BIOS guides, methods, resources and tools
This topic is closed.
This is a sticky topic.
  • piernov
    • Jan 2016
    • 4438
    • France
    Please post any suggestions and corrections to the discussion thread: https://www.badcaps.net/forum/showthread.php?t=103527
    For additional information on SPI ROM, BIOS, EC, Intel ME, etc., please read: https://github.com/ISpillMyDrink/UEFI-Repair-Guide/wiki
    Table of Contents:
    1. How to dump and flash
    1.1. BIOS
    1.1.1. Programmers
    1.1.1.1. T48
    1.1.1.2. T56
    1.1.1.3. RT809F
    1.1.1.4. RT809H
    1.1.1.5. EZP2019
    1.1.1.6. CH341A
    1.1.2. Adapters
    1.2. EC
    1.2.1. Programmers
    1.2.1.1. SVOD3
    1.2.1.2. SVOD4
    1.2.1.3. Vertyanov
    1.2.1.4. RT809H
    1.2.1.5. RT809F
    1.2.1.6. T56
    1.2.1.7. T48
    1.2.2. Adapters
    1.2.3. Automatic flashing
    2. How to clean ME/TXE region
    3. Password removal by laptop brand
    3.1. Acer
    3.2. Apple
    3.2.1. 2011 and older
    3.2.2. 2012 to 2017
    3.2.3. 2018 to 2020 (T2)
    3.2.4. 2020 and newer (M1)
    3.3. Asus
    3.4. Dell
    3.5. Fujitsu-Siemens
    3.6. HP
    3.7. Lenovo ThinkPad
    3.7.1. Password ROM bypass (2012 and older)
    3.7.2. DXE password bypass driver injection (2012-2018)
    3.7.3. Flashing EC (2019-*)
    3.8. Microsoft Surface
    3.9. Panasonic, and some other standard AMI implementation
    3.10. Toshiba
    3.10.1. Consumer
    3.10.2. Business
    4. DMI editing by brand
    4.1. AMI-based standard BIOS (SuperMicro…)
    4.2. Acer
    4.3. Apple
    4.4. Asus
    4.5. HP
    4.6. Intel Network Adapters
    4.7. Lenovo
    5. Clearing NVRAM
    6. Finding bios update packages
    6.1. Major brands
    6.1.2. Acer
    6.1.3. Apple
    6.1.4. Asus
    6.1.5. Dell
    6.1.6. Dynabook (Formerly Toshiba)
    6.1.7. Fujitsu
    6.1.8. HP
    6.1.9. Lenovo
    6.1.10. Microsoft
    6.1.11. Samsung
    6.2. Other brands
    6.2.1. Clevo
    6.2.2. Gigabyte
    6.2.3. Haier
    6.2.4. Medion
    6.2.5. MSI
    6.2.6. Schenker
    6.2.7. Panasonic
    6.2.8. NEC
    6.2.9. Huawei
    6.2.10. ASRock
    6.2.11. ECS Elitegroup
    6.2.12. Colorful
    7. Extracting BIOS/EC firmware from update packages
    7.1. Desktops
    7.2. Laptops
    7.2.1. Acer
    7.2.2. Asus
    7.2.3. Dell
    7.2.4. HP
    7.2.5. Lenovo
    8. On Board Ram Disable via Bios Editing
  • piernov
    • Jan 2016
    • 4438
    • France
    Re: BIOS guides, methods, resources and tools
    1.1. BIOS
    BIOS can be updated from software using the manufacturer's tool. It can also often be dumped from software (although not really reliable).
    However, if you need to re-flash the BIOS because the computer does not boot and BIOS recovery procedure does not work, you need an external programmer.
    Likewise, if you want to modify the BIOS to remove a password, it must be done with an external programmer.
    When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
    On Windows, you can use the command "fc /b" to check if two dumps are identical.
    Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
    Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
    1.1.1. Programmers
    T48 is arguably the most reliable and easy to use programmer while still being relatively cheap.
    For eMMC support, consider T48,T56 or RT809H
    If you need LCD monitor In-System Programming through VGA port, consider RT809F or RT809H.
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size https://www.badcaps.net/forum/troubl...ze#post3721905
    1.1.1.1. T48
    Supports I2C, SPI, LPC, FWH, parallel, eMMC.
    Support list: http://www.xgecu.com/MiniPro/T48_List.txt
    1.1.1.2. T56
    Support list: http://www.xgecu.com/MiniPro/T56_List.txt
    1.1.1.3. RT809F
    Supports I2C, SPI, LPC, FWH, VGA ISP.
    Parallel interfaces support requires PEB-1 extension board and can be troublesome.
    Support list: https://www.hklrf.com/Download__1.html
    Software: http://doc.ifix.net.cn/@rt809/ENGLISH.html
    1.1.1.4. RT809H
    Supports I2C, SPI, LPC, FWH, parallel, eMMC, VGA ISP.
    Add extra ITE EC chip support: https://www.badcaps.net/forum/troubl...lashing-ite-ec
    1.1.1.5. EZP2019 ,EZP2019+ ,EZP2020 ,EZP2023 ,EZP2025
    Supports I2C (24-series), SPI (25-series), 93-series.
    Support list: https://www.hklrf.com/wap/Download.html?styleid=&page=1
    Add chip support to EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025 https://www.badcaps.net/forum/troubl...ro-programmers , https://www.badcaps.net/forum/troubl...60#post3611060
    Note: Auto-detection may not work properly for 8Mb and larger ROMs, it is recommended to select the part number manually. In addition, if there are errors when reading and writing, try to lower the speed.
    1.1.1.6. CH341A
    Supports I2C (24-series), SPI (25-series).
    This programmer is not recommended but it is the cheapest programmer available.
    It has several shortcomings:
    • Limited interfaces support, only SPI and I2C
    • Several different software with varying level of reliability and ROM IC support (especially troublesome with 128Mb and larger ICs)
    • Several different hardware design, some of them having design defects
    • No proper detection of communication issue with the ROM IC
    Available software include: NeoProgrammer, Colibri, AsProgrammer, Flashrom ,IMSProg (linux Github Project)
    Add chip support to NeoProgrammer: https://www.badcaps.net/forum/troubl...41a-programmer
    Add chip support to AsProgrammer https://github.com/nofeletru/UsbAsp-...iscussions/132
    Read the guide there: https://winraid.level1techs.com/t/gu...rammer/32948/3
    If you have a black PCB, it is very likely that it needs to be modified for 3V operation instead of 5V. Failing to do so could damage the ROM IC.
    Watch the instructions there:
    https://www.youtube.com/watch?v=-ln3VIZKKaE
    https://www.youtube.com/watch?v=HwnzzF645hA
    1.1.2. Adapters
    It is possible to use clips on SOIC-8 ICs to avoid desoldering, however it is *very unreliable* and will often lead to an empty or corrupt dump. Avoid whenever possible.
    If you insist on using a clip, then make sure the programmer uses an additional buffer and line driver for SPI.The T48 and T56 has it built-in.
    It is recommended to desolder the chip and use an adapter board or socket. They exist for all sorts of packages: SOIC-8 200mil, SOIC-8 150mil, SOIC-16, WSON-8 8x6mm, WSON-8 6x5mm, USON-8 4x3mm, PLCC-32, TSSOP-48…
    Most common packages for the BIOS SPI ROM on modern boards are SOIC-8 200mil and WSON-8 8x6mm.
    Desktop boards sometimes use DIP-8 which can be inserted directly into the programmer.
    Desktop boards before around 2005 used PLCC-32 (which can use a LPC, FWH or parallel bus), even older boards (in the 90s or older) used DIP-32.
    MacBook Pro 15"/17" boards before 2015, MacBook Pro 13" non-Retina and MacBook air before 2011 use SOIC-8 200mil
    MacBook Air and MacBook Pro 13" Retina boards between 2011 and 2015 use WSON-8 8x6mm.
    Apple boards from 2015 to 2017 use WSON-8 6x5mm.
    Apple boards from 2018 onwards use USON-8 4x3mm for T2/M1 ROM.
    1.2. EC
    Dumping and flashing EC often requires a dedicated EC programmer. Some EC can be flashed with regular SPI ROM programmers.
    List of EC that may require programming: https://www.badcaps.net/forum/showthread.php?t=66963
    1.2.1. Programmers
    1.2.1.1. SVOD3
    Code:
    ENE
    ITE
    Nuvoton
    SMSC
    SVOD3 debug ZIF programming PCB - https://www.badcaps.net/forum/showthread.php?t=108704
    1.2.1.2. SVOD4
    Code:
    ENE
    ITE
    Nuvoton
    SMSC
    1.2.1.3. Vertyanov
    Code:
    ENE
    ITE
    Nuvoton
    SMSC
    1.2.1.4. RT809H
    Code:
    ENE
     KB9010
     KB9012
     KB9016
     KB9018
     KB9022
     KB9028
    ITE
     IT8386E
     IT8580E
     IT8585E
     IT8586E
     IT8587E
     IT8595E
     IT8985E
     IT8987E
     IT8996E
    Nuvoton
     NPCE288N
     NPCE388N
    SMSC
     MEC1653
     MEC1650
     MEC1633
     MEC1609
     MEC1619
     MEC1618
     MEC5035
     MEC5045
     MEC5055
     MEC5075
     MEC5085
    1.2.1.5. RT809F
    Not a dedicated EC programmer, standalone programmer supports EC SPI and JTAG interfaces only. PEB-1 extension board supports ITE interface.
    Code:
    ENE
     KB9010
     KB9012
     KB9016
     KB9018
     KB9022
     KB9028
    ITE (requires PEB-1 extension board)
     IT8580
     IT8585
     IT8586
     IT8587
     IT8985
     IT8595
     IT8987
     IT8996E
    SMSC
     MEC1653
     MEC1650
     MEC1633
     MEC1609
     MEC1619
     MEC1618
     MEC5035
     MEC5045
     MEC5055
     MEC5075
     MEC5085
    1.2.1.6. T56
    Not a dedicated EC programmer, supports EC SPI interface only.
    Code:
    ENE
     KB9010
     KB9012
     KB9016
     KB9018
     KB9022
    1.2.1.7. T48
    Code:
    ENE
     KB9010
     KB9012
     KB9016
     KB9018
     KB9022
    1.2.2. Adapters
    Adapter boards exist for some programmers, chip must be (partially) soldered on the adapter board, then the adapter board is connected to the programmer to be flashed.
    In most cases, EC can also be programmed in-system through the keyboard connector. Adapter for the programmer to keyboard connector is required, as well as correct cable (keyboard connectors can have different number of pins and different pitch). Pinout of the keyboard connector matching the EC programming interface must be known and set up in the programmer software.
    Some platforms can automatically flash a blank EC from the image stored in an external SPI ROM alongside the main BIOS when power is first applied. This assumes that there is no other issue on the board.
    Platform with automatic flashing:
    • Most Asus laptops
    • Quanta Y11A
    • To be completed…
    • piernov
      • Jan 2016
      • 4438
      • France
      Cleaning ME/TXE region is required after replacing the PCH or the SoC. Sometimes the ME region gets corrupted on its own and it also required cleaning.
      Cleaning ME/TXE region consists in replacing the existing ME/TXE region in the BIOS dump by a fresh, non-paired one, retaining the manufacturer's configuration.
      Symptoms when ME region cleaning may be required include:
      • Shutdown after 30 minutes (unrelated cause is using Core i3/i5/i7 with HM70 PCH, cleaning ME region won't help)
      • Slow POST
      • Fans spinning at full speed
      • Intel MEI not working in Device Manager
      • In case of Apple machine, macOS reboots or freezes during boot
      • No POST
      Refer to: https://www.badcaps.net/forum/showthread.php?t=88533 and https://winraid.level1techs.com/t/gu...lization/31277 .
      Do not use use Intel ME/TXE Injector/Easy Clean ME or similar tools: they do not retain the manufacturer's configuration and can cause subsequent problems.
      MS Surface no touchscreen after cleaning ME Firmware: https://www.badcaps.net/forum/showthread.php?t=104153
      • piernov
        • Jan 2016
        • 4438
        • France
        DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices. The information given here is for personal use only, ie. you accidentally set a password on your own machine, you forgot the password you set a long time ago or you mistyped the password when setting it and cannot get in again.
        Note that a device bought locked might also have been stolen if the previous owner cannot give the correct password. This is especially common with business-grade equipment (Lenovo ThinkPad…) that employees sneak out or do not return.
        3.1. Acer
        If you enter empty password 3 times, the BIOS gives you a code.
        8-digit answer generators are easily found on the web.
        For 10 digits, see here: https://www.badcaps.net/forum/showthread.php?t=84084
        3.2. Apple
        For 2011 and older machines, changing RAM configuration and performing 3x PRAM reset can clear the password. Password can also be extracted from BIOS dump.
        3.2.2. 2012 to 2017
        For 2012 to 2017 machines, BIOS must be edited and reflashed to clear the password. There are 2 methods for this:
        • Clear out the whole SVS store. There are other stuff in this store, no idea what they are for so better avoid doing this.
        • Invalidate the CBF2CC32 NVRAM variable in that SVS store which contains the encrypted password. You just have to change one bit in its name, so like replace the C with an A or whatever. Note that strings are UCS-2 encoded, so in the hex editor it'll show up as 0x43 0x00 0x42 0x00 0x46 0x00 etc.
        If there is an iCloud pin, you need to perform 3x PRAM reset after removing password. If FindMyMac is still enabled, you have to reinstall macOS while being disconnected from the Internet, then reconnect after logging in and bind to a new Apple account.
        For 2018 to 2020 machines with T2, T2 DFU restore with Apple Configurator 2 can clear the EFI password, however it will not remove the iCloud account. iCloud account is bound to the T2 of the machine on Apple servers and cannot be permanently unbound except by Apple. Methods to bypass activation screen thanks to checkm8 exploit exist.
        For 2020 and newer machines with M1, no publicly known bypass method has been confirmed yet.
        3.3. Asus
        A lot of Asus machines use a standard AMI implementation, and BIOS password can be decoded or cleared from AMITSESetup NVRAM variable. See: https://www.badcaps.net/forum/showpo...55&postcount=2
        Master codes for some dates also exist.
        3.4. Dell
        Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
        See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
        Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
        Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
        Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
        Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
        Note: There is no publicly available 8FC8 generator available at the moment.
        The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
        8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
        See: https://www.badcaps.net/forum/showthread.php?t=79974
        3.6. HP
        BIOS password is stored in NVRAM in the BIOS. BIOS editing and re-flashing is required.
        You can use the automatic unlocker at: https://www.badcaps.net/forum/showthread.php?t=98539
        Another tool that may also work: https://www.badcaps.net/forum/showthread.php?t=103184
        HP i xxxxxxxx 8 digit password: https://www.badcaps.net/forum/troubl...it-code-unlock
        There are mainly 3 methods to unlock ThinkPads and some other Lenovo laptops depending on the generation.
        Most ThinkPads from 2012 and older (3rd gen Intel and older) use a 24-series dedicated password ROM. It can often be bypassed during boot by shorting the SDA and SCL pins together.
        Other times, flashing the ROM may be required.
        For newer machines (2012-2018, 4th to 8th gen Intel), the password itself is stored in the EC. BIOS must be modified and re-flashed to insert a special driver that will allow bypassing the BIOS password.
        Refer to https://www.badcaps.net/forum/showthread.php?t=87588 and https://www.badcaps.net/forum/showthread.php?t=81573
        3.7.3. Flashing EC (SMSC MEC, 2019-*)
        On the latest generations of ThinkPads, the security issue that allowed to inject the DXE driver and bypass the password does not exist anymore. The password is still stored inside the EC, in a write-only region.
        However, it appears that dumping the EC with a dedicated programmer, erasing it and flashing back can actually clear the password. See: https://www.badcaps.net/forum/showth...t=95736&page=5
        https://www.badcaps.net/forum/showthread.php?t=111439
        3.7.4. Flashing EC (ENE KB9012)
        ThinkPad S1 Yoga 12: https://www.badcaps.net/forum/showpo...4&postcount=19
        3.7.5. Flashing EC (Nuvoton NPCE288/NPCE388)
        ThinkPad X390 Yoga: https://www.badcaps.net/forum/showthread.php?t=117284
        Surface Pro 3 passwords are stored in AMITSESetup NVRAM variable and can be decoded from the BIOS dump without any need to re-flash. See: https://www.badcaps.net/forum/showpo...&postcount=139
        Surface Pro 4 and newer cannot be decoded, password must be removed from dump and re-flashed.
        Password often can be decoded from the BIOS dump, see: https://www.badcaps.net/forum/showthread.php?t=102275
        Otherwise, AMITSESetup variable can be cleared from the BIOS dump and re-flashed.
        3.10. Toshiba
        3.10.1. Consumer
        A lot of Toshiba consumer laptops have a jumper on the motherboard that needs to be shorted before boot to clear the password.
        3.10.2. Business
        Most Toshiba business laptops do not have a jumper, and the password is stored inside a protected region of the EC. See affected models: https://www.badcaps.net/forum/showpo...2&postcount=19
        Either you need a donor EC without password, or you need to unlock through challenge-response.
        Response generator is not available publicly, however, some generous people may be able to generate a response for you. Ask in this thread: https://www.badcaps.net/forum/showthread.php?t=79489
        Laptop must not be rebooted, the challenge will change.
        • piernov
          • Jan 2016
          • 4438
          • France
          DMI editing can be required to restore model number and serial number after flashing a blank dump or rebrand a machine after board replacement.
          Copy DMI info easily with Hex editing software and Macro script: https://www.badcaps.net/forum/showthread.php?p=1214739 (NOTE: Can only be used with pre-made scripts)
          WinKeyFinder - Search for Windows key in BIOS dump: https://www.badcaps.net/forum/showthread.php?t=115044
          See: https://www.badcaps.net/forum/showpo...2&postcount=18
          4.2. Acer
          See: https://www.badcaps.net/forum/showthread.php?t=103301
          4.3. Apple
          For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
          Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
          See: https://www.youtube.com/watch?v=poA8HByYqTM
          4.4. Asus
          With these tools you can add DMI information, add a MAC address to older generation Asus boards and fix the keyboard backlight not working on newer generation boards.4.5. HP
          See: https://www.badcaps.net/forum/showthread.php?t=69204
          HP DMI Tool: https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
          Not specific to a board manufacturer but rather to the Ethernet controller on the board.
          If you want to fix the MAC address of some Intel controllers, you can use eeupdate: https://www.badcaps.net/forum/showpo...8&postcount=17
          4.7. Lenovo
          Sometimes you only need a hex editor to edit the DMI,or to copy the DMI to a different bios. Lenovo DMI tools also exist such as U1 tool for newer machines .
          Also some can be edited using the bios update software from the command line,read the bios release notes to find out which ones are supported that way.
          Lenovo Gold Key U1 Tool: https://github.com/ASparkOfFire/lenovo-u1-tool EDIT: No longer available due to DMCA takedown
          Lenovo Golden Key V3.5.60 - DMI EDITOR (BOOTABLE USB) https://www.badcaps.net/forum/troubl...r-bootable-usb
          ThinkPad Config Information Update Utility: https://www.badcaps.net/forum/showth...90#post1174090
          LVAR: https://www.badcaps.net/forum/showth...64#post1133564
          Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019: https://www.badcaps.net/forum/showthread.php?t=98038
          • piernov
            • Jan 2016
            • 4438
            • France
            5. Clearing NVRAM
            Clearing NVRAM manually from the BIOS can help if NVRAM variables become corrupt and POST does not finish successfully, or BIOS freezes before boot, or when entering Setup.
            Actual process may vary between BIOSes, but blanking the first VSS store inside the first NVRAM area can be enough.
            • piernov
              • Jan 2016
              • 4438
              • France
              In order to fix a corrupt BIOS or EC firmware, it may be necessary to find and use an image provided by the manufacturer. Manufacturers rarely provide an image ready to flash, but rather an update file that may
              contain extra data or missing part of the full image. Note that using a clean BIOS like this will lose DMI info.
              All of the major brands provide an official support page.If your laptop or PC originated in your own country go to the country specific support page or region.
              6.1. Major brands
              The current Top 10 brands,listed in alphabetical order.
              6.1.2. Acer
              https://www.acer.com/
              Enter the SNID at the downloads/drivers page.
              6.1.3. Apple
              6.1.4. Asus
              https://www.asus.com/support/
              Laptop - Look for a barcode or QR code on the motherboard for a model number to find the bios
              version the board came with and search at the support site with that model number.
              See: [TUTORIAL] fix asus bios with bios from asus web support https://www.badcaps.net/forum/showthread.php?t=96604
              6.1.5. Dell
              https://www.dell.com/support/home/en-uk?app=drivers
              Enter the service tag.Also look at the configuration that the laptop shipped with - the OS,
              AMT enabled or disabled,Corporate or consumer ME firmware.
              https://dynabook.com/global/en/index.html
              Dynabook has dropped support for many toshiba models.If no bios update is found with the serial
              number search with the short product number instead.
              6.1.7. Fujitsu
              https://www.fujitsu.com/global/support/
              6.1.8. HP
              https://support.hp.com
              See: [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/showthread.php?t=122195
              6.1.9. Lenovo
              https://support.lenovo.com
              Enter the serial number and/or model type.
              6.1.10. Microsoft
              Some but not all updates can be found inside the MSI installer drivers package
              See: https://www.badcaps.net/forum/showpo...25&postcount=2
              6.1.11. Samsung
              Samsung do not provide bios downloads at their support pages.
              See: ID Samsung bios from dump and download the official update https://www.badcaps.net/forum/showthread.php?t=88206
              6.2. Other brands
              This list will not be kept in alphabetical order.
              6.2.1. Clevo
              No bios downloads at official support page.
              See: https://www.badcaps.net/forum/showpo...89&postcount=2
              log in with - username repo . password repo
              6.2.2. Gigabyte
              https://www.gigabyte.com/Support
              6.2.3. Intel
              6.2.4. Medion
              https://www.medion.com/gb/service/
              Enter the product number or MSN.Some updates can be found by searching the Medion forums.
              To find bios updates via google search put an x at the end of the model number instead of the
              last number,followed by the word bios.
              6.2.5. MSI
              https://www.msi.com/support
              6.2.6. Schenker & XMG
              https://download.schenker-tech.de/
              6.2.7. Panasonic
              https://pc-dl.panasonic.co.jp/itn/index.html
              https://panasonic.net/cns/pc/
              6.2.8. NEC
              https://www.nec.com/en/global/support/index.html
              6.2.9. Huawei
              https://consumer.huawei.com/en/search/?
              Search by laptop model number then click on support tab.
              6.2.10. ASRock
              https://www.asrock.com/support/
              https://www.ecs.com.tw/en/download-center
              6.2.12. Colorful
              https://en.colorful.cn/en/home/download
              • piernov
                • Jan 2016
                • 4438
                • France
                In order to fix a corrupt BIOS or EC firmware, it may be necessary to use an image provided by the manufacturer. Manufacturers rarely provide an image ready to flash, but rather an update file that may contain extra data or missing part of the full image. Note that using a clean BIOS like this will lose DMI info.
                BIOSUtilities: https://github.com/platomav/BIOSUtilities
                • AMI BIOS Guard Extractor
                • AMI UCP Update Extractor
                • Apple EFI IM4P Splitter
                • Apple EFI Image Identifier
                • Apple EFI Package Extractor
                • Apple EFI PBZX Extractor
                • Award BIOS Module Extractor
                • Dell PFS/PKG Update Extractor
                • Fujitsu SFX BIOS Extractor
                • Fujitsu UPC BIOS Extractor
                • Insyde iFlash/iFdPacker Extractor
                • Panasonic BIOS Package Extractor
                • Phoenix TDK Packer Extractor
                • Portwell EFI Update Extractor
                • Toshiba BIOS COM Extractor
                • VAIO Packaging Manager Extractor
                Guide to use Dell PFS extractor or other extractors from BiosUtilities: https://www.badcaps.net/forum/troubl...ilities-my-way
                7.1. Desktops
                Retail motherboards can have a full BIOS image or only an update. Pre-built desktops will have DMI info, and mostly only a BIOS update.
                The full BIOS image may be packed into an UEFI Update Capsule. UEFITool with recognize the UEFI Update Capsule and allow you to extract the body in order to obtain the raw BIOS image.
                7.2. Laptops
                For laptops, the manufacturer rarely provide the full BIOS image. The usual procedure is to extract the BIOS region, and if provided the ME region, from the update package, and insert them back into the original dump using Intel FITC. If ME region is not provided, it can be cleaned with one from the win-raid repository at the same time.
                7.2.1. Acer and other Insyde-based UEFI
                See: https://github.com/ISpillMyDrink/UEF...-Tool-(H2OFFT)
                7.2.2. Asus
                See: https://www.badcaps.net/forum/showthread.php?t=96604
                7.2.3. Dell
                AFUDELL: https://www.badcaps.net/forum/showthread.php?t=115830
                7.2.4. HP
                [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948 and
                [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
                7.2.5. Lenovo
                Phoenix TDK: https://www.badcaps.net/forum/showthread.php?t=80861
                  • 25742
                  To fix onboard soldered ram not working sometimes it is neccesary to edit the bios if disabling via resistor straps isn`t an option
                  See: https://www.badcaps.net/forum/troubl...a-bios-editing
                  Bios RAM Patcher, See: https://www.badcaps.net/forum/troubl...ts#post3232220
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • TopPop
                    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                    by TopPop
                    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                    12-14-2025, 09:40 PM
                  • Arzigol
                    Acer Nitro Lite 16 NL16-71G (V1.19) - BIOS Unlock / Advanced Menu / CFG Lock
                    by Arzigol
                    Hello everyone!
                    I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
                    Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
                    Laptop Information
                    Model:
                    Motherboard:
                    CTE_NB_NL160P1G_RTH (NB6807C)
                    CPU:
                    Intel...
                    07-12-2026, 02:27 AM
                  • zlr8r
                    looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                    by zlr8r
                    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                    cheers
                    Dell Inspiron 17 (7786) Laptop
                    Service Tag: 5J0NHT2
                    Bios: 1.9.0
                    MOBO: RO 15 17 WHL 2GB MB / 18706-2
                    Attached;
                    1. My saved bios using a programmer
                    2. Dells Bios updater .exe (v1.16)
                    3. Dells Bios recovery file
                    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                    5. Image of ME...
                    12-18-2023, 03:08 PM
                  • Deniz
                    IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                    by Deniz
                    Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                    I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                    I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                    Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                    After that, I tried to update the...
                    01-27-2026, 06:56 AM
