Sony KD-55AG9 TCON?
  • bbrain
    • Apr 2024
    • Hungary
    Sony KD-55AG9 TCON?
    I have this problem with my Sony 55' AG9.
    It flashes 4x.
    I have found the service manual, and seems it is the TCON.
    Before I buy a TCON can someone check the vid?
    https://drive.google.com/file/d/13bR...usp=drive_link
    Thanks in advance!
  • Diah
    • Feb 2013
    • 6501
    no its not t-con.... check first the EVDD socket voltage at start of high and low
    • bbrain
      • Apr 2024
      • Hungary
      Originally posted by Diah
      no its not t-con.... check first the LED BL socket voltage at start of high and low
      Please help, where can I check this? I am new in the oled repair world.
      Thanks!
      • Diah
        • Feb 2013
        • 6501
        open it and post photos tp all boards separately and one to the whole back together
        on the T-CON you have EVDD >22V,,, just disconnect it and see if the tv will complete boot ( screen will remain black) yours sign TV booted and work the audio optic port on main boards will lit red color and remain on
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4520
          • Italy - Milan
          Can you post one,two pictures of screen defect?
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            Post the video from YouTube Link so we don't have to download potentially sketchy files.
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • thelankanguy
              Sony KD-55X9000F TCON Issue
              by thelankanguy
              The TV shows a black screen with no image.
              TCON ribbon connectors were disconnected individually for image and there was no half image even.
              Later both ribbons were disconnected and TCON voltages were tested.
              12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
              There is also a short to ground in this circled inductor.
              Is this a TCON issue or something else ?...
              12-13-2024, 12:27 AM
            • odie34
              Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
              by odie34
              I am a hobbyist (not a professional) so please be gentle...
              I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
              I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
              02-18-2024, 09:11 AM
