Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Samsung UE49KU6500U boot loop
  • signedupfordownload
    • Jul 2024
    • ireland
    My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
    With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
    I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test? Apologies for the lack of information, I can provide more as needed and pictures too.
    Thanks​
  • Diah
    • Feb 2013
    • 6650
    for test BL its enough to unplug the MB from PSU they should come on.... but yours issue at Panel.. you can stop this reboot by masking LVDS but its just to satisfied solutions... search here you will find allot
    • TVAddict
      • Jan 2022
      • 76
      • Caribbean
      Thanks​
      The black patch may have been caused by possible damage to the panel itself, most likely a minor crack somewhere along the edges of the panel on that side of the tv or the COF over heating and literally burning the panel, either way, my guess is the panel has finally deteriorated to a point of no return.
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
      • eigma
        Samsung UN40H5003 boot loop every ~8 seconds
        by eigma
        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
        Main board: BN94-07592P / BN97-08922R...
        11-20-2024, 10:31 PM
      • blaster_
        Samsung UE49MU6105K - boot loop, horizontal lines
        by blaster_
        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
        06-22-2022, 05:19 PM
      • THXFX
        samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
        by THXFX
        Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
        I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
        When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
        What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
        I check capacitors and diodes and didn't find any short IN MAINBOARD.
        Measured all power supply...
        03-20-2024, 03:21 AM
      • Boardview and Schematic Bot
        09-07-2024, 05:50 AM
