Faulty Philips PSU (715g5246-p01-000-002s )
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    "ook some time to get my hands on the IC to replace the old one. After replacing, my readings are:
    Here are the readings:
    On/Off 0V
    DIM 0,01V
    +12v 0V
    +12v
    Gnd
    Gnd
    Gnd
    24v 0V
    24v
    PS-on 3.3V
    5.2v 3.3V
    5.2v 3.1V"
    So now the 5V stby power supply is working after replacing the IC, but are you only 3.3V instead of 5.2V as shown in your chart above?
    Your meter is good? It still bother me that with 225VAC for your power and you only get 308V on the main filter cap, it is telling me that the cap is not charging up to the peak of the voltage.
    We also have to work on the 12v circuit next, but we must make sure your meter is OK.
    Another point also is the reading of the two pins of the 5.2V connectors, the two pin are tied together but some how you are getting 3.3 and 3.1 V reading, they should be the same.
    • Mr_K
      • 111
      #62
      Hey, thanks for coming back here!
      I´ll try to answer your questions:
      My B+1 is 318V at the main filter cap.
      Regarding Standby Voltages: I made a mistake here: There is a 13Pin connector with only 12 Pins labled. Look at the downside of the board. Below the two 5.2v Standby pins is an additional pin. I mixed them up:
      Correct readings:
      PS-on 0V
      5.2v 3,37V
      5.2v 3,37V
      "pin13" 3,36V
      The main problem left might be the 12v rail. Is it possible that somesthing in the 12v circuit is drawing power from the 5v standby?
        I do know of some Philips PSUs that change the +5.2V to +3.3V in standby mode to save power, it could be that.
        • Mr_K
          • 111
          #64
          That would be even better. Tv LED is blinking 3 times. This is related to my 12v problem. So standby power MIGHT be ok.
            Well, I need to trace out the 12v power supply section next and draw up the diagram.
              By the way, did you put all those components you have removed and cut traces back at the right locations, just to be sure.
                Correct readings:
                PS-on 0V
                5.2v 3,37V
                5.2v 3,37V
                "pin13" 3,36V
                OK, you are not getting PS_ON to turn on the 12v/24v POWER SUPPLY.
                TV unplugged, Put the DC voltmeter on the PS_ON pin, plug the TV into the outlet, take the reading, hit the power switch, take the reading, hit the power switch again and take the reading. I need to see if this PS_ON voltage change state at all.
                • Mr_K
                  • 111
                  #68
                  All components are in place and all cuts are closed.
                  I´ll check PS_ON status as soon as i get home.
                  BTW can you explain the difference between PS_ON and ON/OFF pins?
                    ON/OFF is usually for backlight, just routed through PSU (reduces wiring.)
                    • Mr_K
                      • 111
                      #70
                      Thank you.
                      I´ll not be able to test the PSU inside the TV before tomorrow.
                      When i bridge standby to ps-on nothing happens to 12v. More test will follow tomorrow.....
                        The reason I ask to check the voltage on PS_ON when TV is off and when TV is on is to find out if this Philips TV uses Active High or Active Low logic, some Philips uses >3v for OFF instead of ON.
                        • Mr_K
                          • 111
                          #72
                          PS_ON: When plugged in, its 2.9V. After ~1sec its 3.3V and shorted to standby. Pressing the Power button or CH+ doesn´t affect PS_ON.
                            "After ~1sec its 3.3V and shorted to standby" Do you mean the PS_ON was at 2.9 and it then goes up to 3.3v which at that point the TV goes into standby?
                            The PS_ON should toggle between two voltage values (high and low) when you activate/deactivate the power switch.
                            • Mr_K
                              • 111
                              #74
                              No, PS_ON is at 2.9V as soon as i plug the TV in. After ~1sec it goes up to 3.3V. I have checked with my meter that it has continuity to standby PIN when at 3.3V wich it hasn´t when tv is not plugged in. So anything must have switched and connected PS_ON to STANDBY PIN.
                              I do NOT measure any changes (no high or low) when pressing the power button.
                              My guess is: TV tries to power on as soon as plugged in.->PS_ON is switched to 3.3v->With 12v missing, tv goes into some kind of "error mode"->thats why the power button doesn´t affect PS_ON
                              • Mr_K
                                • 111
                                #75
                                Still no luck with this one. Any more help please?
                                • Mr_K
                                  • 111
                                  #76
                                  I found a faulty transistor. (Q8101; The lower one of the two on the top below the sticker......pic will follow....) Its a K2510AK
                                  First question: Can this one be responsilble for 12V not being present.
                                  Second question: Can someone please tell me a suitable replacement part. RS would be nice. Thanks!!
                                    To get an orderable part number, add "2S".
                                    2SK2510
                                    http://australia.rs-online.com/web/p...stors/5485125/
                                    ^Yeah, in Australia. Seems to be out of stock everywhere else.
                                    • Mr_K
                                      • 111
                                      #78
                                      Hmmm...discontinued product. Thats why i´m looking for substitution. And of course it´s faster ;-)
                                      Would a IRL540N fit? I´d like to double check this for safety reason!!
                                        60V, 10mOhm fet.
                                        This is 60V, 7mOhm.
                                        Should be fine.
                                        http://uk.rs-online.com/web/p/mosfet...stors/6875324/
                                        • Mr_K
                                          • 111
                                          #80
                                          Should´t it be for 100V?
                                          • lolich112
                                            GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                            by lolich112
                                            I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                            Symptoms:
                                            Initially experienced a gradient-style black screen from the top.
                                            Poor performance: ~10 FPS on the lock screen.
                                            Encountered artifacts followed by black screens.
                                            After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                            Upon using GPU-Z:
                                            Memory size shows as 0MB.
                                            Unknown bus width and bandwidth reported....
                                            10-27-2023, 06:17 AM
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • ugamazing
                                            820-02020 PPBUS_AON missing
                                            by ugamazing
                                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                            02-05-2025, 04:21 PM
                                          • jpreza
                                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                            by jpreza
                                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                            Looking at the card, it appears to be missing the following:
                                            1x 1.0uH inductor - orange square
                                            2x...
                                            11-01-2024, 10:54 PM
                                          • BYTEHAT248
                                            Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                                            by BYTEHAT248
                                            Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                                            11-14-2025, 04:48 PM
