WinKeyFinder : Search for Windows key in bios dump
  • SRO2
    • Sep 2018
    • 44
    • FRANCE
    Description:
    WinKeyFinder is a program that I developed to search the Windows key in a bios dump file. This manipulation is easily done with a hexadecimal editor but I have added some features to the program that can help save time.
    Program features:
    - Graphical interface : allows you to choose if you want to scan one or more files or if you want to scan all the files in a directory. The result is displayed in a window and the found keys are automatically inserted in the clipboard.
    - Drag and Drop : drag and drop one or more files or a folder directly on the executable. The result is displayed in a window and the found keys are automatically inserted in the clipboard.
    - Commande line interface : allows you to indicate on the command line the files and/or directories you wish to analyze. The result is returned by default in the console but the program can also create a CSV file associating the file name with the corresponding Windows key
    Help:
    For more information about the program features you can click on the "?" button in the graphical interface or type the command winkeyfinder.exe -h
    Licence:
    The license of the program is GNU GPLv3.
    Bug report:
    If you notice any bugs or if you have any suggestions please let me know
    Source code:
    The source code is available in attachment. The program is written in AutoIt and compiled with version 3.3.14.5.
  • lapfix
    • Mar 2020
    • 2765
    • my workshop
    Re: WinKeyFinder : Search for Windows key in bios dump
    Thank you , i tested with some bios bin and it works
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Thanks for sharing, I tried this tool with many files which I already know if they have a key or not. It's working fine and shows the correct key.
      all donations are welcome,
      • R_J
        • Jun 2012
        • 9623
        What about the Trojan:Script/Wacatac.H!ml included
          • 22109
          It could be a false positive, the exe isn`t signed .
          • R_J
            • Jun 2012
            • 9623
            Ok, just thought I would mention it.
              • 22109
              Its flagged by a few more at Virustotal https://www.virustotal.com/gui/file/...d5c4/detection
              • SRO2
                • Sep 2018
                • 44
                • FRANCE
                Programs written in AutoIt are unfortunately often recognized as trojan/malware... I think that Antivirus programs identify false positives because they make a correspondence with real trojans that also use the native AutoIt libraries.
                I can assure you that the executable I provided is compiled from the source code I provided.
                More informations on the official Wiki of AutoIt : https://www.autoitscript.com/wiki/AutoIt_and_Malware
                • LazzeKongo
                  • Mar 2023
                  • 1
                  • Sverige
                  Really nice, still works
                  Thank you, saved med lots of time!
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                    by mkdj
                    Dear all,
                    I have a ASUS ZenBook UX480F with the following symptoms:
                    I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                    I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                    10-19-2025, 04:41 AM
                  • Habble7
                    I need a BIOS dump for the Samsung S49CG934SU monitor
                    by Habble7
                    The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                    Suspected Cause:
                    I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                    by Citymin
                    My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                    The charging red LED lights up, but the charging screen doesn't show any indication.
                    When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                    (I've tried removing the battery and resetting the device, but the issue persists.)
                    NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                    PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
