Modal :none
                                Code :3) Service Menu - Random stuff Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 0 and 5 in series, Service Menu will appear in the left top of screen
                                Sr. No. :51
                                Modal :none
                                Code :2) Factory Menu - Access to color calibration & WB settings Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 3 and 5 in series, Factory Menu will appear in the left top of screen
                                Sr. No. :50
                                Modal :none
                                Code :1) Design Menu - Can access all other modes through this - Access to Overscan and other settings Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 1, 9, 5 and 0 in series, Design Menu will appear in the left top of screen
                                Sr. No. :49
                                Company :samsung led/lcd
                                Modal :none
                                Code :power info menu mute power
                                Sr. No. :48
                                Company :LLOYD
                                Modal :none
                                Code :menu+1147
                                Sr. No. :47
                                Company :LLOYD
                                Modal :none
                                Code :menu+sound balance+1969
                                Sr. No. :46
                                Company :Philips LED LCD
                                Modal :24PFL3457
                                Code :MENU+1950
                                Sr. No. :45
                                Compa
                                • sardarshams
                                  • Jan 2017
                                  • 9
                                  • iran
                                  #116
                                  Menu 8202
                                  Sr. No. :119
                                  Company :Changhong Ruba
                                  Modal :none
                                  Code :• Source 3138 • Source 1125 • Source 42580 • Source 3130 • Menu 1125 • Menu 1147 • Menu 2580 • Menu 0816
                                  Sr. No. :118
                                  Company :Board Name
                                  Modal :40-T31TOT-MAB2HG
                                  Code :Menu. Contrast 1950 or 9735
                                  Sr. No. :117
                                  Company :Board Name
                                  Modal :SP208ESA HK-7050A-V2.08-E
                                  Code :Menu 7050
                                  Sr. No. :116
                                  Company :Board Name
                                  Modal :350016386
                                  Code :Menu 2008
                                  Sr. No. :115
                                  Company :Board Name
                                  Modal :5800-A8M260-0020
                                  Code :Source 3195
                                  Sr. No. :114
                                  Company :Board Name
                                  Modal :LAD.MV59S.G
                                  Code :Menu 7710
                                  Sr. No. :113
                                  Company :Board Name
                                  Modal :T56J.11.2
                                  Code :Menu 1147, Input 2580, Input 0000, Menu 8896, AV 208, AV 308
                                  Sr. No. :112
                                  Company :Board Name
                                  Modal :TP.VST59s.PB813
                                  Code :Menu 1147
                                  Sr. No. :111
                                  Company :Board Name
                                  Modal :T.R85.031
                                  Code :Menu 1147
                                  Sr. No. :110
                                  Company :Board Name
                                  Modal :T.R83.031
                                  Code :Menu 1147
                                  Sr. No. :109
                                  Company :Board Name
                                  Modal :T.VST59.031
                                  Code :Menu 1147
                                  Sr. No. :108
                                  Company :Board Name
                                  Modal :VS.TP56L62.2
                                  Code :Menu 1147
                                  Sr. No. :107
                                  Company :Board Name
                                  Modal :VS.Tp53U61.2
                                  Code :Input 208
                                  Sr. No. :106
                                  Company :Board Name
                                  Modal :VS.Tp53U71.2
                                  Code :Input 208
                                  Sr. No. :105
                                  Company :China Universal Board
                                  Modal :Jumper Board
                                  Code :• Source 2585 • Source 2587 • Source 3137 • Source 3138 • Source 3195 • Source 6483 • Source 7343 • Mute 6483
                                  Sr. No. :104
                                  Modal :Jumper Board
                                  Code :• Input 208 • Source/Input 308 • Input 3195 • Source 0000 • Source 2283 • source 2285 • Source 2580 • Source 2583
                                  Sr. No. :103
                                  Modal :Jumper Board
                                  Code :• Menu 8893 • Menu 8896 • Menu 9301 • Menu 9380 • Menu 9385 • Menu 9527 • Menu 9735 • Menu 9883 • Input 1147 • Input 2580 • Input 0000
                                  Sr. No. :102
                                  Modal :Jumper Board
                                  Code :Menu 0000 • Menu 208 • Menu 0101 • Menu 710 • Menu 1234 • Menu 4711 • Menu 4725 • Menu 5880 • Menu 6181 • Menu 7050 • Menu 7168 • Menu 7343 • Menu 7710 • Menu 8093 • Menu 8500 • Menu 8202 • Menu 8593
                                  Sr. No. :101
                                  Modal :Jumper Board
                                  Code :Menu 2888
                                  Sr. No. :100
                                  Modal :Jumper Board
                                  Code :Menu 2880
                                  Sr. No. :99
                                  Modal :Jumper Board
                                  Code :Menu 2611
                                  Sr. No. :98
                                  Modal :Jumper Board
                                  Code :Menu 2588
                                  Sr. No. :97
                                  Modal :Jumper Board
                                  Code :Menu 2580
                                  Sr. No. :96
                                  Modal :Jumper Board
                                  Code :Menu 2508
                                  Sr. No. :95
                                  Modal :Jumper Board
                                  Code :Menu 2387
                                  Sr. No. :94
                                  Modal :Jumper Board
                                  Code :Menu 2383
                                  Sr. No. :93
                                  Modal :Jumper Board
                                  Code :Menu 2008
                                  Sr. No. :92
                                  Modal :Jumper Board
                                  Code :Menu 1999
                                  Sr. No. :91
                                  Modal :Jumper Board
                                  Code :Menu 1973
                                  Sr. No. :90
                                  Modal :Jumper Board
                                  Code :Menu 1950
                                  Sr. No. :89
                                  Modal :Jumper Board
                                  Code :Menu 1199
                                  Sr. No. :88
                                  Modal :Jumper Board
                                  Code :Menu 1197
                                  Sr. No. :87
                                  Modal :Jumper Board
                                  Code :Menu 1187
                                  Sr. No. :86
                                  Modal :Jumper Board
                                  Code :Menu 1185
                                  Sr. No. :85
                                  Modal :Jumper Board
                                  Code :Menu 1167
                                  Sr. No. :84
                                  Modal :Jumper Board
                                  Code :Menu 1150
                                  Sr. No. :83
                                  Modal :Jumper Board
                                  Code :Menu 1147
                                  Sr. No. :82
                                  Company :NEC
                                  Modal :none
                                  Code :While powering ON, hold "MENU" or "INPUT" on TV,
                                  Sr. No. :81
                                  Company :Insignia USA
                                  Modal :none
                                  Code :Input 2580 (TV is on)
                                  Sr. No. :80
                                  Company :Hisense
                                  Modal :none
                                  Code :“Parental ” enter 0000 then select “Clean All ~
                                  Sr. No. :79
                                  Company :COBY
                                  Modal :none
                                  Code :menu, Hi-Lite “audio” then enter 8893 Mode/Source 2580
                                  Sr. No. :78
                                  Company :Samsung and Sony Service
                                  Modal :CV628-B42 CV338-B42 and CV338-A50 Boards
                                  Code :Source 2580 Source 2583 Source 2587 Also other china universal boards service mode Menu 1147 Menu 1183
                                  • sardarshams
                                    • Jan 2017
                                    • 9
                                    • iran
                                    #117
                                    All Service Code
                                    Sr. No. :177
                                    Company :
                                    Modal :
                                    Code :
                                    Sr. No. :161
                                    Company :MI
                                    Modal :None
                                    Code :Insert Ac Plug Relese STb from Tv Power Key Then Press & Hold Power & OK Keys In Remote Now TV Will Open With Service Mode For Software Instalation Also Fallow Same Method
                                    Sr. No. :160
                                    Company :MI India
                                    Modal :NOne
                                    Code :Press the Menu button and then the right arrow button on the your remote, and then arrow down to the Sound settings. Arrow right and enter the Advanced Audio Settings, and arrow down to the Balance section. Make sure it is set to 0. Type "1969" on your remote. Your TV will leave the menu screen, and a green "M" will appear in the upper left corner of your screen. Press the Menu button to access the service menu. The 'Factory' tab at the top will be highlighted in yellow
                                    Sr. No. :159
                                    Company :Panasonic
                                    Modal :Hotel MOde On Off
                                    Code :How to enter to Hotel Mode 1. Purpose Restrict a function for hotels. 2. Access command to the Hotel mode setup menu. In order to display the Hotel mode setup menu, please enter the following command (within 2 second). [TV] : Vol [Down] + [REMOTE] : INPUT (3 times) Self-check indication and forced to factory shipment setting Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds. Exit Disconnect the AC cord from wall outlet.
                                    Sr. No. :158
                                    Company :Panasonic
                                    Modal :Self Check
                                    Code :Self Check Mode 1. Press the �MENU� button (on the remote control) and the �VOL DOWN� button on the LCD panel. 2. Press ON/OFF button on the panel to Exit. Hotel Mode Adjustment 1. Press the �VOLUME DOWN� button on the TV panel and simultaneously press the INPUT button on the remote control 3 times to enter Hotel Mode. 2. Set Hotel mode �on/off�, then press �EXIT� to come out.
                                    Sr. No. :157
                                    Company :Panasonic
                                    Modal :TH-32A300DX
                                    Code :While pressing [VOLUME ( - )] button of the main unit, press [INFO] button of the remote control three times within 2 seconds.
                                    Sr. No. :132
                                    Company :Vision Quest
                                    Modal :all
                                    Code :Input/Source 2580
                                    Sr. No. :131
                                    Company :Veste/
                                    Modal :all
                                    Sr. No. :130
                                    Company :Symphony
                                    Modal :all
                                    Sr. No. :129
                                    Company :Toshiba
                                    Modal :all
                                    Code :On Menu, select "Installation", then " System Information" press the right arrow button. ("System Information" will change to "Factory Reset" or something similar) • Adjust the volume to zero, press the mute twice from the remote and press the menu button on the TV (fourth button from the bottom and marked p and decree it shares) to exit, the menu shut the TV • Press the Menu, Highlight the Picture, Press 9301, ok
                                    Sr. No. :128
                                    Company :Supra
                                    Modal :all
                                    Code :INPUT, 3, 1,3,8,MENU-1147,INPUT-2580,MENU-1147,MENU-2008,MENU-7050,INPUT-2580,"Menu", "Red", "Green", "Yellow", "Cyan,"MENU" - dial 2008,SOURCE - 3, 1,9,5, MENU -1, 1,4,7. Exit EXIT,
                                    Sr. No. :127
                                    Company :Videocon
                                    Modal :all
                                    Code :Menu 123 • Menu 0323 • Menu 1147 • Menu 1947 • Menu 6483 • Menu+Sound+8532
                                    Sr. No. :126
                                    Company :LG
                                    Modal :all
                                    Code :• Press and Hold the Menu button until 4 digit password displayed: • 8741 • 0413 • 0000 • 8878 • 7777 • 8743
                                    Sr. No. :125
                                    Company :Samsung
                                    Modal :all
                                    Code :• On Standby Press Mute+182+Power • Turn OFF, Info, Menu, Mute, Power
                                    Sr. No. :124
                                    Company :TCL
                                    Modal :all
                                    Code :• Menu+Contrast+9735 or 1950 • With the TV on, Select Home Select Setting and OK A 5121 Select System and OK Select About and OK, System info for TV will be displayed Use the remote and press the following sequence: Up, Right, Down, Right, Up Press the Fast Forward button 3 times Press the Rewind button 2 times
                                    Sr. No. :123
                                    Company :Haier
                                    Modal :all
                                    Code :• Menu 1147 • Menu 8202 • Menu 8893 • Menu 4578 • Menu+Highlight Audio+8893 • Press "MENU/EXIT"; Press 1999; Press "OK"
                                    Sr. No. :122
                                    Company :Orient
                                    Modal :none
                                    Code :• Input 2580, 2588 • Source 2588, 2580
                                    Sr. No. :121
                                    Company :Orient
                                    Modal :none
                                    Sr. No. :120
                                    Company :Ecostar
                                    Modal :none
                                    Code :• Menu 2008 • Menu 2508 • Menu 8002 •
                                    • sardarshams
                                      • Jan 2017
                                      • 9
                                      • iran
                                      #118
                                      TCL LED TV SERVICE MODE Access to the service menu (all the adjustments on your own risk !!):
                                      In the picture settings menu, select "Contrast" and at this point tsify dialing the following:
                                      1950 - general service menu (Design Menu)
                                      9735 or 6428 - subsection Factory Menu
                                      9705 - subsection Service menu
                                      6405 - subsection Hotel menu
                                      6425 - another (separate) menu, nothing new, but there is quick access to the reset (reset All and reset Shop)
                                      • sardarshams
                                        • Jan 2017
                                        • 9
                                        • iran
                                        #119
                                        LED TV SERVICE MENU WITH BOARD NAME:-
                                        1. VS.TP53U71.2 = Input 208
                                        2. VS.TP53U61.2 = Input 208ed Tv
                                        3. VS.TP53L62.2 = Menu1147
                                        4. T.VST59.031 = Menu 1147
                                        5. T.R83.031 = MENU 1147
                                        6. TP.HV320/PB813 = MENU 1147
                                        7. TP.HV320/PB801 = MENU 1147
                                        8. TR.85.03 = MENU 1147
                                        9. T.VST59.031.A81A8 = MENU 1147
                                        10. T.VST59.031 = MENU 1147
                                        11. T56J.11.2 = MENU 1147, NPUT 2580, Input 0000, Menu 8892, Av 208, AV308
                                        12. T.VST29.03 = MENU 1147
                                        13. SKR.03 = MENU 1147
                                        14. SKR.801 = MENU 1147
                                        15. T5964.81 = MENU 1147
                                        16. TP.MS.338.PC821 = MENU 1147
                                        17. LAD.MV59S.G = MENU 7710
                                        18. T.VST29.61.C = MENU 1147
                                        19. 5800-A8M260-0020 Input 3195
                                        20. 350016386 = MENU 2008
                                        21. CVMV26L-A-20 = Input 2580
                                        22. CV182L-B = Input 2580
                                        23. SP208ESA HK-7050A-V208 =Menu 7050
                                        24. 35017414 rev-01 = Menu 2008
                                        25. TVST 59.A5 = MENU 1147
                                        26. CV181L-Y Input 2580
                                        27. T.VST59.62 = MENU 1147
                                        28. JUG7.820.531-3 = Input 3133
                                        29. 35016445 REV-01 Menu 2008
                                        30 T.VST59S.73 = MENU 1147
                                        31. TP.VST59.P83 = MENU 1147
                                        32. T.MT 8223.33 = MENU 1147
                                        33. TMS.18VG.81B = MENU 1147
                                        34. T.MS.18VG.71A = ENU 1147
                                        35. 40.TBI.TO7-MABE HG = Menu / Contrast 1950 or 9735
                                        36. TP.MS1306.PB772 = Menu / Contrast 1950 or 9735
                                        37. CV309H-V = Input 2580
                                        38. TP.VST59.PB819 Menu 2008
                                        39. CV56BH.242 Menu 2580
                                        40. TP.MS.608.P82 Source/Input 1147
                                        CHANGHONG SERVICE MENU CODE:-
                                        1. Input 3138
                                        2. Input 1125
                                        3. Input 42580
                                        4. Input 3138
                                        5. Menu 1125
                                        6. Menu 1149
                                        7. Menu 2580
                                        8. Menu 0816
                                        ECOSTAR SERVICE MENU CODE:-
                                        1. Menu 2008
                                        2. Menu 2508
                                        3. Menu 8002
                                        4. Menu 8202
                                        ORIENT SERVICE MENU CODE:-
                                        1. Input 2580, 2588
                                        2. Source 2588, 2580
                                        HAIER SERVICE MENU CODE:-
                                        1. Menu 1147
                                        2. Menu 8202
                                        3. 8823
                                        4. Menu 4578
                                        5. + High Light Audio+8893
                                        6. Menu/Exit +1999+OK
                                        TCL SERVICE MENU CODE:-
                                        1. Menu + Contrast + 9735 or 1950
                                        SUM SUNG SERVICE MENU CODE:-
                                        1. On Standby Press Mute + 182 + Power
                                        2. Turn Off, Info, Menu, Mute, Power
                                        LG SERVICE MENU:-
                                        1. Press and hold the menu button until 4 Digit password Display open
                                        2. 8741
                                        3. 0413
                                        4. 0000
                                        5. 8878
                                        6. 7777
                                        7. 8743
                                        VIDEO CON SERVICE MENU:-
                                        1. Menu 123
                                        2. Menu 0323
                                        3. Menu 1147
                                        4. Menu 1947
                                        5. Menu 6483
                                        6. Menu + Sound + 8532
                                        ONIDA SERVICE MENU:-
                                        1. Source 2580
                                        2. Menu + Vol+ + 8532
                                        3. Menu, Pic, Cont, 9735
                                        4. Menu, Pic, Cont, 1950
                                        INTEX SERVICE MENU:-
                                        1. LED 1601 = MENU 13
                                        2. LED 1602 = MENU 8896
                                        3. LED 1602N = MENU 8896
                                        4. LED 1600 = INPUT 2580
                                        5. LED 1611-VT13 = Source + 6964
                                        6. LES/9HD08-B013 = Input + 2580
                                        7. LED TV2110 = Menu+8896
                                        8. Led 2200 FHD= Menu + 1147
                                        9. Led 2202 FHD= Menu + 1147
                                        10. Led 2410 FHD= Menu + 8202
                                        11. Led 2800 FHD= Menu + 1147
                                        CHINA UNIVERSAL LED TV BOARD SERVICE MENU:-
                                        1. Menu+208
                                        2. Menu+0101
                                        3. Menu+710
                                        4. Menu+1234
                                        5. Menu+4711
                                        6. Menu+4725
                                        7. Menu+5880
                                        8. Menu+6181
                                        9. Menu+7050
                                        10. Menu+7168
                                        11. Menu+7343
                                        12. Menu+7710
                                        13. Menu+8093
                                        14. Menu+8500
                                        15. Menu+8202
                                        16. Menu+8593
                                        17. Menu+8896
                                        18. Menu+8893
                                        19. Menu+9301
                                        20. Menu+9380
                                        21. Menu+9385
                                        22. Menu+9527
                                        23. Menu+9735
                                        24. Menu+9883
                                        25. Input+1147
                                        26. Input+2580
                                        27. Input+0000
                                        28. Input+208
                                        29. Input+308
                                        30. Source 0000
                                        31. Source 2283
                                        32. Source 2285
                                        33. Source 2580
                                        34. Source 2585
                                        35. Source 2587
                                        36. Source 3137
                                        37. Source 3138
                                        38. Source 3195
                                        39. Source 6483
                                        40. Source 7343
                                        41. Source 6483
                                        42. Menu+0000
                                        43. Menu+1147
                                        44. Menu+1150
                                        45. Menu+1167
                                        46. Menu+1185
                                        47. Menu+1187
                                        48. Menu+1189
                                        49. Menu+1199
                                        50. Menu+1150
                                        51. Menu+1173
                                        52. Menu+1999
                                        53. Menu+2008
                                        54. Menu+2383
                                        55. Menu+2387
                                        56. Menu+2508
                                        57. Menu+2580
                                        58. Menu+2588
                                        59. Menu+2611
                                        60. Menu+2880
                                        61. Menu+2888
                                        LCD/LED TV Service Menu Code with Board Name:
                                        CV338H- A32: Menu 1147
                                        CV338H- A42: Menu 1147
                                        CV338H- A50: Menu 2580
                                        CV628H-T42: Menu 1147
                                        CV628H-B42: Menu 1147
                                        CV950H-A42: Source 2580
                                        MSD338ST V5.0: Source 2580
                                        TP.HV310.PB801: Menu 1147
                                        TP.HV320.PB801: Menu 1147
                                        TP.HV510.PC821: Source 2580
                                        TP.HV530.PC821: Source 2580
                                        TP.MS338.PB801: Menu 1147
                                        TP.MS338.PB802: Menu 1147
                                        TP.MS338.PC821: Menu 1147
                                        TP.MS338.PB822: Menu 1147
                                        TP.MS338.P818: Menu 1147
                                        TP.MS338.PB818: Menu 1147
                                        TP.MS358.PB801: Menu 1147
                                        TP.MS608.PB831: Menu 1147
                                        Tp.MS608.P83: Menu 1147
                                        Tp.MS608.P82: Input/Source 1147
                                        TP.MS628.PC821: Menu 1147, Menu 2580
                                        TP.MS628.PB803: Menu 1147, Menu 2580
                                        TP.MS628.PB831: Menu 1147
                                        TP.MS628 PD65: Menu 1147, Menu 2580
                                        TP.MT5505.PC801: Menu 1147
                                        TP.MT5507.PC821: Menu 1147
                                        TP.MT5507.PB801: Menu 1147
                                        TP.RT2984T.PC821: Menu 1147, Menu 2580
                                        TP.RT2982.PC821: Menu 1147, Menu 2580
                                        TP.RT2982.PB801:
                                        TP.R69 PD64:
                                        T.MS608.61: Source 2580
                                        T.MS608.81: Source 2580
                                        VS.SP33811.2: Input/Source 208
                                        ZP.VST6A338.PB818: Source 2580
                                        T.R83.031: Menu 1147
                                        T.R85.031: Menu 1147
                                        TR.85.03 Menu 1147
                                        T56J.11.2 Menu 1147
                                        VS.Tp53U61.2: Input 208
                                        VS.Tp53U71.2: Input 208
                                        VS.TP56L62.2: Menu 1147
                                        T.VST59.031: Menu 1147
                                        TP.VST59s.PB813 Menu 1147
                                        CV56BL-L: Input 2580
                                        CV56BL-Q24: Input 2580
                                        CV56BL-Y24: Input 2580
                                        SKR.03: Menu 1147
                                        SKR.801 Menu 1147
                                        SKR.816: Menu 1147
                                        SKR.819: Menu 1147
                                        LAD.MV56U.A36 Menu 1147
                                        LAD.MV56U.A48 Menu 1147
                                        LAD.MV56U.A75 Menu 1147
                                        LAD.MV56U.B48 Menu 1147
                                        LAD.MV56U.C36 Menu 1147
                                        LAD.MV59S.I Menu 7710
                                        LAD.MV59S.G Menu 7710
                                        LAD.MV59S.Q Menu 7710
                                        LAD.MV9.R: Menu 710
                                        LAD.MV9.P: Menu 1147
                                        T.VST29.03 Menu 1147
                                        T.V56.03 Menu 1147
                                        T.VST59.031 .A81 A8 Menu 1147
                                        T5964.81 Menu 1147
                                        T.VST29.61 C Menu 1147
                                        CVMV26L-A-20 Input 2580
                                        CV182L_B Input 2580
                                        SP208ESA HK-7050A-V2.08-E Menu 7050
                                        T.MS18VG.72 Menu 1147
                                        T.VST59.A5 Menu 1147
                                        CV181 L-Y Input 2580
                                        T.VST.29.61 C Menu 1147
                                        T.VST59.62 Menu 1147
                                        T.VST59S. 73 Menu 1147
                                        TP.VST59.P83 Menu 1147
                                        T.MT8223.3B Menu 1147
                                        T.MS.18VG.81 B Menu 1147
                                        T.MS18VG.71A Menu 1147
                                        CV309H-X Source 2580
                                        CV56BH-Q28: Input 2580
                                        CV56BH-Q32: Input 2580
                                        CV56BH-Q42: Input 2580
                                        CV56XH-U32: Input 208
                                        CV56XH-U42: Input 208
                                        CV56XH-U50: Input 208
                                        • skyx
                                          • Jan 2017
                                          • 17
                                          • iraq
                                          #120
                                          Originally posted by sardarshams
                                          ny :Philips LED LCD
                                          Modal :22PFL 4407
                                          Code :MENU+2580
                                          Sr. No. :44
                                          Company :LG TV:
                                          Modal :none
                                          Sr. No. :43
                                          Company :LG TV:
                                          Modal :none
                                          Sr. No. :42
                                          Company :Samsung TV
                                          Modal :none
                                          Sr. No. :41
                                          Company :Samsung TV
                                          Modal :none
                                          Sr. No. :40
                                          Company :Sony TV
                                          Modal :none
                                          Sr. No. :39
                                          Modal :none
                                          Sr. No. :38
                                          Company :LG LCD
                                          Modal :none
                                          Sr. No. :37
                                          Modal :none
                                          Code :MENU +6483
                                          Sr. No. :36
                                          Modal :none
                                          Code :MENU +1147
                                          Sr. No. :35
                                          Modal :none
                                          Sr. No. :34
                                          Modal :none
                                          Sr. No. :33
                                          Modal :none
                                          Sr. No. :32
                                          Modal :none
                                          Code :MENU+123
                                          Sr. No. :31
                                          Company :CHINA
                                          Modal :none
                                          Sr. No. :30
                                          Company :TELEFUNKEN
                                          Modal :all model
                                          Code :MENU+4725
                                          Sr. No. :29
                                          Code :INPUT+0000
                                          Sr. No. :28
                                          Code :INPUT+2580
                                          Sr. No. :27
                                          Code :MENU +1147
                                          Sr. No. :26
                                          Company :None
                                          Modal :Jumper board
                                          Code :Menu+8896
                                          Sr. No. :25
                                          Company :China
                                          Modal :None
                                          Code :mute+6483
                                          Sr. No. :24
                                          Company :China
                                          Modal :None
                                          Code :source+0000.
                                          Sr. No. :23
                                          Company :China
                                          Modal :None
                                          Sr. No. :22
                                          Company :China
                                          Modal :None
                                          Code :source+3138
                                          Sr. No. :21
                                          Company :China
                                          Modal :None
                                          Code :source+2580
                                          Sr. No. :20
                                          Company :China
                                          Modal :None
                                          Sr. No. :19
                                          Company :China
                                          Modal :None
                                          Sr. No. :18
                                          Company :China
                                          Modal :None
                                          Sr. No. :17
                                          Company :China
                                          Modal :None
                                          Sr. No. :16
                                          Company :China
                                          Modal :None
                                          Code :menu+8893
                                          Sr. No. :15
                                          Company :China
                                          Modal :None
                                          Code :menu+8896
                                          Sr. No. :14
                                          Company :China
                                          Modal :None
                                          Code :menu+2387
                                          Sr. No. :13
                                          Company :china
                                          Modal :none
                                          Code :menu+8202
                                          Sr. No. :12
                                          Company :china
                                          Modal :none
                                          Code :menu+2383
                                          Sr. No. :11
                                          Company :china
                                          Modal :none
                                          Code :menu+1183
                                          Sr. No. :10
                                          Company :china
                                          Modal :none
                                          Code :menu+1199
                                          Sr. No. :9
                                          Company :china
                                          Modal :none
                                          Code :menu+1167
                                          Sr. No. :8
                                          Company :china
                                          Modal :none
                                          Code :menu+1187
                                          Sr. No. :7
                                          Company :china
                                          Modal :none
                                          Code :menu+0000
                                          Sr. No. :6
                                          Company :china
                                          Modal :none
                                          Code :menu+1999
                                          Sr. No. :5
                                          Company :china
                                          Modal :none
                                          Code :menu+123
                                          Sr. No. :4
                                          Company :china
                                          Modal :none
                                          Code :menu+7343
                                          Sr. No. :3
                                          Company :china
                                          Modal :none
                                          Code :menu+4725
                                          Sr. No. :2
                                          Company :china
                                          Modal :none
                                          Code :menu+1147
                                          Sr. No. :1
                                          Modal :None
                                          so good........
                                            LCD LED TV Service Menu Codes
                                            TCL LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            10-31-2024, 03:58 AM
                                          • RRice25541
                                            Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                            by RRice25541
                                            So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                            the color is all outa wack, like the settings have been corupted,
                                            I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                            so
                                            The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                            when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                            05-13-2022, 10:44 PM
                                          • howardc64
                                            M557-G0 no WiFi/Bt no WIFIVendor file?
                                            by howardc64
                                            Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                                            • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                                            • Service Menu shows many Bt/Wifi info missing
                                            • Vizio app shows no WIFIVendor file
                                            Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                                            • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                                            10-15-2024, 01:12 PM
                                          • dxz
                                            lenovo thinkpad e480 problem
                                            by dxz
                                            howdy yall,
                                            back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
                                            the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
                                            and im wondering if my current problem is due to the flash/patch ive done:
                                            im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...
                                            06-16-2023, 04:10 PM
                                          • Retro140
                                            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                            by Retro140
                                            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                            06-18-2023, 06:13 PM
