Samsung UE55MU6120K Boot loop with backlight no video
  • fanaticgames
    • May 2017
    • 138
    • italy
    #101
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    my buddy tampatec fixed one by putting some good heatsinks on every chip that got pretty warm on the mainboard, might not do the trick but something pretty easy to try.
    it was installed on the wall, maybe some bad welding and with the deformation of the weight... I don't know what the hell to think, it's the strangest thing that happened to me
    • nomoresonys
      • 12116
      • U.S.
      #102
      not sure, but probably retaining a lot more heat if it's snug against the wall, well was it sitting straight when running for 30 hours as in same position as on the wall.
      • fanaticgames
        • May 2017
        • 138
        • italy
        #103
        It just didn't turn on, plugged into the wall...turned on and baamm rebooting like always
        • nomoresonys
          • 12116
          • U.S.
          #104
          probably won't work but if it's still on the wall try a quick reset before you wrestle it back off the wall, unplug tv, hold power button for 30 seconds and try it, prolly no joy, then off the wall again.
          • fanaticgames
            • May 2017
            • 138
            • italy
            #105
            already done unfortunately it doesn't work, i have to disassemble everything again
            • nomoresonys
              • 12116
              • U.S.
              #106
              lmao...hate when that happens.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4297
                • Italy - Milan
                #107
                Don't waste time with thoughts of bad soldering joints and Macumbeiras... the problem reseats on the display and obviously without surgeries and with the eprom comparison equal you have a alternating defect maybe little heat related, maybe to gate COG , better to start the tespoint searching, clock lines, and prepare masking flats with tape..
                • nomoresonys
                  • 12116
                  • U.S.
                  #108
                  doubt it very much, can not recall a shorted panel ever not working then working for 30 hours.
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    #109
                    I maskered the world to no avail last time, I'll see tomorrow anyway a bit and I do various tests
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4297
                      • Italy - Milan
                      #110
                      Evidently if you have forced TCon-Ready signal and something heated on the main board, the main goal is to locate the short circuit, actually it can also be on a small cap on mainbboard, thethermal cam helps, but also if you go to the supermarket you can ask the shop man for a piece of adhesive thermal paper for the fiscal record, if the heat comes from an inductor only on mb then better to search on the panel distribution boards
                      • fanaticgames
                        • May 2017
                        • 138
                        • italy
                        #111
                        Originally posted by lotas
                        You didn't seem to put a jumper there.
                        I'm back, I bridged the points indicated by you (without connecting the display flats) and the TV turns on and off repeatedly as always, at this point I buy a motherboard once and for all
                        • nomoresonys
                          • 12116
                          • U.S.
                          #112
                          Well you can replace the mainboard 47 times but it still won't fix it if the problem isn't the mainboard.
                          • lotas
                            • Jan 2016
                            • 4554
                            • Russia
                            #113
                            Well, now try, with each lvds cable (from the left, then from the right).
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              #114
                              maybe you missed some pieces :-)
                              • fanaticgames
                                • May 2017
                                • 138
                                • italy
                                #115
                                i heated this area up with 350 degree hot air and the tv started working again
                                • nomoresonys
                                  • 12116
                                  • U.S.
                                  #116
                                  Actually it probably is the mainboard, well there's your proof, posted this after the above post, as in wrote this before your above post so didn't see that til after I posted.
                                  • fanaticgames
                                    • May 2017
                                    • 138
                                    • italy
                                    #117
                                    he seems to be the problem, probably some cracked welding since it now works after being heated
                                    • nomoresonys
                                      • 12116
                                      • U.S.
                                      #118
                                      so I wonder what exactly it could be, do any of those little mlc caps test short, maybe check those resistors too, what is that chip the ethernet switch?
                                      • lotas
                                        • Jan 2016
                                        • 4554
                                        • Russia
                                        #119
                                        This is a DC / DC converter for powering the panel, there may be a problem in tying this converter with ceramic capacitors.
                                        • fanaticgames
                                          • May 2017
                                          • 138
                                          • italy
                                          #120
                                          Yes it's a power main control chip, the nearby capacitor had a cracked solder, I re-soldered it, let's see it works for now
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
