Samsung UE55MU6120K Boot loop with backlight no video
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4462
    • Italy - Milan
    #141
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    not on the cof, on the panel distribution boards , a jumper on the diodes if present
    • handsworth
      • Oct 2015
      • 174
      Originally posted by lotas
      Here I give you a photo of each half (left and right cable) where to isolate the CKV. Maybe it will be easier for you.
      I have 2 of these MU models and your placements worked for me. Definitefly bad screens. Was hoping to light it up and verify the main boards still worked. Cudos to you
      • Takeatry
        Yet another Samsung QLED Boot Loop
        by Takeatry
        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
        10-04-2024, 02:57 PM
      • torchzack
        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
        by torchzack
        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
        08-28-2023, 07:42 AM
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
      • eigma
        Samsung UN40H5003 boot loop every ~8 seconds
        by eigma
        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
        Main board: BN94-07592P / BN97-08922R...
        11-20-2024, 10:31 PM
      • signedupfordownload
        Samsung UE49KU6500U boot loop
        by signedupfordownload
        My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
        With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
        I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
        07-29-2024, 01:56 PM
