M557-G0 no WiFi/Bt no WIFIVendor file?
  • howardc64
    • Jun 2017
    • 653
    Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
    • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
    • Service Menu shows many Bt/Wifi info missing
    • Vizio app shows no WIFIVendor file
    Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
    • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory reset, system update (with enet) reboot tv, power off/on, dis/reconnect power, DNS off/on (only when enet plugged in).
    • After factory reset and initial setup, network setup first shows alert triangle, then performing wifi scan finds nothing
    • Internet shows many Vizio users complain of no wifi or frequent disconnects
    • Couldn't firmware update via USB. 8GB drive formatted FAT32 (PC/mac has no FAT only), 2 files from Vizio support website, followed their directions, could only get Music, Picture, Video menu when inserting into main board
    Anyone encounter this type of issue before?
    Click image for larger version  Name:	IMG_3322.jpg Views:	0 Size:	4.11 MB ID:	3484487 Click image for larger version  Name:	IMG_3314.jpg Views:	0 Size:	3.18 MB ID:	3484488 Click image for larger version  Name:	IMG_3325.jpg Views:	0 Size:	2.42 MB ID:	3484486 Click image for larger version  Name:	IMG_3324.png Views:	0 Size:	89.8 KB ID:	3484485
  • Diah
    • Feb 2013
    • 6550
    1- you need to check the areal cable not connect to module chassis... and if the position are correct... for me make no sense when they are crossing each other
    2- with Flux clean the soldering and do it again..
    after that do hard reset from service menu after you check if wifi enable and the mac listed as it print on the module
    • howardc64
      • Jun 2017
      • 653
      • Cable all isolated from chassis. Antenna is taped on and insulated. Also made sure cable plugs are not touching wifi/bt model EMI shield
      • Crossing over each other at wifi+bt module seems to be from the factory with taped down cable and plastic cover mounts suggesting wasn't opened and moved.
      • Fluxed and resoldered the module
      • Hot air generally heating the module, communication line SMDs and power source circuit
      Unfortunately no difference. I did notice a few things
      • Alternating factory reset shows WiFiVendor = QCA (alternate times = No Vendor) which probably = Qualcomm Atheros as they have wifi+bt chips part number starting with QCA. Maybe QCA chip is inside the module. (see attached pic)
      • There are 3 places to find enet MAC (System Menu, Service Menu, TV linked Vizio App) and 4 for wifi MAC (System Menu, Service Menu, TV linked Vizio App, Module sticker)
      • enet MAC same in all 3 locations
      • Wifi MAC is differnet in all 4 locations
      • enet + Wifi MAC is same in System Menu
      Maybe wifi+bt module is dead. Its location just above the SOC heatsink. TV can't be powered off in ECO mode (will just power back on) so SOC maybe running hotter all the time (80 to close to 100C when SOC is streaming) Vizio smart TVs have been running hot since 2014-15 with a bunch of SOC BGA failures.
      ebay used main ~$20 shipped within US.
      • Diah
        • Feb 2013
        • 6550
        when i face such part problem related to function, i go straight to read the device specification to be sure if this function enabled
        at yours no BT.
        over all streaming devices / TV / TV box when they have RJ45 LAN & WiFI WLAN the both MAC of them will be used only to register modules. the real MAC communicated between the device and outside will be ONE. same MAC address what ever we use LAN or WLAN., this MAC written by Key beside other licenses Keys.
        SoC reach 100° describe to me the WIFI Module have short / defect. as its connected direct to SoC
        so cheap MB i would get it and install it.
        • howardc64
          • Jun 2017
          • 653
          at yours no BT.
          yes, I also guessed single MAC to outside since TV user manual said WiFi doesn't work if RJ45 is connected.
          I forgot to share this TV has USB Debugging feature in service menu ( MENU + 4 + 2 + 1 + 0 ) If turned on, it will produce a system OS log file on the plugged in FAT32 USB. My log ( attached ) shows not finding WiFi and Bt HW as expected ( driver load fails )
          Will report back after replacing main. Maybe I'll also try to reflow the SOC on this main to see any effect.
          • howardc64
            • Jun 2017
            • 653
            UPDATE
            Replacement main came in. Installed and wifi works (this TV has no BT) and Power off Eco Mode works as well.
            Hot air heated the wifi module ( 2-3x ) on the old main with no WIFI HW detected and Power off Eco Mode not working (TV just restart after turning off). WIFI HW is now recognized (see pic) but can't find any SSID. Power off Eco Mode now works. I guess Power off Eco Mode not working was due to the missing WIFI HW somehow and got fixed once WIFI HW showed up. WIFI not finding SSD probably just shows failed WIFI module.
            Anyway, this TV is fixed with an extra main that don't do WIFI.
            • howardc64
              • Jun 2017
              • 653
              UPDATE 2
              Replacement main has 2 problems
              • WIFI HW would be lost on ECO MODE power off and on. Need to unplug/plug power to recovery
              • All streaming/smart apps crash and reboot randomly
              Back to using original board fixed enough to work perfect everywhere except no WIFI.
              These mains must suffer high thermal failure and WIFI too since its soldered onto main and few centimeters above SOC heatsink diagonally with SOC running ~90C when TV on.
                LCD LED TV Service Menu Codes
                ALL LCD LED TV SERVICE MENU CODES
                Service Menu Code with Board Name
                China Universal Board / Jumper Board Service Menu Code
                Changhong Ruba Service Menu Code
                Ecostar LED TV Service Menu Code
                Orient LED TV Service Menu Code
                Haier LED TV Service Menu Code
                TCL LED TV Service Menu Code
                Samsung LED TV Service Menu Code
                LG LED TV Service Menu Code
                Videocon LED TV Service Menu Code
                Supra LED TV Service Menu Code
                Toshiba LED TV Service Menu Code
                Symphony LED TV Service Menu Code
                Veste/ LED TV Service Menu Code...
                10-31-2024, 03:58 AM
              • ruletero
                DA0P5DMB8C0 wifi card shows as disabled
                by ruletero
                Motherboard: DA0P5DMB8C0
                Fail: wifi card does not activate
                Model: HP 15-dy1002la
                wifi card model: AW-NB274NF
                Hello everybody
                I have this DA0P5DMB8C0 motherboard, the problem was water damage and I found the 3alw chip failed.
                I changed it and the laptop turns on perfectly but the original wifi card does not work, in fact it gets very hot
                I have switched with three different wifi cards (realtek and broadcom) and these are recognized in Device Manager, but they do not show available wifi networks, they only show...
                07-22-2021, 01:02 PM
              • ugamazing
                820-00850 & 820-01949, No WiFi *In Recovery*
                by ugamazing
                I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                01-25-2023, 05:39 PM
              • AlexVG
                Replacing the WiFi module on a vacuum cleaner iROBOT i7
                by AlexVG
                I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                (This board does not respond, only the LEDs light up in a circle.
                The liquid damage is catastrophic and restoration is impractical).
                (I bought this board to get the WiFi module and camera).
                The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                If...
                10-22-2024, 07:20 AM
                Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) Studio Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over...
                09-07-2024, 04:10 AM
