Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
  • Retro140
    • Jan 2023
    • united states
    So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
    To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button sequence suggested but nothing ever appears.
    If anyone has any thoughts pleas let me know
    Service manual: https://www.manualslib.com/manual/29...?page=5#manual
  • Retro140
    • Jan 2023
    • united states
    Re: Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
    Bump
    • R_J
      • Jun 2012
      • 9610
      You likely need to get the Installer Remote Control to activate access to the menu's
      User Remote Control part number
      6710V00108L
      Installer Remote Control part number
      6710V00108M
      Installer’s menu items can be
      accessed by using the optional
      installer’s remote control. Just
      press and hold MENU (about 8
      seconds) until the menu disappears, then press 9, 8, 7, 6,
      then ENTER. To remove the
      Installer’s Menu, press ENTER
      repeatedly. Any changes you
      make will be stored in nonvolatile memory.
      • Retro140
        • Jan 2023
        • united states
        6710V00108L
        6710V00108M
        Yes, I have it and it didn't work. Nothing happens when you press and hold menu
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • Ierwin
          Philips 58PUS7805 Menu working but no/weird picture from video sources
          by Ierwin
          I got a 58pus7805 that shows some weird behavior.
          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
          I managed to install the latest official firmware by holding the control button while plugging...
          03-10-2024, 12:50 PM
        • vf fa
          EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
          by vf fa
          Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
          I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
          So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
          01-31-2024, 01:40 PM
        • alltvrepairs
          Jvc Lt-65VU3000 reduce backlight from service menu
          by alltvrepairs
          I have just replaced led set of this vestel tv due to age.
          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
          Thanks again....
          09-20-2025, 05:03 AM
