SONY KDL-40P3600 Picture Problem
  • retrorepair
    • Jan 2012
    • 18
    Hello gurus, hope you can assist me...
    I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
    I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
    Thanks in advance.
  • Diah
    • Feb 2013
    • 6499
    not Panel... its like CFL dead or joint connection
    • retrorepair
      • Jan 2012
      • 18
      It's not CCFL. All the CCFL had been tested with external control board, and all of them are fine.
      • Diah
        • Feb 2013
        • 6499
        if you are so sure... show please the inside boards
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4518
          • Italy - Milan
          The problem is in the COF TAB, i think it's fixable, but i never succesfully repaired one, i send you a PM
          • Chrissygizmo
            Sony KD-55XG9505 lines on screen problem
            by Chrissygizmo
            Hello again everyone,
            This is my latest mission, to try getting this Sony tv back to normal working order…
            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
            02-19-2025, 11:31 AM
          • iglitare
            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
            by iglitare
            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
            Backlight seems to work, Sound (Setup menu after reset) works.
            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
            With my small knowledge i would think at least the cables are good.
            Can this happen because of a bad tcon board?
            Or is it always a bad/shorted...
            09-04-2025, 07:13 AM
          • tree5656
            diagnosing sony XBR-75X900H. NO PICTURE
            by tree5656
            This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
            11-09-2023, 04:55 PM
          • crackedprint
            Sony HCD-HX80R Amplifier Volume Control Problem
            by crackedprint
            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
            I have tried a Cold Reset as per the service manual.
            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
            I have looked all the way through the service manual and tried many online...
            01-21-2025, 12:18 PM
          • DKWS89
            Sony XBR 49x900E - Sound and backlight on but no picture
            by DKWS89
            Hey Guys,
            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
            12-14-2023, 04:30 PM
