Faulty Philips PSU (715g5246-p01-000-002s )
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    I've uploaded it under OEM.
    I think I'll put future generic schematics in this directory.
    http://www.tgohome.com/ServiceManual...&Search=Submit
    I have a feeling that the manufacturer of these parts is BriView, from a little research, a relatively unknown company in China. Maybe I can get more of the 715G schematics from that server.
      If you solder another 3K3 resistor in parallel with R9335, you should see the output voltage rise up if the opto is controlling.
        If the opto was leaky, the AZ432 should compensate, by pulling more current through, so I don't think changing the resistor will help -- AZ432 has been verified already. For the opto to fail, it would have to be really, really leaky.
        • Mr_K
          • 111
          #124
          Originally posted by budm
          The SCH shows Q9301, R9339, R9341, R9340 as NC (NOT CONNECTED/NOT USED).
          Check ZD9303, OPTO IC9303, REF DIODE IC9304 as Tom suggested.
          The more PIN4 (FB) switng toward ground (less voltage), the less output voltage you will get. Check voltage between pin2 and 3 of ref diode IC9304.
          When the output voltage tries to go up, the Opto will turn on more to keep the FB pin low.
          ZD9303 is fine
          Opto needs to be tested tomorrow (need a second multi)
          V between Pin 2 and 3 of IC9304 is 1.76V
          Will try the second resistor now
          • Mr_K
            • 111
            #125
            Still 2.94V on standby......
              Correction, second multimeter to measure current on current range (through opto transistor.)
              Basically any generic optocoupler will work so it may be quicker to find one on an old power supply board and swap it.
              • Mr_K
                • 111
                #127
                EDIT....my bad.....
                    The harder the LED is turn on (the photo transistor will turn on more cause the FB pin to go lower), it will cause output to drop, it is negative feedback from what I see in the SCH, so if you reduce the current flowing through the LED, the the transistor will turn on less due to lower current transfer function. We are basically try to change the voltage level at the FB pin of the SMPS IC.
                    • Mr_K
                      • 111
                      #130
                      New opto..... Same Problem
                        This could prove very difficult to trace down then.
                          What do you read at the FB pin and the ground pin?
                            See explanation on page 9 on FB pin, the FB pin is sunk by the Opto, if the FB is < 0.95V it will stop the Oscillator.
                            • Mr_K
                              • 111
                              #134
                              0.8V with new opto still installed.
                                That is not right at all, something is sinking that pin down, there is a zener diode connected to that pin per SCH. Lift one leg and take the resistance reading of the Zener and also resistance between FB pin and the ground pin.
                                  Perhaps the FB pin is leaky, or C9334, or ZD9303 are.
                                    Never mind, I looked back at the long thread, it is 5.2V.
                                    Disregard:
                                    I am still not sure if the board STBY is 5v or 3.3V. He did not have the STBY until I have him changed the STBY IC.
                                    • Mr_K
                                      • 111
                                      #138
                                      ZD9303 is too high to
                                      FB to gnd is ~16meg
                                        OK, this is what you can do, hookup the meter to monitor the 5.2V output and also have a small 6V lamp connected to the 5.2V Output, keep the meter hookup at all time. Apply the power to the board, then short/un-short pin 1 and pin 2 of the Opto IC 9303, you should see the voltage rise up everytime you short out the pin, if it does, then the IC is working, if not, I would replace the Opto, the IC 9304 1.25V ref diode..
                                        • Mr_K
                                          • 111
                                          #140
                                          Ok, when i short Pin 1 and 2 of opto IC9303, the voltage rises up to 5.7V and immediatly falls to 1.4V. and rises again. This repeats as long as the pins are shorted.
                                          Edit: Sorry! Forgot to put the zener bach in place. Will try again....
                                          Edit2: Ok, with the Zener back in place and the extra 3K3 removed, voltage comes up to 4.5v and drops to 1.5->4.5->1.5-> etc
                                          • lolich112
                                            GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                            by lolich112
                                            I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                            Symptoms:
                                            Initially experienced a gradient-style black screen from the top.
                                            Poor performance: ~10 FPS on the lock screen.
                                            Encountered artifacts followed by black screens.
                                            After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                            Upon using GPU-Z:
                                            Memory size shows as 0MB.
                                            Unknown bus width and bandwidth reported....
                                            10-27-2023, 06:17 AM
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • ugamazing
                                            820-02020 PPBUS_AON missing
                                            by ugamazing
                                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                            02-05-2025, 04:21 PM
                                          • jpreza
                                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                            by jpreza
                                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                            Looking at the card, it appears to be missing the following:
                                            1x 1.0uH inductor - orange square
                                            2x...
                                            11-01-2024, 10:54 PM
                                          • BYTEHAT248
                                            Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                                            by BYTEHAT248
                                            Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                                            11-14-2025, 04:48 PM
