Faulty Philips PSU (715g5246-p01-000-002s )
  • mr2013e
    Elc. Engineer
    • Jul 2013
    • 41
    • TURKEY
    #161
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    check R9332
    • mr2013e
      Elc. Engineer
      • Jul 2013
      • 41
      • TURKEY
      #162
      ic9101 for 12/24v power supply and ic9801 for power factor corrections(PFC)
      • Mr_K
        • 111
        #163
        Thank you mr20123e!
        R9332 is fine. It´s 2.4Ohms
        My intention with adding external 5.2V: To test the rest of the PSU....
        • mr2013e
          Elc. Engineer
          • Jul 2013
          • 41
          • TURKEY
          #164
          then swap psu.
          • Mr_K
            • 111
            #165
            Originally posted by mr2013e
            then swap psu.
            This one is realy realy hard to find. Especialy with the exact same config as mine. The model number is always the same, but there are different (more) components and false plugs on the board.
            • nagp678@gmail.com
              • Dec 2015
              • india
              #166
              12v & 24v is not working
              • angel-boy
                • 550
                #167
                have a problem with this board,
                - i dont have light on display
                - i have 24v.
                - dim - 3.3v
                - on/off - 3.3v
                i see that conector goes in display
                • angel-boy
                  • 550
                  #168
                  fix, change one led and now it`s working
                  • Kalias
                    • 17
                    • Slovakia
                    #169
                    Hi, have you succeeded in repairing of the board? I have the same issue, spent lot of time trying to diagnose the fault, but with no success.
                    • mr.greywater
                      • Jul 2019
                      • France
                      #170
                      I know this is an old thread, but I just want to comment that I'm pretty sure this board is designed to output 3.3V instead of 5.2V. Why? Because if you calculate the output voltage from the reference voltage, you arrive at 3.26V.
                      This formula comes from the datasheet of IC9304 to calculate Vout:
                      (R9337/R9338+1)*Vref=
                      (12.7KOHM/7.87KOHM+1)*1.25V=3.26V
                      Therefore the voltage is regulated to be ~3.26V
                      I think originally there was intended to be the mosfet Q9301 which switched the path between PIN1 of IC9304 to ground to a path with less resistance, thus increasing the output to 5.2V. They probably decided they don't need 5.2V at all, marked those components as NC, but left the labels of the rail as 5.2V, as they could output it depending on the version of the power supply.
                      • lolich112
                        GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                        by lolich112
                        I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                        Symptoms:
                        Initially experienced a gradient-style black screen from the top.
                        Poor performance: ~10 FPS on the lock screen.
                        Encountered artifacts followed by black screens.
                        After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                        Upon using GPU-Z:
                        Memory size shows as 0MB.
                        Unknown bus width and bandwidth reported....
                        10-27-2023, 06:17 AM
                      • tony359
                        Faulty CRT AKF12/Philips CM8500: bad flyback?
                        by tony359
                        I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                        What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                        There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                        Can it be a short somewhere...
                        08-22-2023, 04:39 PM
                      • ugamazing
                        820-02020 PPBUS_AON missing
                        by ugamazing
                        Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                        Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                        02-05-2025, 04:21 PM
                      • jpreza
                        Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                        by jpreza
                        I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                        Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                        It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                        Looking at the card, it appears to be missing the following:
                        1x 1.0uH inductor - orange square
                        2x...
                        11-01-2024, 10:54 PM
                      • Sharpa
                        Repair attempt Philips 55OLED804/12
                        by Sharpa
                        I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                        The symptoms when bought: Philips logo appears then tv turns off
                        Things tried so far:
                        1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                        2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                        Today, 08:30 AM
