Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I took a piece of tape and lightly applied pressure the last LVDS harness till I saw picture and now its working, watching TNF
Question is, do you know why its doing this? What can be the issue that I can look to fix? I can totally live with it as it is, but its a big tv that get hung on wall, I wouldnt want to close it up and hang it and then the tape gives way 4 months from now and I have to do it all over again. Can I use a silicone to keep it held in place, and if it was needed to service, I can remove the silicone? Thoughts? Thanks all.
Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
Try not to mess too much with the fragile panel to avoid damaging something else.
1. If you have a thermal camera handy, check if any of the ceramic caps near that LVDS connector shows any glow.
2. You may try to use a small piece of thin cellulose tape or kapton tape to insulate a few contact pins at a time on the flex cable to locate which one(s) caused the short. It should be some voltage supply pins that have wider tracks on the PCB, rather than some data pins.
Good luck!
by TakeatrySamsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...2 Photos
by yellowtigerHello Everyone,
I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
Here are my laptop details:
- Model: Lenovo Slim 7i 14IMH9
- Serial Number: YX09M0K7
- Machine type: 83D80003US
**Problem:**
About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...-
Channel: BIOS Requests ONLY!
by TR103I have a Samsung 8K TV (2018), model QE65Q900RAL. The TV does not power on and there is no backlight. The standby LED is on normally. After pressing the power button, the LED turns off, but after approximately 10 seconds it flashes an error code: 1 blink, which indicates a mainboard issue. After that, the TV enters a boot loop: the relay inside the One Connect Box clicks and the cycle repeats.
I checked the mainboard and both backlight driver boards. All voltages appear normal, there are no shorts, and there is no visible damage.
The backlight is controlled via a flat...3 Photos -
by DenizHello everyone,
Mainboard: 820-02890
I'm working on a 16" M2 Pro (A2780) board with a complex boot/DFU issue. I would appreciate any guidance on the next steps.
Symptoms & Behavior:- The board does not boot. Without the trackpad connected, it pulls up to ~500mA briefly, then drops and gets stuck around 140mA. Fans spin at max speed (expected due to missing thermal sensors).
- External USB keyboard Caps Lock test fails (no light after 5 mins), confirming it's a boot-crash/kernel panic, not just a no-display issue.
- Trackpad behavior: When I connect
by No LanHey everyone,
Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise
I've seen what this community can do, so I'm pretty sure you guys can help me out.
Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only... - Loading...
