Sanyo dp42848. No picture no sound?has anyone found the problem
    Re: Sanyo dp42848. No picture no sound?has anyone found the problem
    First using Ohm mode to check the resistance between those pins of the transformer to see if it has open windings, it should show really low ohms.
    Second, we will test the rectifiers by setting the meter in Diode testing mode. please see the notes on the picture.
    • tomstr
      Tommy
      • Jun 2010
      • 147
      • Usa
      #42
      7.75 on both circuits, not voltage oms
        "take the reading between pin 12 and 13, and 12 and 14 of that transformer T1"
        Can you verify the reading of the transformer?
        12 & 13 = xxxx Ohms
        12 & 14 = xxxxx Ohms.
        Then in Diode mode reading of the two rectifiers for the 24V?
        • tomstr
          Tommy
          • Jun 2010
          • 147
          • Usa
          #44
          I dont thik my meter has diode function?
            Can I see the picture of the meter?
            So you are reading 7.75 Ohms on the transformer? I do not expect it to be that high at all.
            • tomstr
              Tommy
              • Jun 2010
              • 147
              • Usa
              #46
              The readings are 7.75 for both
                Is the meter set to 2K Ohms as shown in the picture, if it is that means it is showing 7.75K ohms (7750 Ohms!).Set it to '200' Ohms range and take the reading again. I expect it to be less than one Ohm. What resistance do you get when you short the meter leads together?
                Your meter does have Diode mode.
                I also drew up simplified diagram, as you can see, there is not much for the 24vdc section at all.
                • tomstr
                  Tommy
                  • Jun 2010
                  • 147
                  • Usa
                  #48
                  Set meter to 200k. Readings-1.0 on all points on cathodes
                  • selldoor
                    Slow Learner
                    • 7870
                    #49
                    Budm did not say 200k ohms he said 200 ohms
                    • tomstr
                      Tommy
                      • Jun 2010
                      • 147
                      • Usa
                      #50
                      Ok i will set meter to 200 ohm and let u know
                      • tomstr
                        Tommy
                        • Jun 2010
                        • 147
                        • Usa
                        #51
                        Im going to be home half day so i can spend the afternoon on this tv YOU PEOPLE HAVE BEEN VERY NICE AND HELPED ME ALOT THANKS
                          Set to 200 to verify the resistance of the transformer windings. That resistance reading of 7.75 Ohms/K Ohms is not right at all.
                          Set to Diode mode to test the Diode that I asked to check.
                          Please go on line and learn how to test the Diodes and resistance.
                          Right now we have narrowed it down to the 24V output section, the 12v is owrking so the T1 section for the 12v and the driving circuits are functionong OK, only the 24 section is not right, especially the DC resistance reading of 7.75???? is not right at all.
                          I am getting a little frustrated right now on giving the instructions to follow with all the pictures and the diagrams that I had provided so far.
                          May he should by a new board and get it over with.
                          • tomstr
                            Tommy
                            • Jun 2010
                            • 147
                            • Usa
                            #53
                            Will do i a couple hours
                            • tomstr
                              Tommy
                              • Jun 2010
                              • 147
                              • Usa
                              #54
                              Im trying to follow all suggestions,im goingas fast as possible !!!HELP im going to narrow down in a few,someone sent me a pic of some digram but not sure how to read it?so MABEE I SHOULD JUST GET A POWER SUPPLY?let me know....
                              • tomstr
                                Tommy
                                • Jun 2010
                                • 147
                                • Usa
                                #55
                                Just found out how to test diods i will do it tonight
                                  I need that reistance reading of the transformer for sure, may be johnboy1313 can give us the reading from his TV transformer T1 reading.
                                  • tomstr
                                    Tommy
                                    • Jun 2010
                                    • 147
                                    • Usa
                                    #57
                                    Ok will do will get back i a hour just got home
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      My readings are listed in the link I provided. The TV is back together and hanging on the wall. I'm probably not going to take it down and open it back up until there is a fault of somekind. I don't know though, crazier things have happened.
                                      • tomstr
                                        Tommy
                                        • Jun 2010
                                        • 147
                                        • Usa
                                        #59
                                        Ok again tested circuit t.1 set meter at 200 ohms NOT 200k ohms is 00.9 on 12-13 and 00.9 on 12-14 IS THAT WHAT YOU NEED?
                                        • tomstr
                                          Tommy
                                          • Jun 2010
                                          • 147
                                          • Usa
                                          #60
                                          Hey about the skeches on the circuit,which way is the board lying down,not sure were to start don't know how to read scamatics?
                                          • doorzon
                                            AOC AGON AG273QCG refresh problem picture shifts
                                            by doorzon
                                            hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                                            The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                                            See attached picture.
                                            I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                                            However, this could also be related...
                                            08-12-2023, 02:36 AM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • retrorepair
                                            SONY KDL-40P3600 Picture Problem
                                            by retrorepair
                                            Hello gurus, hope you can assist me...
                                            I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                                            I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                                            Thanks in advance.
                                            10-11-2024, 05:12 PM
                                          • KYBOSH
                                            Samsung UN55MU8000 - Backlight But No Picture Problem
                                            by KYBOSH
                                            Hello all
                                            I pick this up free as a repair project for the holidays.
                                            The original symptom was power cycling after 3-4 seconds with a single red light flash.
                                            To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
                                            I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
                                            12-21-2022, 12:42 AM
                                          • Chrissygizmo
                                            Linsar 75uhd520 picture problem
                                            by Chrissygizmo
                                            Hi all, I've recently acquired a linsar 75uhd520 TV, there was nothing on the screen when I first got it, now after finding around I've managed to get a picture but it has loads of lines running through it, I've uploaded a Google image of what the picture looked like, i will upload photos of it soon, also, I didn't get a remote with it, I've went through all my remotes trying to get one to work it but had no luck, does anyone know what remote would work this set please??...
                                            01-24-2023, 10:20 PM
