Sony XR-77A80J OLED 5 Blink
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4502
    • Italy - Milan
    #41
    Re: Sony XR-77A80J OLED 5 Blink
    Sorry, it's Sunday i'm lazy, i don't read again all, so since you have nothing loose, why don't you apply my test mode advice? I'm about new in oled field and i'm curious to learn.. don't ask me how, in Latin: Verba volant scripta manent (it's all written)
    give me the tcon model..
    • Diah
      • Feb 2013
      • 6470
      Originally posted by EazyBone
      TV is done. New tcon same results. Panel short. Thanks for trying. I have bad luck with expensive tvs
      don't give up... try to cutting the black plastic covered the panel puffer boards slowly with cutter.( its mounted with infrared heat) ... you could find the issue on ceramic cups 90%
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4502
        • Italy - Milan
        #43
        Originally posted by Diah
        puffer boards
        These?
        Ceramic cups
        these?
        • EazyBone
          • Jun 2023
          • 1356
          • United states
          #44
          I have tried many things, I even found a broken screen a80j and swapped all parts from it. To confirm also evdd would send 21.4v on this one, when doing test. So I ordered new tcon, found a random full set replacement with broken screen and results always the same. The screen shows same exact pattern. I also found a small damage spot on the side of chassis that may have crunched the screen in some way. It was enough to put a small dent in the chassis so I'd assume it could of damaged it.
          As much as I'd love to save it, I think we are confirmed goner.
          Diah, I could cut into the metal strips and such but I have alot of others to fix at the moment. I'm going to put it to the side for now, and if I decide to do such ill look back.
          Davi, I don't see much point in the test now, since I found all those replacement parts. Literally everything is the same no matter what I switch etc and I can see on the broken OLED screen that there was a jumbled picture.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4502
            • Italy - Milan
            #45
            " also found a small damage spot on"
            that is the answer, better to check better next time before buying it and parts..
            • EazyBone
              • Jun 2023
              • 1356
              • United states
              #46
              Yes I'm sure, it was pretty small. The screen shows no damage just on the chassis. Something that was hard to see I guess.
              I only spent $25 on tcon board, I'm not at a loss. This is how I learn, now I know for next time
              • Diah
                • Feb 2013
                • 6470
                the rand of OLED there are 2 lines of the EVDD,
                show me the ribbon cable from T-CON side.. if they have each 4 lines 2 on left & right side separated... or not
                • EazyBone
                  • Jun 2023
                  • 1356
                  • United states
                  #48
                  Already packed up TV but maybe does this help?
                  • Diah
                    • Feb 2013
                    • 6470
                    they look they have,,, but need to see the ribbon self its silver pins..
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4502
                      • Italy - Milan
                      #50
                      On the sides there are glass printed data traces that feeds the rows, that dent appears to be quiet severe.. cracked glass for me..
                      • Diah
                        • Feb 2013
                        • 6470
                        Originally posted by Davi.p
                        for me..
                        yours post #43 just childish action don't do it again.
                        stay in topic. if you don't know any about oled just keep silent.
                          • 12306
                          • U.S.
                          #52
                          Stay in topic. If you don't know any about oled just keep silent.
                          +1000
                          • ChattFix
                            • Oct 2021
                            • 79
                            • US
                            #53
                            I get blue red white green
                            I have the same TV with the 5 blinking red lights. Just wondering how you are able to get the colors on your screen. I have everything disconnected as stated but nothing comes up with LVDS and power lines to the motherboard disconnected.
                            • EazyBone
                              • Jun 2023
                              • 1356
                              • United states
                              #54
                              You need to read the thread thoroughly. You have to jumper voltages to the correct spots, just disconnecting stuff ain't going to do anything
                              • Diah
                                • Feb 2013
                                • 6470
                                follow post 4 at this threat
                                • ChattFix
                                  • Oct 2021
                                  • 79
                                  • US
                                  #56
                                  Diah thanks for that. I'll start reading. Also I have purchase V160 8Th Generation LCD Screen Tester Set 4K-Vbyone & 2K-LVDS For Screen Test. Can I use this to test on this Sony TV?
                                  My reading were incorrect from EazyBone here is what I have below.
                                  1.TCON_12_ON = 0V (never changes when I hit power)
                                  2. BL_ERR = 0V
                                  3. EVDD_ON = 3.38V
                                  4. AC_OFF_DET = 0V
                                  5. POWER_ON = 0
                                  6. STBY = 0V
                                  7. GND = OV
                                  14-20. REG 12V = 12.8V
                                  PSU to TCON.
                                  1-3 0v
                                  4-6 0v
                                  7-18 0v
                                  19-30 0v​
                                  Last edited by ChattFix; 04-09-2024, 10:08 AM. Reason: Incorrect readings on my part.
                                  • Diah
                                    • Feb 2013
                                    • 6470
                                    2. BL_ERR = 0V
                                    3. EVDD_ON = 3.38V
                                    4. AC_OFF_DET = 0V
                                    5. POWER_ON = 0
                                    6. STBY = 0V
                                    7. GND = OV
                                    PSU to TCON.
                                    1-3 0v
                                    4-6 0v
                                    7-18 0v
                                    19-30 0v​
                                    yours measurement had error... not correct 100% .. but please do it again with photos
                                    • ChattFix
                                      • Oct 2021
                                      • 79
                                      • US
                                      #58
                                      Thank you for your response Diah . The only difference I saw was in the pins below located at CN6401:
                                      1.TCON_12_ON = 3.38v for half a second then down to 0v
                                      3. EVDD_ON = 0v then when I hit power button goes to 3.38v then to 0v once red light is present.
                                      Here are the picture below where I started at pin 1 on both PSU to MB then PSU to TCON. I noticed that R712 does not have continuity, is it supposed to have continuity? R712 also flashes 12v on one side for half a second.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        sounds like r712 maybe open circut maybe lift one side from board and re check
                                        • ChattFix
                                          • Oct 2021
                                          • 79
                                          • US
                                          #60
                                          vinceroger69 I removed one leg and still no continuity. I'll look to see a replacement. Is there something else I should check before replacing?
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
