Faulty Philips PSU (715g5246-p01-000-002s )
  • Mr_K
    • 111
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    Originally posted by selldoor
    Hi - what is this- may be just a link or the picture, but it looks a bit odd.
    You have excellent eyes! I suspected this one, too. It looks odd because i lifted two pins for testing. From this view, the top left one and the lower one. Problem still remains....
    • Mr_K
      • 111
      So, i made a cut in the 12V line. Pls see the picture for details
      Edit: Picture updated with another cut. Blue lines are jumpers on the top. No short below this cut
        OK, the other possibility is a failed MLCC (ceramic capacitor.) There is a small brown capacitor across the +12V and GND, right near the connector. Remove this and check if the short persists. It is only for EMI so not crucial for operation. Replacement should be with a 1uF 16V or 25V, 0603 device.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Well - not a lot to check? Make sure the solder joints are not touching at the connector
          12v and gnd are pretty close. Then chack those little smd components that go from 12vtrace to gnd trace.
          Edit
          Just beaten to it!
          • Mr_K
            • 111
            No, that didn´t do the trick
              So, let me understand this. DMM in ohms across 12V and GND. Reads dead short?
              • Mr_K
                • 111
                #27
                Reads 0,5kOhms With cuts still open
                  And across the transformer tap it shows a short?
                  I fail to see the problem here -- this is quite normal. A transformer winding is a piece of wire inductively wound around a core. Ideally, it has zero resistance.
                  • Mr_K
                    • 111
                    #29
                    I can´t mesure ohms between the transformer pins and ground. It alters very fast and i´m only using a multimeter.
                      It should be steady -- TV/PSU must be unplugged.
                      • Mr_K
                        • 111
                        #31
                        Sure!!!
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #32
                          Can you unsolder the long link - will shorten the problem zone.
                          Did you test the resistors crossing the line? and is there a cap or something
                          pinkish lines - what is the odd cherry coloured joint
                            Can I see the label on the white connector with a bunch Voltage labels next to it, I cannot read them on the picture.
                            I expect the 5V stanby to be working sinc the 12v is switched on by the main board.
                            Philips model number and chassis number? I also see MLCC right across the 12v output close to those two bleeder resistors.
                              We already ruled out the MLCC. After the diode it was my prime suspect. But I really am not sure where the short is any more.
                              • Mr_K
                                • 111
                                #35
                                The blue one? It´s unsoldered. See post #22
                                They seem to be fine. They would have much more ohms and not shorting out when failing.
                                Pls see the pic for details.....
                                • Mr_K
                                  • 111
                                  #36
                                  Which label exactly?
                                  The TV is a 42PFL4007H/12. I didn´t find the chassis number and i´ll have to wair for tomorrow to look it up....
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #37
                                    He means the values shown in the box underneath _ I tried to enlarge and improve but could not
                                    On/Off
                                    DIM
                                    +12v
                                    +12v
                                    Gnd
                                    Gnd
                                    Gnd
                                    24v
                                    24v
                                    PS-on
                                    5.2v
                                    5.2v
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #38
                                      Its nothing daft like the link on the top of the board pressed down onto the socket pin ends
                                        So it shows 500 Ohms (0.5K Ohms), that is not dead short, that sounds like the reading of those 3 resistors in parallel with the 12V output. I think we need to get the 5vstby working first.
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #40
                                          Good eyes - perhaps- but totally missed that there was no 5v.
                                          Mr K are there any voltages on the connector
                                          • lolich112
                                            GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                            by lolich112
                                            I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                            Symptoms:
                                            Initially experienced a gradient-style black screen from the top.
                                            Poor performance: ~10 FPS on the lock screen.
                                            Encountered artifacts followed by black screens.
                                            After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                            Upon using GPU-Z:
                                            Memory size shows as 0MB.
                                            Unknown bus width and bandwidth reported....
                                            10-27-2023, 06:17 AM
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • ugamazing
                                            820-02020 PPBUS_AON missing
                                            by ugamazing
                                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                            02-05-2025, 04:21 PM
                                          • jpreza
                                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                            by jpreza
                                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                            Looking at the card, it appears to be missing the following:
                                            1x 1.0uH inductor - orange square
                                            2x...
                                            11-01-2024, 10:54 PM
                                          • BYTEHAT248
                                            Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                                            by BYTEHAT248
                                            Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                                            11-14-2025, 04:48 PM
