Common SPI bios chip programming Questions and Answers
    • 21874
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad contact with a sop8 clip or bad contact on the adapter board.
    Using the wrong clip with a different type of chip (SOP8 clip with WSON8 chip)
    The chip is physically damaged,burnt,shorted or no longer holds data.
    The adapter,clip or chip isn`t lined up with pin 1.
    The chip is 1.8V or lower voltage.An adapter is required if your programmer
    only works at a single voltage.
    The programmer doesn`t have support for the chip in the supported chip list.
    The programmer software needs updating to add support for newer chips or
    alternative software with more support can be used,if available.
    Q: I have a chip thats not in the support list,can i add support for it ?.
    A: That depends if the programmer software allows end users to add it or not.
    There are a few 3rd party software projects to add support to the EZP and CH341A programmers
    Q: My chip isn`t in the support list and i can`t add it,what do i do ?.
    A: Select a different chip that has the same voltage and capacity.Many 25Q chips are
    interchangeable.If the programmer has a check-ID option uncheck it.You may also have to
    untick verify before programming.
    Q: I have a compatible chip,can i flash it with a dump thats already been posted,is making a
    backup of the old one so important.
    A: Your backup could contain DMI information,a serial number,UUID,Windows Key and other
    important info.
    Q: If i flash a dump with DMI info already in it will i be able to change it somehow.
    A: That depends if the laptop manufacturer,motherboard or bios vendor has some DMI tools allowing
    you to change it.Some DMI info can be easily copied from a backup using a hex editor , no
    other software needed.
    Q: Is the DMI info stored in every bios.
    A: No,sometimes its stored in the EC or on a seperate eeprom.
    Q: What is a virgin bios ,if i flash it will i lose DMI info.
    A: Its a clean bios straight from the manufacturers support page or extracted from an update.
    If the DMI info is stored in the bios you will lose it.
    Q: If a full virgin bios is available and the DMI from the backup is easy to copy is there any need
    to have my backup repaired.
    A: A virgin bios should be the preferred option,it is quicker than trying to fix your backup.
    Q: Can i flash a bios dump with different DMI info,i`m not bothered about it having a different serial.
    A: Yes,although with some models you can have a pop-up warning message on screen about a mismatch.Make
    a backup of your original bios,just in case.
    Q: My chip is damaged,i have a donor motherboard,can i just swap the bios chip over.
    A: If its not from the exact same model no.If its from the exact same model yes if its an AMD
    board.If its a modern intel board an extra step is needed,the ME (Management Engine) firmware
    will need cleaning first or it will shut down after 30 minutes,boot slow or not boot at all.
    If there`s a unique IP address stored in the intel Gbe region then it might need editing
    with a hex editor after ME cleaning,or programmed with MAC address changer software.
    Q: Can i make a backup and program the bios without having to desolder the chip ?.
    A: Sometimes yes,you can use a sop8 clip,WSON8 pogo pin adapter ,solder wires to the chip
    legs or empty sop8 contacts on the board.Some desktop boards have a programming header with pins.
    Q: I`m using a clip ,i can`t make a backup,what can i do.
    A: In some cases attaching the laptop charger can help.
    Additionally read: https://www.badcaps.net/forum/showthread.php?t=103526 1.1.2. Adapters
    Q: Is it more reliable to desolder the bios or use a clip.
    A: Desoldering is best,although it must be said that clips can be used fairly reliably with plenty of practice.
    Q: The bios chip is WSON8,there`s no legs for the SOP8 clip to grip onto,how do i program it ?.
    A: Desolder it and use a WSOS8 adapter board,use a WSON8 clip with pogo pins or solder wires to the
    motherboard if there`s some empty solder pads for a SOP8 chip.
    Q: How do i know if i`ve made a good backup or not ?.
    A: One of the easiest ways is to make 2 backups,open both with a hex editor and use the
    File-Compare option.Scroll through and make sure there`s some code in the backups.If both files
    are all FF`s (empty) then you havn`t made a good backup or the chip is blank.Make multiple backups
    making sure all connections are good and all programmer settings are correct.Double check,triple check !
    Additionally read: https://www.badcaps.net/forum/showpo...40&postcount=2
    Q: I`m sure the backup i made is good but it still looks corrupt,can i still post it ?.
    A: Yes,it might be fixable or there could be some DMI data still readable.
    Q: I have seen EC files posted besides bios dumps,do i have to program them too.
    A: No,try the bios first,although if there is a big mismatch between an older bios and much newer
    EC and vice versa it might not boot.The EC may have a seperate external chip (any programmer
    will flash it) or have internal memory inside the EC chip that you have to flash with a
    dedicated programmer.Some EC chips aren`t programmable,the firmware can also run from the bios.
    Q: I`ve written to the chip but it won`t verify,there`s an error message,whats happening ?
    A: The chip isn`t soldered properly to the adapter or not lined up in the socket,or the chip is faulty.
    Erase the chip and try programming again.
    Q: I have a CH341A,is there any other alternative software for it ?.
    A: Yes,there`s NeoProgrammer, Colibri, AsProgrammer, Flashrom , IMSProg (for linux - Github project) .
    Q: I have a Raspberry PI,can i program an SPI bios with it ?.
    A: Yes you can. https://www.badcaps.net/forum/showthread.php?t=43777
  • hotcrossedbuns999
    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
    by hotcrossedbuns999
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this
    01-03-2025, 12:32 PM
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • elzorroazul777
    Did I Screw Up? Any Hope for Success? Programming BIOS CHIP
    by elzorroazul777
    Before I go further down the rabbit hole, I'd like to know if I have created a dead-end in my repair process. I am attempting to reflash my Lenovo X1 Extreme Gen 2's BIOS chip after a power interruption corrupted the BIOS data during an update.
    I do not have backups of the data I pulled off the chip using a CH341A 24 25 Series EEPROM https://www.amazon.com/Organizer-Soc...Q%3D%3D&sr=8-5
    I also wrote to the...
    10-09-2022, 10:45 AM
  • inck243
    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
    by inck243
    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
    The BIOS...
    07-25-2024, 09:17 AM
  • Azurain
    Elitebook 840 G5 Bios Chip Soldering Question
    by Azurain
    Hi everyone,
    I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
    Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
    04-14-2023, 06:58 PM
