Hi guys, I have a problem with this TV, if I detach the flat lvds this seems to work (clearly I don't see anything on the screen), I tried to detach 1 flat at a time and the defect is not there (but shouldn't you see at least the meta display? ?), so the problem is on the mainboard or on the display? Has anyone solved it somehow?
Samsung UE55MU6120K Boot loop with backlight no video
Tags: None
Re: Samsung UE55MU6120K Boot loop with backlight no video
not understanding, what exactly are the symptoms?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS. -
Its either the mainboard... or display as you have surmised.
The 'easiest' way to determine which is which for certain is to get a verified good replacement mainboard and install it. if the TV works then its the mainboard.
The key here is to get a mainboard that is VERIFIED good.
Some of the ones you see on eBay cant be verified bcos they were pulled from TVs with damaged screens that actually never displayed a picture. The issue with those boards could be the screen, the mainboard or both. The seller will almost never verify the part before selling and just assume its good.
The harder way is to test voltages on the mainboard while in a sort of diagnostic mode. This is where you trick the mainboard to think it has a good display attached and it sends signals it normally would. Different mainboards have different ways to initiate this diagnostic test. Some are as easy as putting a jumper on easily accessible pins. Others require soldering different traces together.
But before you do this you may want to check your backlights. Often times they are 'kind of' bad. Good enough to light up but bad enough to trip a protection circuit on the mainboard.
You'd do this with a backlight tester but it 'may' require you to open up the panel and remove the display screen to get access to them.
Good luckComment
the tv turns on, the screen stays black with the backlight on and restarts continuously after 3 seconds. If I remove the panel flats, the TV turns on regularly, I hear sounds, the remote control responds and everything seems to workComment
Good luck
my question is if I test it with scotch tape by eliminating some clock signal lines, can I figure out if it's a display or motherboard problem?Last edited by fanaticgames; 02-05-2023, 02:58 PM.Comment
1) yes, the backlight turns on and off because the tv restarts, you can tell by the red status led
2) if I disconnect the 12 pin cable that goes to the motherboard the backlight stays on without problemsComment
yes I checked the winbond chip on the left pcb and there is 3.3V
I did some random tests with tape on the panel flats and the TV doesn't restart anymore and you can hear the audio and the backlight works but the screen is completely black, no imageComment
are we talking about giving current to the panel? and where I find the 15v line I have no diagrams and nothing is indicated on the pcbComment
Ah, yes, try switching normally on the tv, if you can locate a 15 v for a short time on the capacitors on the screen's boards then you have located the 15v on those condensers, if the voltages does not appear then you must search for technical document of the model, or study the circuit on mainbboard , if you can't i need very sharp picture of it.Comment
by TakeatrySamsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...2 Photos
by torchzackHi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't... -
by NolesFanHello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...2 Photos
by eigmaHi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
Main board: BN94-07592P / BN97-08922R...1 Photo -
My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?... - Loading...
