Samsung UE55MU6120K Boot loop with backlight no video
  • fanaticgames
    • May 2017
    • 138
    • italy
    Hi guys, I have a problem with this TV, if I detach the flat lvds this seems to work (clearly I don't see anything on the screen), I tried to detach 1 flat at a time and the defect is not there (but shouldn't you see at least the meta display? ?), so the problem is on the mainboard or on the display? Has anyone solved it somehow?
    • 12128
    • U.S.
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    not understanding, what exactly are the symptoms?
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      Its either the mainboard... or display as you have surmised.
      The 'easiest' way to determine which is which for certain is to get a verified good replacement mainboard and install it. if the TV works then its the mainboard.
      The key here is to get a mainboard that is VERIFIED good.
      Some of the ones you see on eBay cant be verified bcos they were pulled from TVs with damaged screens that actually never displayed a picture. The issue with those boards could be the screen, the mainboard or both. The seller will almost never verify the part before selling and just assume its good.
      The harder way is to test voltages on the mainboard while in a sort of diagnostic mode. This is where you trick the mainboard to think it has a good display attached and it sends signals it normally would. Different mainboards have different ways to initiate this diagnostic test. Some are as easy as putting a jumper on easily accessible pins. Others require soldering different traces together.
      But before you do this you may want to check your backlights. Often times they are 'kind of' bad. Good enough to light up but bad enough to trip a protection circuit on the mainboard.
      You'd do this with a backlight tester but it 'may' require you to open up the panel and remove the display screen to get access to them.
      Good luck
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4302
        • Italy - Milan
        meta?? Half, che meta?? :+)
        1) how can you state that tv is boot looping? Backlight does on-off?
        2) so detaching a flat b.l. stays on?
        • fanaticgames
          • May 2017
          • 138
          • italy
          the tv turns on, the screen stays black with the backlight on and restarts continuously after 3 seconds. If I remove the panel flats, the TV turns on regularly, I hear sounds, the remote control responds and everything seems to work
          • fanaticgames
            • May 2017
            • 138
            • italy
            Good luck
            if I unplug the cable between the motherboard and the power supply, the LEDs stay on without problems even for 15 minutes, if they were faulty they didn't light up at all or not?
            my question is if I test it with scotch tape by eliminating some clock signal lines, can I figure out if it's a display or motherboard problem?
            • fanaticgames
              • May 2017
              • 138
              • italy
              Sorry, yes half display :-)
              1) yes, the backlight turns on and off because the tv restarts, you can tell by the red status led
              2) if I disconnect the 12 pin cable that goes to the motherboard the backlight stays on without problems
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4302
                • Italy - Milan
                ok so panel problem mostly, check on the screen's small large boards if there's a short on the caps
                • zwarder
                  • Oct 2013
                  • 45
                  • United Kingdom
                  try blocking ckv lines, worked for me
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    I can't identify the ckv lines on this model, can you help me?
                    I can't connect the tracks to the serigraphs
                    • fanaticgames
                      • May 2017
                      • 138
                      • italy
                      do you mean on the two pcb right and left in the panel?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4302
                        • Italy - Milan
                        yep
                        • fanaticgames
                          • May 2017
                          • 138
                          • italy
                          yep
                          Nope, I didn't find any shorted capacitors
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4302
                            • Italy - Milan
                            locate on the panel connector if it is present a 1,8/3,3v
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              yes I checked the winbond chip on the left pcb and there is 3.3V
                              I did some random tests with tape on the panel flats and the TV doesn't restart anymore and you can hear the audio and the backlight works but the screen is completely black, no image
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4302
                                • Italy - Milan
                                inject 12v on the 15v line, prepare to remove it when you see something wrong, better if you increase current slowly..
                                • fanaticgames
                                  • May 2017
                                  • 138
                                  • italy
                                  are we talking about giving current to the panel? and where I find the 15v line I have no diagrams and nothing is indicated on the pcb
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4302
                                    • Italy - Milan
                                    Ah, yes, try switching normally on the tv, if you can locate a 15 v for a short time on the capacitors on the screen's boards then you have located the 15v on those condensers, if the voltages does not appear then you must search for technical document of the model, or study the circuit on mainbboard , if you can't i need very sharp picture of it.
                                    • fanaticgames
                                      • May 2017
                                      • 138
                                      • italy
                                      Left and right board photo:
                                      • lotas
                                        • Jan 2016
                                        • 4555
                                        • Russia
                                        Do not try to supply 12v anywhere, otherwise you will completely kill your panel and motherboard! Check with a multimeter for resistance these leads on the protective diode assemblies relative to gnd.
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
                                        • signedupfordownload
                                          Samsung UE49KU6500U boot loop
                                          by signedupfordownload
                                          My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                          With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                          I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                          07-29-2024, 01:56 PM
