Philips 42PFL5432D/37
  • PoteauPets
    • Jan 2012
    • 65
    I Came across this website today when I began searching for recall info for my 42" Philips Flat Screen. The problem started a month ago. The t.v. just goes black, but I still have sound. I can turn the tv off and then back on and it is fine, for a short time and then "poof" out it goes again.
    I have been reading all the posts from others about the same tv with the same problems. I have taken the tv off the wall, taken off the back, and taken pictures. I was disappointed to find that the caps were not bloated, but from what I read they could still be bad, right?
    Can anyone help me/ direct me to where to order the caps? I have never done any soldering, but otherwise am fairly handy for a woman....=) I'm sure I can do this with a little guidance and maybe some words of wisdom from you guys.
    The info on the 3 caps on the left is as follows:
    capXon 1500uF35v
    The info for the other cap on the right is:
    capXon 2200uF16v
    P727
    Vent
    I'm uploading pics for your inspection and eagerly await your replies. Thanks in advance for the help.
    I've tried several times to upload my pics but for some reason it won't let me. Yes, they are the correct size, and I even tried to zip them just to be sure. I will try to post the pics again tomorrow.
  • bbjunkie
    • Dec 2011
    • 301
    Re: Philips 42PFL5432D/37
    Are you using the "Manage Attachments" button just below the Submit Reply button?
    Click on "Post reply" on the bottom left just below my post then look below the Submit Reply button.
    Jim
    • retiredcaps
      • Apr 2010
      • 9271
      See my sig file below for instructions.
      --- begin sig file ---
      --- end sig file ---
      • PoteauPets
        • Jan 2012
        • 65
        Resized the pics again. I have more if needed. Thanks..=)
        • PoteauPets
          • Jan 2012
          • 65
          capXon 1500uF35v
          capXon 2200uF16v
          P727
          Vent
          Thanks everyone
          • retiredcaps
            • Apr 2010
            • 9271
            1) To the left off your board board, there is a green board. It is probably the inverter board. We will need a picture of it.
            2) We prefer pictures in this composition (top down)
            https://www.badcaps.net/forum/showpo...94&postcount=1
            3) Do you have a multimeter?
            • PoteauPets
              • Jan 2012
              • 65
              No, I don't have a multi-meter. Here are the pictures of the inverter board. As far as I can see, everything appears to be okay.
              • retiredcaps
                • Apr 2010
                • 9271
                1) That picture says "Master" which implies a "slave" probably on the other side. We will need a picture of that too.
                2) It looks like the capacitors on the bottom of the Master board are Rubycon. They are good caps so they are unlikely to be the problem.
                3) See if you can borrow a multimeter from someone. Without one, troubleshooting will be very limited.
                • PoteauPets
                  • Jan 2012
                  • 65
                  Thanks for helping........=) Here are the pics of the "slave" side. Looks okay to the untrained eye.
                  I do have a tester, although I have no idea how to use it.......
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Post a picture of your multimeter. We can walk you through it.
                    • PoteauPets
                      • Jan 2012
                      • 65
                      Here it is...........
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        1) Clarification on the "poof". How long does the screen stay on before it goes to black? 1 second, 1 minute, 1 hours?
                        2) If your screen is going black and there is still sound, the problem could be the following:
                        a) The main board is turning off the backlights for some reason via some backlight on/off pin.
                        b) There is something wrong with the inverter boards. It could be a bad inverter transformer, shorted mosfet, etc.
                        c) The power going to the inverter board may be unstable due to bad caps on the power supply.
                        3) While an analog meter can measure a) and c), however the accuracy may not be good enough for b). We need to be able to accurately measure the resistance of secondary inverter transformer pins within 3%.
                        a) and c) must be done with power on. b) is done with power off and tv unplugged from the ac outlet.
                        4) Can you borrow a digital multimeter?
                        • PoteauPets
                          • Jan 2012
                          • 65
                          Clarifiying the "poof"
                          When the tv has been off all day and turned on for the first time, I may get anywhere from 45-60 minutes before it goes out. And yes, when it goes out I still have sound and the power light is still on. I did notice the last few times that it went out, the picture seemed to disappear into the bottom left corner, and then everything went black.
                          Then when I turn it off and then back on again, I may get 10-30 mins. before it goes out again. It seems that once it gets "warmed up" the more frequently it goes off.
                          What can I test with the meter that I have on hand now ? I will see if I can find a "digital one" but that probably won't be until tomorrow.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            1) Let's make sure your analog multimeter is working and calibrated. Take a fresh AA battery. A fresh one should measure above 1.5 V and close to 1.6 V DC.
                            2) Set your multimeter to the 10 DCV setting.
                            3) Put your red probe on the positive end of the AA battery and the black to the negative. Your needle should swing and it should read around 1.5 V. As you can see from this simple test, you won't get too much resolution. On a digital multimeter, it might read something like 1.534 V.
                            Assuming the above tests fine you can now measure the TV voltage.
                            1) First safety. The power board can carry voltages as high as 330 V DC. Avoid touching the power supply including the heat sinks. The heat sinks are likely "live".
                            2) You will need to run the TV with the cover off.
                            3) Power on your TV.
                            4) Set your multimeter to the 250 DCV setting. Don't worry, we are NOT measuring 250 V. Since the master and slave boards are clearly marked 24 V, we cannot leave the multimeter setting on 10 V and thus must use the next highest range.
                            5) On the diagram below, put your red probe on one of the red pins (marked with red "paint" line). It doesn't matter which one. Just be sure to touch only one pin otherwise you could create a short and cause more damage to the TV (which might be big $$$).
                            6) Put your black probe on the ground screw (circled in black). This is your ground.
                            7) The multimeter should read around 24 V DC when the screen is on.
                            8) When the screen goes off, leave the TV on, and re-measure those same two points. If it is still 24 V DC, then the power board is likely good. If it is not 24 V DC, report the reading.
                            9) Do steps 5, 6, 7, and 8 for both master and slave.
                            10) If these instructions are NOT clear, ask for clarification.
                            • PoteauPets
                              • Jan 2012
                              • 65
                              Okay, did the battery test as instructed, reading was perfect.
                              Now on to the next step. Will report back shortly.
                              Thanks again Mr. RetiredCaps.............=)
                              • PoteauPets
                                • Jan 2012
                                • 65
                                Just tested both Master & Slave sides and they both registered about 25 each.
                                Now, since it's not been on all day, I have to wait for it to heat up and kick itself off.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Another possibility that I didn't mention is possibly poor solder joints somewhere causing the screen to go off. Or some heating problem?
                                  Anyway, we need to eliminate one at a time.
                                  • PoteauPets
                                    • Jan 2012
                                    • 65
                                    Well, it made it right about 30 minutes and kicked itself off. Re-tested both slave and master side with power still plugged in and got nothing. The needle didn't move on either side.
                                    Is this good or bad ??? What can I do next ?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      1) So just to confirm, when the TV went off, you left it "on".
                                      2) If correct and you got no voltage (i.e. 0.0 V), then that implies the power or main board is shutting down for some reason.
                                      3) Is the power LED still on when the tv goes black? If yes, what color is it.
                                      4) We will probably need a picture of the main board (where the hdmi, rca, component cables are).
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        A couple of points I'd like clarified - when the screen goes dark do the backlights remain in or go off? If they go off, can you see a faint image on the screen when you shine a bright light on it?
                                        The picture disappearing sounds like tcon, the lack of voltage to the inverters you mentioned above sounds like power supply.
                                        PlainBill
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          Yesterday, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • Ifixstuff9
                                          Philips 42PFL5432D/37 power supply issue no 12v
                                          by Ifixstuff9
                                          I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                          After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                          05-02-2021, 09:29 PM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
