Samsung UE55MU6120K Boot loop with backlight no video
  • fanaticgames
    • May 2017
    • 138
    • italy
    #61
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    Originally posted by Davi.p
    Now that we have listen to the others would you like to follow my advice? what do you think?
    to inject a voltage from 12 to 15 I need a bench power supply that I don't have, I thought I'd solve it in another way
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      #62
      no read my post about the jumper wire..
      • fanaticgames
        • May 2017
        • 138
        • italy
        #63
        I've already bridged those points
        • fanaticgames
          • May 2017
          • 138
          • italy
          #64
          kept on even more than 3 minutes nothing heats up on the display board, in fact I tried 5 times, 4 times the TV restarts the same repeatedly, only once it stayed on, the only thing I noticed was a hum in this area but nothing else
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4462
            • Italy - Milan
            #65
            so to be more clear, TRDY jumpered , but not the ones told to you by Diah, the ones actually marked as them, no tape on the flats, and it keeps restarting? i don' think so, i remember you posted only one picture clear of TRDY point, and the other one?
            • fanaticgames
              • May 2017
              • 138
              • italy
              #66
              read above, united points (the correct ones I assume because without flats they don't restart), with all flats the result is that only once it doesn't turn off, it keeps restarting with the variant that emits a bad buzz in that area of the motherboard , all components are cold except for the cpu which is slightly warm
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4462
                • Italy - Milan
                #67
                Ok, so without a bench PSU i can only suggest this type of test, remove each one of the diode packs on the screen's boards, test entire tv after each removing, if it doesn't change (i think is not there the problem), repeat same thing also with the bigger caps that are probably on the Avdd/15v line..
                just to be clear, the buzzing noise confirms that there is a short circuit on the screen
                • fanaticgames
                  • May 2017
                  • 138
                  • italy
                  #68
                  for information when I did the tests with scotch tape I also isolated the vcom and avdd signal and it always restarts
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4462
                    • Italy - Milan
                    #69
                    and which is the question? the masking suggestion is not by me, you must ask to the owners, avdd and vcom must not be isolated
                    • PaolinaSparks
                      • Feb 2023
                      nothing changes, it always restarts, i guess the ckv lines have nothing to do with it at this point
                      please excuse my stupid question
                      But to really rule everything out please tell me which photo is which cable and if it is mainboard side or gate driver side.
                      • fanaticgames
                        • May 2017
                        • 138
                        • italy
                        #71
                        the tape was put on correctly
                        • fanaticgames
                          • May 2017
                          • 138
                          • italy
                          #72
                          the question is isolating those 2 lines (avdd and vcom) shouldn't it turn on and not restart if the short is there? do you think the short could be on avdd? so your suggestion is to inject the 15v directly on one of the two display boards with everything connected?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4462
                            • Italy - Milan
                            #73
                            if masked avdd or vcom the mainboard circuitry goes in trouble and reboots, injecting on avdd can pop a suspected bad cap so you can replace it, but 12v are enough, the important is that 1,8v/3,3v must be present, therefore cof are powered.. prepare to switch off everything when you see smoke, but pay attention first on screen's glued ribbons, them must not burn!
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              #74
                              the 3,3 are present only for a moment as the tv restarts every 2/3 seconds
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4462
                                • Italy - Milan
                                #75
                                is there any 1,8v? you must check which of these two voltages are present on the smaller caps near the source cofs therefore the ribbons on the bottom side, that tension must be provided constantly to the panel toghether with avdd
                                • PaolinaSparks
                                  • Feb 2023
                                  I hope you forgive me. How could I doubt you
                                  • PaolinaSparks
                                    • Feb 2023
                                    Nope, I didn't find any shorted capacitors
                                    Have you tested the resistors and diodes too?
                                    And I can still recommend disconnecting the Bluetooth module. A defect in it can also cause the error.
                                    • fanaticgames
                                      • May 2017
                                      • 138
                                      • italy
                                      #78
                                      I check as soon as possible, I test as soon as I can with a bench power supply and you update
                                      • fanaticgames
                                        • May 2017
                                        • 138
                                        • italy
                                        #79
                                        I have an update, as usual strange things only happen to me, I left the TV off for 3/4 days with the bridge on points RDY1 and RDY3 today I borrow a friend's thermal imaging camera and turn on the TV (with the bridge and the connected flats) and immediately after 1 second I see these 2 components (in the photo) heating up so much, I disconnect the bridge and turn the TV back on and it works, the whole display works, you see
                                        • lotas
                                          • Jan 2016
                                          • 4753
                                          • Russia
                                          #80
                                          You didn't seem to put a jumper there.
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
