Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
  • istvanszasz99
    • Nov 2025
    • Hungary
    Product ID: RZ09-0421
    Motherboard: CH580
    Bios File Size: 32,768 KB
    Dear Forum Readers!
    !!! MY RAZER BLADE HAS POWER THROTTLING ISSUE !!!
    That's the reason i'm looking for answers in the BIOS.
    More info about that in my reddit post:
    https://www.reddit.com/r/razer/comme...g_i_need_help/
    There are the questions I'm looking for:
    _/PCI Subsystem Settings/Re-Size BAR Support Disabled
    Is that easy to get Re-Size BAR Support just by switching it to Enabled?
    _/Setup/OverClocking Performance Menu/
    Need help to understand, If i'm correct i don't have to touch it if the system is working as it should in normal case. I only have to touch it if I want to extreme OC the system.
    _/Setup/Advanced/Power&Performance/CPU-Power Management Control/ View/Configure Turbo Options/ (This page controls the PL1 & PL2 limits)
    _/Setup/Advanced/Power&Performance/CPU-Power Management Control/ View/Configure Turbo Options/Power Limit 2 Override Enabled (Control Help String: Enable/Disable Power Limit 2 override. If this option is disabled, BIOS will program the default values for Power Limit 2.)
    _/Setup/Advanced/Power&Performance/CPU-Power Management Control/ View/Configure Turbo Options/Power Limit 2 0 (Control Help String: Power Limit 2 value in Milli Watts. BIOS will round to the nearest 1/8W when programming. If the value is 0, BIOS will program this value as 1.25*Processor Base Power (TDP). For 12.50W, enter 12500. Processor applies control policies such that the package power does not exceed this limit.)
    I'm not sure that the Power Limit 2 option should be 0 by default when the override option is Enabled, because my Intel i7-12800H CPU's Processor Base Power (PL1) is 45W and the Maximum Turbo Power (PL2) is 115W.
    Based on the settings that are factory defaults, this should behave like this --> 1.25*45W=56.25W.
    I don't know if these values are purposely edited like this or just by mistake, but I checked the CPU with ThrottleStop and when it hits around 55W+, the PL2 starts Throttling.
    Can I turn off the override or should i set the value of Power Limit 2 to 115000?
    _/Setup/Advanced/Power&Performance/CPU-Power Management Control/Config TDP Configurations
    I need explanation of this page. I figured out it's related to MMIO and MSR about PL1 and PL2, but I don't know if I should change any settings here.
    _/​Setup/Advanced/Power Performance/CPU-Power Management Control/ View/Configure CPU Lock Options/ Overclocking Lock Enabled (Control Help String: Enable/Disable Overclocking Lock (BIT 20) in FLEX_RATIO(194) MSR)
    If I switch it to Disabled, Will I be able to control the Overclocking option with softwares like ThrottleStop or Intel XTU? Now it's fully locked to overclock anything on software side.
    _/Setup/Advanced/Thermal Configuration/Platform Thermal Configuration
    Active Trip Point 0 71°C
    Active Trip Point 0 Fan speed 100 (0-100 scale)
    Active Trip Point 1 55°C
    Active Trip Point 1 Fan speed 75 (0-100 scale)
    Active Trip Points Enabled
    Should I change anything to make better optimalized performance for my laptop?
    I'm not too sure about the Active Trip Points indexing order. Shouldn't it be in the opposite way?
    _/Setup/Advanced/Thermal Configuration/Intel(R) Dynamic Tuning Technology Configuration/OEM Variable and Object/
    Processor Thermal Device
    _TMP 1 Object Disabled
    _TMP 2 Object Disabled
    _TMP 3 Object Enabled
    _TMP 8 Object Enabled
    Should I switch _TMP 1 & _TMP2 Enabled or this is purposely disabled?​​
  • hafner@zendada.org
    BIOS dump for a Razer Blade Pro 17 FHD (RZ09-0220, 2017)
    by hafner@zendada.org
    Looking for a clean BIOS dump for a Razer Blade Pro 17 FHD (RZ09-0220, 2017). Unit was bricked by power transients during a tropical storm shutdown in Hawaii. Razer has EOL'd this product and won't provide BIOS support.
    Details:
    - Model: Razer Blade Pro 17 FHD
    - Part number: RZ09-0220
    - Year: 2017
    - Flash chip: Winbond W25Q128 (assumed)
    - Cause: power transient on shutdown — dead on next boot
    CH341A programmer + SOIC8 clip on the way. Happy to dump and share my chip back to the community once recovered — that's...
    03-17-2026, 03:25 PM
  • lming888
    Razer Blade 14 (2021) RZ09-0370 - Black Screen / Corrupted BIOS - Need Clean Dump with DMI
    by lming888
    I am looking for some help repairing my laptop's BIOS. The machine experienced a bad flash/corruption (wrong parameters were used during the flashing process) and currently results in a black screen with no boot / no POST when powering on.
    This is what I did,
    AFUWINx64.EXE P1106.rom
    Instead of
    AFUWINx64.EXE P1106.rom /p /b /n /RLC:E
    I have successfully desoldered the BIOS chip and performed a 100% verified dump using a CH341A programmer and NeoProgrammer (multiple read.000s matched perfectly, 0% difference)....
    07-01-2026, 05:51 AM
  • Heitor - AWS Informática
    Razer Blade 2020 RZ09 03519E11 - BIOS Request
    by Heitor - AWS Informática
    Hi, everyone!
    I've a Razer Blade 2020 on my bench today, all stand-by tensions are OK, but we've no action when I press the power button.
    Here's some informations about the laptop and the original file backup:
    Laptop Model: Razer Blade 2020
    MB Model: ol510mb v1.0
    P/N: RZ09 03519E11
    S/N: 622048M10000619
    Many thank's in advance! And if I broke any rule, sorry, I'm a rookie here, just tell me how can I fix that ...
    12-01-2025, 08:05 AM
  • masufany
    Razer Blade 15 Advanced (2020) RZ09-03304F42 Not turning on, 0V on coils, bios not receiving power
    by masufany
    I have a Razer Blade 15 Advanced from 2020 model number RZ09-03304F42 that doesn't turn on, no led light and no charging. When I supply 19v the amperage goes to 6 amps for less than a second, and then drops to 0.5 amps for 1 second and drops once again to 0.1 amps, I checked the coils and they all give 0V, or some 0.4v. The power supply is working, and 19V enter the charging port, I followed its trace and it goes to a mosfet, which receives 19.5v at source, and 17.5v at gate, and goes to the other side of the board, but the coil there's 0V for some reason. What I have found is that the 8mb bios...
    03-21-2026, 11:31 AM
  • theplop
    Razer blade 2022, 14" PI480 wont boot to OS, freezes
    by theplop
    Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
    I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
    I've run memtest quite a few times, and more often then not...
    03-20-2025, 06:42 PM
