Philips 42PFL5432D/37
  • Sharpa
    Repair attempt Philips 55OLED804/12
    by Sharpa
    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
    The symptoms when bought: Philips logo appears then tv turns off
    Things tried so far:
    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
    11-22-2025, 08:30 AM
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • Ifixstuff9
    Philips 42PFL5432D/37 power supply issue no 12v
    by Ifixstuff9
    I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
    After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
    05-02-2021, 09:29 PM
  • Justin_D33
    You know what pisses me off? Finding CapXon in the wild.
    by Justin_D33
    It doesn't matter the series - GL, KF, LX, PD, I don't care. If I see CapXon in anything, my instinct is always "get it out of there". Even if it "looks fine". They should be ashamed of themselves. CapXon = CrapXon (rightfully memed).
    Yesterday, 09:27 PM
