Hp elitebook 840 g5 bios password
You may be right, but I prefer such a defense-in-depth. The other night, a thief cut a hole through my window while I was sleeping, trying to steal my phones from my bedside using a long stick. But I woke up before any damage could be done.
I initially thought as much, but didn't think that was the issue. The same password that didn't work happened to work again. I have not restarted my laptop again since then, as I always put it in sleep mode. I don't know if the problem will continue to persist or not.
HP Elitebook 840 G5
Serial Number : 5CG8524YZM
ProID:3JX27EA#ABE
Password Remove please
Attaching Backup BiosAttached FilesComment
Type the laptop serial number, full name and model, motherboard model, etc.
post the contents of the bios chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
HP EliteBook 840 G5 (Board ID 83B2) — need clean dump for 25Q128JVPQ (EC/SureStart)
I need a clean dump for the second SPI chip (EC / SureStart) on an HP EliteBook 840 G5.
Laptop details:
- Model: HP EliteBook 840 G5
- Board ID: 83B2
- System BIOS: Q78 (version 01.09.01)
- Main flash: W25Q256JVEQ (32 MB) — I already have a clean working dump with my serial numbers.
- Secondary flash: 25Q128JVPQ (16 MB, EC) — my dump is attached below.
Symptoms: The laptop works only with the main 32 MB chip replaced, but I suspect the EC/SureStart flash (25Q128JVPQ) is corrupted.
Since HP SureStart uses this chip, I need a proper clean dump to reprogram it.
Could someone please share a clean working EC dump for this exact board (ID 83B2)?
Any help would be greatly appreciated. Thanks in advance!
Добрый день!
Ищу чистый дамп для второй SPI-флешки (EC / SureStart) ноутбука HP EliteBook 840 G5.
Данные по ноутбуку:
- Модель: HP EliteBook 840 G5
- Board ID: 83B2
- System BIOS: Q78 (версия 01.09.01)
- Основная флешка: W25Q256JVEQ (32 МБ) — дамп уже собран, чистый с моими серийниками.
- Дополнительная флешка: 25Q128JVPQ (16 МБ, EC) — мой дамп прикладываю ниже.
Симптомы: ноут работает только после прошивки основной флешки, но подозреваю, что дамп EC (25Q128JVPQ) повреждён.
Так как HP SureStart использует этот чип для восстановления, нужен правильный чистый дамп, чтобы прошить его программатором.
Буду благодарен, если кто-то поделится рабочим чистым дампом под эту модель (Board ID 83B2).
Заранее спасибо!
post S/N, product number,post the contents of the bios chip even if it is corrupted..
,etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Серийный номер: 5CG9207TJ1
W25Q256JVEQ (32 МБ)
I'll post the second one tomorrow because I didn't have time to take it off today.Attached FilesComment
here is the second one as promisedAttached FilesComment
Hi anyone can help remove bios password
HP Elitebook 840 G5
SN: 5CG9050GJHComment
Thank you
already removed via rcunlocker
but everytime i bootup there is MEBx Login
anyone how to remove this ?Attached FilesComment
Hi need help remove bios password, i already try using RCunlocker with 16mb chip, but the password still there.
here i upload both 16mb and 32mb original file.
HP Elitebook 840 G5
SN: 5CG9052M48Attached FilesComment
try..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
- Loading...
