820-02020 PPBUS_AON missing
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways), but no change.
    Went back to inspecting CD3217 area because everything else seemed fine; I replaced them "just in case" to see if there would be *any* change at all, but there wasn't. Same exact behavior.
    A bit lost here, as I've never had a missing-ppbus issue be anything other than things mentioned above, especially when it isn't shorted. The cycling of ppbus (between 1.9v and 0.9v) made me think there was a short on an auxiliary line, but I can't find anything amiss on any of the main rails. Have checked all caps for shorts to be sure.
    Any help appreciated!
  • mon2
    • 14761
    With no power, no battery, what is the exact resistance to ground on fuse F5200?
    Attach the power adapter, measure the voltage to ground of:
    I2C_SMC_PWR_1V8_SCL
    I2C_SMC_PWR_1V8_SDA
    I2C_SMC_PWR_3V3_SCL ; at the battery BMS connector
    I2C_SMC_PWR_3V3_SDA
    • ugamazing
      • Jun 2013
      • 171
      • usa
      Thanks, Mon!
      PPBUS diode is .478
      I2C_SMC_PWR_1V8_SCL: 0v
      I2C_SMC_PWR_1V8_SDA: 0v
      I2C_SMC_PWR_3V3_SCL: 0v
      I2C_SMC_PWR_3V3_SDA: 0v​
      • mon2
        • 14761
        PPBUS diode mode is ok and not shorted.
        Test the following in diode mode (with no power to the board & no battery attached):
        I2C_SMC_PWR_1V8_SCL
        I2C_SMC_PWR_1V8_SDA
        I2C_SMC_PWR_3V3_SCL
        I2C_SMC_PWR_3V3_SDA
        • ugamazing
          • Jun 2013
          • 171
          • usa
          Thanks, Mon!
          I2C_SMC_PWR_1V8_SCL .530
          I2C_SMC_PWR_1V8_SDA .520
          I2C_SMC_PWR_3V3_SCL .499
          I2C_SMC_PWR_3V3_SDA .500
          • mon2
            • 14761
            These lines are not shorted but you appear to be missing the pull-up voltages on each side of the level shifter. Can you confirm? The 1v8 and 3v3 rails are missing? They will be tied to the high side of the pull-up resistors on these SMBUS lines.
            • ugamazing
              • Jun 2013
              • 171
              • usa
              How are you concluding that specifically? The diode readings provided appear to match a working board; is it simply because the signals are missing that you've concluded this? Sorry if I'm confused in your question, lol.
              • mon2
                • 14761
                SMBUS is an open-drain specification. That is, the SMBUS device / master can pull the line low but there is no high level. Instead, when a high signal is desired, the line is made to be open or floating. For this reason, you will see a local pull-up resistor to park the floating line to the high voltage. In the level shifter, one side is to 1v8 and the other to 3v3 if all is well.
                So when the SMBUS lines are floating, the external voltages must be present else you will read 0v on these lines. The other possibility is that the bus master is pulling both lines low to 0v but do not think so.
                Measure the voltage to ground on the pull-up resistors @ RD202 / RD203 and also RD200 / RD201.
                RD200 ; should be 1V25 on pin # 1
                RD201
                RD202 ; should be 1V8 on pin # 1
                RD203
                RD207 ; should be 3v3 on pin # 1
                RD208
                • iMuhtaseb
                  820-02020 (A2338) stuck @ 5v 0.11amps
                  by iMuhtaseb
                  board came with liquid damage and prior work on SoC PMU (U8100) with short on PP3v8_AON..
                  it had corroded caps around U8100, all removed and U8100 replaced successfully.. short removed..
                  Board is still stuck 5v 0.11 amps.. I have returned all the missing caps around U8100 thinking maybe they're necessary but sadly no fix.
                  PPBUS 12.33v
                  PP3v8_AON 3.8v
                  PPV5_S2 not present, no short
                  PP3v3_S2 not present, no short
                  PP1v8_S2 not present, no short..
                  I've taken diode and short measurements around all coils for U8100 they were...
                  10-16-2024, 06:39 AM
                • Instafixx
                  Macbook A1466 820-00165 PPBUS Missing
                  by Instafixx
                  Hello, I have a Macbook A1466 80-00165 which is not turning on. It is taking 0 ohms and the PPBUS_G3H is at 0v at F7140.
                  Tried Injecting 1V but nothing gets hot.
                  Removed the F7140 fuse and the Pin#2 is still short to ground.
                  Can anyone suggest where the issue is ?
                  05-20-2023, 06:42 AM
                • jpreza
                  Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                  by jpreza
                  I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                  Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                  It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                  Looking at the card, it appears to be missing the following:
                  1x 1.0uH inductor - orange square
                  2x...
                  11-01-2024, 10:54 PM
                • BYTEHAT248
                  Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                  by BYTEHAT248
                  Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                  11-14-2025, 04:48 PM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
