Re: the gutless, bloated, and fried power supply hall of shame
It's possible, but this is very rare. I've actually seen that only in a cheap CWT-built Cyberlink with a tiny EI-28 transformer.
If you don't see a second choke on the secondary side, *most* of the time you can assume the 3.3V rail is regulated in with a MOSFET and a 431 shunt regulator.
 Half of the computer problems is caused by bad contacts
 Basically all todays higher-end PSUs use DC-DC from single very powerfull 12V rail. How else would you achieve close to 90% efficiency, right (also note that blade servers and this stuff uses this for a long time - single higher-voltage rail with huge efficiency). Thats why it came to my mind in the first place, it would be only reasonable to find it in business class-PSUs (like most Hipro OEMs are)
