LG 32LX1D will not turn on
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: LG 32LX1D will not turn on
OK, finally!, VIPER22A.
Check to see if it has DC voltage (set meter to 200V range) between Source and Drain pin, be careful not to let the probes slipped.Attached FilesLast edited by budm; 01-06-2014, 11:26 PM.Never stop learning
The IC requires 14.5Vdc to start. You can try replacing that start up cap (sooner or later that cap will have to be replaced any way, just like in post 20), it may have leakage and not allow the startup voltage to rise up to 14.5V, or bad IC.Last edited by budm; 01-06-2014, 11:33 PM.Never stop learning
Hi guys, I didn't get a new TV like Captgrail suggested in post #77, I put this aside due to my mother becoming very ill and going to hospital. Spent the last 3 weeks at the hospital and then her house where they placed her in hospice. Unfortunately she just passed away on Monday and dealing with her funeral arrangements this week. Hopefully I can get started back up on this TV soon to get it repaired. I'll post soon what I get on my new DMM.Comment
http://www.badcaps.net/forum/showthread.php?t=39740Comment
If I have it on 20 it fluctuates between 0.78-0.83. Ok I just heated up C126 with hair dryer and plugged TV back in and it powers up for about 1 minute and shuts back off. TV screen comes on. I hooked up a dvd player and I get sound but no picture.Comment
Ok so now I unplugged my dvd component cables and replaced them with just a red/white/yellow video cables and now I have picture and sound, plugged in a computer and have picture (unknown if sound yet since I need keyboard and mouse). Originally my problem was sound and no picture from HDMI cable. TV sat unused for a few months and when I went back to try to figure out what the problem was I had no power either.Comment
I think change that cap and if you want to justify paying the postage buy some more
to replace caps of the same make on that board. That one has to work hard so has failed sooner. It will give a better base to work from if other faults become apparentPlease upload pictures using attachment function when ask for help on the repair
Well, I haven't done a thing since my last post and TV still running. Have an old Mac G4 hooked up to it using it in the garage for time being. It's what I am using right now for the monitor. Afraid to turn it off for fear it won't come back on. Think I should still try my hand at soldering and replace that C126 cap.Comment
In a word Useless!
You need a Panasonic FR FM or FC or nichicon or rubycon equivalent from digikeyPlease upload pictures using attachment function when ask for help on the repair
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
04-23-2025, 10:09 PM -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... - Loading...
