Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
AMD Radeon R9 290 / R9 380 / R9 390
The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...-
Channel: Schematics and Boardviews
AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...-
10-01-2024, 01:07 PM -
AMD Radeon RX 470 / RX 580 Schematic & Board View
The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...-
by thebarberHi,
I have an RX 6600 from MSI, and it has no power. I have found no shorts, and almost all voltages are missing:- I have 5V on the back of the card (U310), but it seems to be used for video output (5V_VESA).
- All fuses seem okay.
- The thermal camera shows no hot spots.
- I have flashed the latest BIOS (using CH341A). It makes 1.8v and 0.75v come back
I am used to repairing shorted cards and replacing blown components, but here I am stuck.
For schematics and board view, I use the Rev 2.0 PDF schematic, as nothing is available for Rev 1.0. However, Rev 2.0 is...2 Photos -
AMD Radeon R7 340 / R7 430 Schematic & Board View
The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...-
10-01-2024, 12:36 PM -
- Loading...
