MS Surface no touchscreen after cleaning ME Firmware **FIX**
    • 21922
    If you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
    ** Some models do not need this fix.
    *You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
    EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
    Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO" then do not change any settings,clean the ME as normal.
    If your working dump models default setting for "Integrated Sensor Hub Supported" is set to "NO" and cleaning the ME firmware does not make the touchscreen work it could be a fault with the screen.
    If a working dump models default setting for "Integrated Sensor Hub Supported" is set to "YES",follow the instruction below,using your own bios to retain the serial number and other DMI information.
    The touchscreen can be fixed by cleaning the ME firmware and making a change to a few settings in FIT (flash image toolkit).Change the "Integrated Sensor Hub Supported" from NO to YES ,the "ISH Image - InputFile" will change to the bios image path.If the "Integrated Sensor Hub Initial Power Up State" is set to disabled then set it to "Enabled" .After changing those settings clean the ME as normal,the settings wil be retained in the saved xml file.
    In picture 1 is a bios dump on the left and a bios with cleaned ME firmware on the right (non working touchscreen,without the fix).Compare the different settings.
    The dump on the left has the correct settings.
    open the bios with ME Analyzer using the -dfpt switch
    Both bios showing the ME Partition layout.ISHC is the integrated sensor hub firmware partition
    Cleaned ME bios,showing the ISCH partition as TRUE after changing the "Integrated Sensor Hub Supported" from NO to YES and
    changing "Integrated Sensor Hub Initial Power Up State" to Enabled
    • 21922
    Download drivers and firmware for Surface
    https://support.microsoft.com/en-gb/...pdate-manually
    If you need to extract the firmware from the MSI installer
    The drivers need to be extracted using MSIEXEC command line tool
    Launch CMD with elevated permissions
    cd to the directory where you have downloaded the MSI drivers package
    Type msiexec /a SurfacePro6_Win10_16299_1900307_*.msi TARGETDIR=C:\SurfacePro6Drivers /qn ( * needs
    to be replaced with the correct number as included in the file name and you are free to use your own
    target directory)
    The target directory will be created automatically if doesn't exist already
    The drivers will be extracted and saved at C:\SurfacePro6Drivers\SurfaceUpdate\Drivers location
    Surface recovery Image https://support.microsoft.com/en-us/...recovery-image
    Surface Diagnostic Toolkit https://support.microsoft.com/en-us/...0-1982eb16f7b5
    • hoaca388
      Badcaps
      • Jan 2022
      • 12330
      Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
      Good job, thank you !
      • clrscr
        • Dec 2020
        • 186
        • sing
        thank you !
        all donations are welcome,
        >>>>> click on this link to donate via PayPal. <<<<<
        • kiensgpro
          Badcaps VIETNAM
          • Nov 2021
          • 17
          Please instructions build bios logo off
            • 21922
            what do you mean logo off, whats the problem,what model number
            • kiensgpro
              Badcaps VIETNAM
              • Nov 2021
              • 17
              Example surface pro 5 size up 4s logo off. Please please instructions how to build the original bios. Can you guarantee me. We tryed clear me and still turn off. But sending the original bios to vinafix build is ok. I please how to do it without anyone.
                • 21922
                Read the ME cleaning guide if thats what you want to fix,or post your bios and someone will try to fix it for you
                https://www.badcaps.net/forum/showthread.php?t=103526
                • kiensgpro
                  Badcaps VIETNAM
                  • Nov 2021
                  • 17
                  OK THANKS BRO. I WILL LEARN IT: chúc mừng:
                  • ahmypc
                    • Oct 2013
                    • 80
                    • Turkey
                    Which intel flash image tool version is required for surface pro 6 ?
                      • 21922
                      Open the bios with ME Analyzer,it will tell you which version it has https://github.com/platomav/MEAnalyzer/releases
                      • ahmypc
                        • Oct 2013
                        • 80
                        • Turkey
                        Thanks for the reply. I have surface pro 5 with bios software modified to remove uefi password. The original bios was deleted. Different bios gives ME error. Is there any way I can fix it?
                        • clrscr
                          • Dec 2020
                          • 186
                          • sing
                          @SMDFlea. my laptop touch not working/ please help me check
                            • 21922
                            Whats the model number.Is it the original bios,has it had a password removed or something
                            • clrscr
                              • Dec 2020
                              • 186
                              • sing
                              my laptop: surface pro 4, before ROM bios die , don't has original bios , this bios i download from intenet
                                • 21922
                                That bios is no good, use one from this forum instead, https://www.badcaps.net/forum/showthread.php?t=87929 just clean the ME region https://www.badcaps.net/forum/showpo...41&postcount=3
                                • clrscr
                                  • Dec 2020
                                  • 186
                                  • sing
                                  thanks! i will checking
                                  • Penetre
                                    • Apr 2022
                                    • 7
                                    • España
                                    I'm trying to solve the same problem... but... how can I extract the BIOS without opening the surface and using a programmer? is there any way?
                                    1000thx for help
                                      • 21922
                                      1000thx for help
                                      Model number ? ,history of the machine .Has it previously had a password removed or the ME firmware cleaned,did the touch just stop working on its own, has the machine been apart before
                                      • Penetre
                                        • Apr 2022
                                        • 7
                                        • España
                                        after an official firmware update, the surface me must be corrupted.
                                        does not finish installing the firmware update, error Code 10. the touch does not work. (Surface ME)
                                        The BIOS has never been touched, the only thing I have done is change all the hardware parts, LCD, Flex, touch plate...
                                        I think that I would only have to modify in the bios, so that the touch is activated.
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Tamo Neko
                                          Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                          by Tamo Neko
                                          I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                          What Happened:
                                          I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                          • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                          • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                          What I Need:
                                          • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                          02-12-2025, 11:29 PM
                                        • jorpec
                                          Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                                          by jorpec
                                          Hi, all
                                          I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                                          10-17-2025, 03:51 AM
                                        • Mephysis
                                          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                          by Mephysis
                                          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                          03-27-2025, 02:34 AM
