Sanyo dp42848. No picture no sound?has anyone found the problem
    Re: Sanyo dp42848. No picture no sound?has anyone found the problem
    First using Ohm mode to check the resistance between those pins of the transformer to see if it has open windings, it should show really low ohms.
    Second, we will test the rectifiers by setting the meter in Diode testing mode. please see the notes on the picture.
      7.75 on both circuits, not voltage oms
        "take the reading between pin 12 and 13, and 12 and 14 of that transformer T1"
        Can you verify the reading of the transformer?
        12 & 13 = xxxx Ohms
        12 & 14 = xxxxx Ohms.
        Then in Diode mode reading of the two rectifiers for the 24V?
          I dont thik my meter has diode function?
            Can I see the picture of the meter?
            So you are reading 7.75 Ohms on the transformer? I do not expect it to be that high at all.
              The readings are 7.75 for both
                Is the meter set to 2K Ohms as shown in the picture, if it is that means it is showing 7.75K ohms (7750 Ohms!).Set it to '200' Ohms range and take the reading again. I expect it to be less than one Ohm. What resistance do you get when you short the meter leads together?
                Your meter does have Diode mode.
                I also drew up simplified diagram, as you can see, there is not much for the 24vdc section at all.
                  Set meter to 200k. Readings-1.0 on all points on cathodes
                    Budm did not say 200k ohms he said 200 ohms
                      Ok i will set meter to 200 ohm and let u know
                        Im going to be home half day so i can spend the afternoon on this tv YOU PEOPLE HAVE BEEN VERY NICE AND HELPED ME ALOT THANKS
                          Set to 200 to verify the resistance of the transformer windings. That resistance reading of 7.75 Ohms/K Ohms is not right at all.
                          Set to Diode mode to test the Diode that I asked to check.
                          Please go on line and learn how to test the Diodes and resistance.
                          Right now we have narrowed it down to the 24V output section, the 12v is owrking so the T1 section for the 12v and the driving circuits are functionong OK, only the 24 section is not right, especially the DC resistance reading of 7.75???? is not right at all.
                          I am getting a little frustrated right now on giving the instructions to follow with all the pictures and the diagrams that I had provided so far.
                          May he should by a new board and get it over with.
                            Will do i a couple hours
                              Im trying to follow all suggestions,im goingas fast as possible !!!HELP im going to narrow down in a few,someone sent me a pic of some digram but not sure how to read it?so MABEE I SHOULD JUST GET A POWER SUPPLY?let me know....
                                Just found out how to test diods i will do it tonight
                                  I need that reistance reading of the transformer for sure, may be johnboy1313 can give us the reading from his TV transformer T1 reading.
                                    Ok will do will get back i a hour just got home
                                      My readings are listed in the link I provided. The TV is back together and hanging on the wall. I'm probably not going to take it down and open it back up until there is a fault of somekind. I don't know though, crazier things have happened.
                                        Ok again tested circuit t.1 set meter at 200 ohms NOT 200k ohms is 00.9 on 12-13 and 00.9 on 12-14 IS THAT WHAT YOU NEED?
                                          Hey about the skeches on the circuit,which way is the board lying down,not sure were to start don't know how to read scamatics?
