Lenovo Thinkpad Ec Pwd Bypass
    Originally posted by Maxpower3 View Post
    Mec16
    look for j9301 if you have it
    https://www.badcaps.net/forum/troubl...61#post3250061
    yes i have j9301 i will try thank You
      anyupdate about this model for remove password P15 Gen 1 NM-C651
        NM-C651
        NPCX897KA0BX
        try
          Mec16
          Click image for larger version  Name:	s-l500.jpg Views:	3 Size:	70.8 KB ID:	3263038
          I do everything as in the video, I click - I enter the bios 2 times, enter the password is disabled, then I need to save F10 (because when I simply reload the bios, I continue to be blocked by the password) Thank you Done
            NM-C651
            NPCX897KA0BX
            try
            not working with this sir stuck on logo
              clear security chip
              https://www.badcaps.net/forum/troubl...00#post3262400
                Thank You
                  good night master chief Today I tried again...
                  I bought some metal tweezers and a Windows keyboard
                  I don't know what I'm doing wrong or what I'm not doing.
                  If you could leave me a message so I can follow the procedure to the letter, I would greatly appreciate it.
                  (I leave images)
                    NPCE68BPA0DX Lad Pin 126-127-128 or 1 of EC
                    Not working for me
                      Anyone tried ITE IT5679VG ?
                      Its T14s Gen 2 AMD
                        (I leave images)
                        In old Lenovo it was required to qround security chip just before pressing F1 or even during pressing F1, to brick communicTion, so bios don't read password from it.
                        Maybe try that way.
                        I also wonder if it is not necessary to ground all 126 127,128 and 1 pin at the same time to ground.
                        Also some hint here for older Lenovo:
                        https://davidzou.com/articles/bios-password-bypass
                          Maybe try that way.
                          I try all process but not success
                          Please You guide me step by step
                            Hello. The same method I used on MEC1723 did not work. The short circuit will get stuck on the LOGO. Can't do anything, can't move
                            Asking for guidance from the master, how to unlock PASSWORD in MEC1723
                              Hi Maxpower3, please help me with T14 gen 1 AMD GT4A1 NM-C801 rev.1.0, can't find boardview and don't know where to connect switch to motherboard. Thank you!
                                NM-C801 IT5261VG
                                  Thinkpad x13/T14s Gen 1 AMD GT4A5/GX3A5 NM-C791
                                  IT5261VG
                                    Originally posted by 本本修 View Post
                                    Hello. The same method I used on MEC1723 did not work., how to unlock PASSWORD in MEC1723
                                    sorry, no solution with that
                                      Its T14s Gen 2 AMD
                                      https://www.badcaps.net/forum/troubl...15#post3238715
                                        Any proven solution for Lwnovo L14/L15 and NPCE68BPA0DX, maybe bios file if short pins not work?
                                          This happens to me too,
                                          change the timing and start earlier just before backlight and stays short for less time.
                                          Mec16 is difficult
                                          many many tries
                                          I've a T14 NM-C931 rev1. after many tries with no lucky it now show me before the logo also if not shorted:
                                          0271 Check date and time
                                          0188 RFID serialization inform area (or something like that)
                                          2200 machine type and serial number are invalid
                                          ( before start to try i disconnected the big battery and also the button one and the check date and time error started for this)
                                          Is this normal so i should still try?
                                          In a post before i read to not short before the backlight, is still valid or with mec 1663 no?
                                          Thanks in advance for any advice
