Onkyo TX-SR805 noise in one channel
  • MegaZAC
    • Oct 2020
    • 49
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left channel working, then cracking sound, then the right channel turns on, and noise as well.
    There are some traces of old repairs, but it looks working in general. What to check to locate the noise source?
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • Sushi1808
    Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
    by Sushi1808
    Hi everyone!
    I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
    I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
    There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
    07-01-2023, 07:53 AM
  • dicky96
    Hitachi V19B01922 Channel Tune problem
    by dicky96
    Hi Guys
    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
    He also has an LG TV, so three screens in the bar
    I installed three Satlink ST-6503 DVB-T Modulators
    This model https://www.aliexpress.com/item/32916553905.html
    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
    02-09-2023, 09:20 AM
