looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
  • zlr8r
    • Feb 2023
    • 158
    • dismantling , repairing (attempts)
    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
    cheers
    Dell Inspiron 17 (7786) Laptop
    Service Tag: 5J0NHT2
    Bios: 1.9.0
    MOBO: RO 15 17 WHL 2GB MB / 18706-2
    Attached;
    1. My saved bios using a programmer
    2. Dells Bios updater .exe (v1.16)
    3. Dells Bios recovery file
    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
    5. Image of ME Analyzer result from my saved bios file.
    There is a glitch stopping me adding attachments to this post, so i have added them further below.
  • kalilinux25
    • Mar 2018
    • 2102
    • ZAMBOANGA SIBUGAY
    • COMPUTER PROGRAMMING
    Originally posted by zlr8r
    looking for fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, So I can compare it with my own bios to check for corruption.
    cheers
    please provide the full details specially the service tag
      • 25687
      cheers
      RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
      • Provide a BIOS/EC dump if possible
      • Attach files directly to your post instead of linking to external websites
      • zlr8r
        • Feb 2023
        • 158
        ? tried to update OP, but my edits arent saving nor are my attachments ?.
        They vanish after is press Save ? also after editing the post, other text is being wiped ? whats happening ? Pressing save on an edited post does not save changes made ?
        [update] 15 mins later the forum started working again ... ? Ok, will try to update again OP.
        • Admin
          • Oct 2003
          • 5334
          possibly a cache issue
          • zlr8r
            • Feb 2023
            • 158
            thought that and cleared history in Chrome, same happened again and again. Then site suddenly started working again after 15 mins?, it let me edit text but now isnt saving my attachments ?
            Can you see any attachments on the OP at the top of this page ?
            Admin, is there a glitch in the Matrix blocking my attachments ? its weird, because i can see the jpg image in my OP, but when i try and edit the post, its not there? And none of the .zip attachments I try to add will save ? (tried both Chrome and Firefox, same result) please advise
            • zlr8r
              • Feb 2023
              • 158
              You MUST:
              Hi, I am having a problem uploading any attachments to my post ?
              When i edit the post, I see the option to attach file, I select a file from my computer. I repeat this for the remaining attachments. I then hit SAVE. After that , the post remains unmodified and no attachments are present ? (also tried using the "insert" option, same result. Am I doing something wrong ?
              • Attach files directly to your post instead of linking to external websites - cannot do at present due to problem above?
              please advise cheers
              sample;
              Click image for larger version  Name:	Screenshot_1.png Views:	0 Size:	51.2 KB ID:	3165288
                • 25687
                Attach the files to your next post,if that doesn`t work rename the attachment to some other name and see if that works.
                • zlr8r
                  • Feb 2023
                  • 158
                  since I cannot add attachments to the original OP, ill try adding them here;
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • TopPop
                    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                    by TopPop
                    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                    12-14-2025, 09:40 PM
                  • Deniz
                    IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                    by Deniz
                    Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                    I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                    I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                    Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                    After that, I tried to update the...
                    01-27-2026, 06:56 AM
                  • what_1282105
                    Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                    by what_1282105
                    Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                    02-14-2025, 07:27 PM
