Sanyo dp42848. No picture no sound?has anyone found the problem
  • tomstr
    Tommy
    • Jun 2010
    • 147
    • Usa
    #101
    Re: Sanyo dp42848. No picture no sound?has anyone found the problem
    NO BUT I HAVE A 12 transformer
      I want to use two 12v lamps connected in series and then connect them to the 24v output to really verify if you have the voltage or not for sure. Something does not make sense at this point.
        Is it possible the transformer has an open winding?
        It would be the first time I've seen one...
          Only if the center tap pin is open tne you will have no output, but I already have him check the resistance on all 3 pins, I myself never have to replace this kind of transformer in all my repair.
          • drpj23
            • May 2012
            • 528
            Just out of curiosity, does removing the inverter from the power supply do anything for the 24v pins?
              Originally posted by tomstr
              What is the rail wire?i unplugged the wire on the power supply upper left at top of power supply,the power supply Board read 24v so I probed that pin. No volts the wire that goes to that pin is white and goes to the invertor, tried on the slave invertor same thing,the other wires show lower voltage like 4.75. But no 24 volts with the tv on plugged in?so if I'm doing it right IS THE POWER SUPPLY TO BLAME?ok will wait up tonight for your reply, thanks
              "i unplugged the wire on the power supply upper left at top of power supplythe power supply Board read 24v so I probed that pin. No volts the wire that goes to that pin is white and goes to the invertor,"
              Hmm, I am trying to understand the statement above. I read it as no 24v with the inverter baord not connected.
              • drpj23
                • May 2012
                • 528
                Sorry, I didn't realize he said that, this thing escalated to 106 posts rapidly so I was trying to rely on memory
                  I know, the thread is getting long, the circuit is so simple, transformer, rectifiers, filter caps- that is? the 12v is generated by the same transformer and it is putting out 12v OK. We are missing something simple here.
                  • tomstr
                    Tommy
                    • Jun 2010
                    • 147
                    • Usa
                    #109
                    Look I don't know anymore than anyone here,but something like a fuse or something has blown?when I plug that tv in and I probe the wires on the power supply there is no 24 volts! Something is shutting down the 24v side of the power board?should I reinstall the board?
                    • tomstr
                      Tommy
                      • Jun 2010
                      • 147
                      • Usa
                      #110
                      How do I power up the backlights with a 24 volt sorce?
                        You need a 24V, 8-10A power supply... if you have one, then provide 24V and connect INV-ON to 5VDC and DIM to 5VDC.
                        • tomstr
                          Tommy
                          • Jun 2010
                          • 147
                          • Usa
                          #112
                          Forget that idea I loaned the power supply
                          • tomstr
                            Tommy
                            • Jun 2010
                            • 147
                            • Usa
                            #113
                            Oh well I'm stuck I guess I will keep looking over this board,if anyone else knows what to do please post thanks
                            • tomstr
                              Tommy
                              • Jun 2010
                              • 147
                              • Usa
                              #114
                              Try this link very interesting could be the problem? http://www.justanswer.com/tv-repair/...hit-power.html
                                I see Rick Williams answer on almost every part of Just Answer to be "it's the capacitors." Even to LCDs with blurring screens etc. It's complete nonsense. But he gets paid for it!!
                                  I still like you to get the lamps for testing the power supply, like I had explained earlier, the T1 supply the 12v and 24V from the SAME transformer and same drive circuit, there is only one shutdown circuit in the primary side of the transformer, if it shuts down, the 12v will be off also.
                                  Did you look to see how much the replacement board is?
                                  • tomstr
                                    Tommy
                                    • Jun 2010
                                    • 147
                                    • Usa
                                    #117
                                    Well I plugged in the power supply to retest wires, now the tv shuts off after 3 seconds,it used to stay on all the time?
                                      Recheck all the connectors, also leave the cable un-connected to the inverter board (no connection on the 24V connector), see if it will come on.
                                      • tomstr
                                        Tommy
                                        • Jun 2010
                                        • 147
                                        • Usa
                                        #119
                                        Which inverter board master or slave?
                                          The connector CN4 to the MASTER, and next to it that goes to the Slave on the power supply board where it is labeled with 24v, do not have anything plug into that connector.
                                          • doorzon
                                            AOC AGON AG273QCG refresh problem picture shifts
                                            by doorzon
                                            hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                                            The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                                            See attached picture.
                                            I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                                            However, this could also be related...
                                            08-12-2023, 02:36 AM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • retrorepair
                                            SONY KDL-40P3600 Picture Problem
                                            by retrorepair
                                            Hello gurus, hope you can assist me...
                                            I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                                            I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                                            Thanks in advance.
                                            10-11-2024, 05:12 PM
                                          • KYBOSH
                                            Samsung UN55MU8000 - Backlight But No Picture Problem
                                            by KYBOSH
                                            Hello all
                                            I pick this up free as a repair project for the holidays.
                                            The original symptom was power cycling after 3-4 seconds with a single red light flash.
                                            To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
                                            I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
                                            12-21-2022, 12:42 AM
                                          • Rusenga
                                            Samsung PS43E450A1R Picture Problem
                                            by Rusenga
                                            Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
                                            Note the green light on the tcon flashes every second.
                                            Power supply board:
                                            PS on 0v
                                            Stby 5v
                                            VS CON 1.72v
                                            VS ON 3.2v
                                            VS 208v
                                            VA. 57v
                                            X buffer :
                                            Svt vs 209v
                                            Svt xout>flactuating between 280 to 900v
                                            Y main board:
                                            Svt vs. 208v
                                            Svt ve. more than 1000v
                                            Svt yg c More than 1000v
                                            Svt yout flactuating between 400v and 1900v
                                            Svt...
                                            11-24-2023, 09:26 AM
