How to add chip support to NeoProgrammer software for the CH341A Programmer
    • 23630
    Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
    and once you do find them there`s a few crucial steps missing.
    Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
    Click image for larger version  Name:	1. NeoProgrammer files.jpg Views:	0 Size:	33.4 KB ID:	3278359
    Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
    Click image for larger version  Name:	2. Import xml.jpg Views:	0 Size:	70.7 KB ID:	3278360 Click image for larger version  Name:	3. Macronix chip.jpg Views:	0 Size:	29.0 KB ID:	3278361
    After adding the chip save the xml file and copy it to the root directory of the NeoProgrammer folder
    Click image for larger version  Name:	4. Root folder.jpg Views:	0 Size:	47.4 KB ID:	3278362
    Start NeoProgrammer,click on the IC tab,and now a new import button is shown.
    Click image for larger version  Name:	5. Import button.jpg Views:	0 Size:	57.2 KB ID:	3278363
    Click on import,then select Yes to start the import.
    Click image for larger version  Name:	6. Import in database.jpg Views:	0 Size:	20.8 KB ID:	3278364
    Success,the chip has been added
    Click image for larger version  Name:	7. Imported.jpg Views:	0 Size:	36.9 KB ID:	3278365
    If you want to know what the id , page and size should be when adding a chip here`s my understanding
    id="C27519" .The C2 is manufacturer, Macronix .The 7519 is memory type and size (might need a correction on this,its where it gets complicated)
    page="256" .The page is usually 256 for SPI bios chips,you can check the chip datasheet to make sure
    size="33554432" .The size is in decimal ,if the bios is 32MB in decimal its 33554432
    Here`s a good list of manufacturer id`s https://chromium.googlesource.com/ch...e/flashchips.h
    If you have an intel bios you can open it with UEFITool and the VSCC table will list various id`s ,although the newest may not be recognised.
  • ali0robot
    • Mar 2023
    • 84
    • N/A
    • Hardware
    thank you so much, it work for me
    • mv707
      • Jun 2023
      • 26
      • Azerbaijan
      Thanks work for me too
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • intelg
        HP Elitedesk 800 G6 lost BIOS admin password
        by intelg
        Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
        Here is the hardware identification specs:
        HP EliteDesk 800 G6 Desktop Mini PC
        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
        BIOS ver S21 Ver. 02.05.01 01/05/2021
        Born on date: 07/26/2021
        SN MXL11841GN
        SKU 3X8V9UCHABA
        UUID 8116E79EF6FFE94DB0B98A3188270C5C
        SYSTEM BOARD ID 8710
        SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
        11-03-2023, 02:05 AM
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
      • Tesla
        Need recommendations for a good chip-programmer please
        by Tesla
        Well, my account here still works. I still remember those days … replacing the caps to save a motherboard. Back before our current disposable-mentality really took-hold. I’ve looked around at the recent threads … it’s really cool how yall help each other. I’ve still been upgrading and fixing desktops and laptops. Replace a laptop-MB, install a NVMe-SSD, new thermal compound apply, pull a coin-battery to clear-cmos (that kind of thing).
        Now that we apparently have to try to build laptops like phones (solder almost everything to the motherboard) looks like the idea of repairing...
        03-15-2026, 06:39 PM
      • VoltVoyager
        ThinkPad T14 Gen 6 Intel (21QD / Intel Ultra 7 265U) – need schematic + CH341A can’t detect SPI flash (1.8V)
        by VoltVoyager
        I’m working on a Lenovo ThinkPad T14 Gen 6 Intel (Type 21QD, MTM 21QDS04D00, CPU Core Ultra 7 265U). I’m trying to dump the firmware from two chips on the motherboard, but I can’t get either chip to be detected by my programmer. I'm looking to flash the bios but I'm not sure which chip is the correct one. This is my first time and I'm excited to learn!
        What I’m looking for:
        • If anyone has the motherboard schematic and/or boardview for this model/board, I’d really appreciate it.
        • Also hoping for guidance on what I might be doing wrong with the SPI read.
        My...
        02-20-2026, 05:38 PM
