ACER 10 Digit unlocker
  • let-def
    • Apr 2020
    • 5
    • France
    I had the chance to have a bogus computer. I saw on this forum that I was not alone, but after some work I managed to write an unlocker:
    https://let-def.github.io/insydious
    Good luck with your computer .
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: ACER 10 Digit unlocker
    Appreciate your work.
      • 20795
      Can any other members confirm if this unlocker works or not .
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Key generate is good.
        • peste
          • Dec 2016
          • 12742
          • ROMANIA
          yes ... post # 57, was made with this unlocker... it seems to work ...
          https://www.badcaps.net/forum/showth...t=80697&page=3
          • CraterM
            • Mar 2018
            • 178
            • Moldova
            Work
            • ibo
              • Oct 2019
              • 93
              • Turkiye
              thanks good work,
              when i download this on github how can i open this file to get it work?
              • Claudiomfa
                • Nov 2015
                • 455
                • Portugal
                Originally posted by ibo
                thanks good work,
                Open html file
                • let-def
                  • Apr 2020
                  • 5
                  • France
                  Yes, opening the html file is enough. It depends on the deriv.js file, so you need to copy both to have a "standalone" unlocker. It is possible to store everything in the html file, I can do that if it helps.
                  • BetaMan1998
                    • Apr 2020
                    • 2
                    • India
                    This WORKS!! Thank you so so much!
                    • f1cs2000
                      • Apr 2020
                      • 2
                      WOrk perfect for me Thanks !!!
                      • przemek_79
                        • Dec 2014
                        • 28
                        • Poland
                        Work THX
                        • ytepay
                          • Apr 2020
                          • 0
                          • India
                          Yup it worked...... Thanks it's really amazing .... Thanks
                          • MadFerIt
                            • May 2020
                            • 2
                            • Brasil
                            Dude, you have no idea how you have helped me. My god, i've been searching for so long for a solution to this problem and you just solved it in 10 seconds.
                            You, my friend, are godlike. Thank you so freacking much!
                            • Maurysan
                              • May 2020
                              • 2
                              • Italia
                              hi I don't know you are still active, I have the following problem, my acer aspire 3 A315-21g notebook has gone into a password lock and I am not in any way able to unlock it.
                              has a 10-character Outlook Password 1691620848.
                              you can help me?
                              • Maurysan
                                • May 2020
                                • 2
                                • Italia
                                I tried the key gen but nothing went wrong
                                • let-def
                                  • Apr 2020
                                  • 5
                                  • France
                                  Did you try typing the unlock key e93608a6dbeb8b73 with an external keyboard?
                                  A few people have reported issues unlocking with the builtin keyboard. I recommend to try again with an external USB one.
                                  • fyaagoub
                                    • Dec 2016
                                    • 269
                                    • maroc
                                    Thank you
                                    • bradastu
                                      • Feb 2020
                                      • 7
                                      • Thailand
                                      My given unlock code is af37ef70753648a1 but the BIOS input box on my Spin 3 only takes 10 characters. What can I do, please?
                                      • let-def
                                        • Apr 2020
                                        • 5
                                        • France
                                        Did you try typing the full code? I suspect that the limitation is just visual, internally the full code will be taken into account.
                                        (Also if it doesn't work, don't forget to also try with an external keyboard)
