Dell n5010 can be converted from graphic version to non graphic
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Dell n5010 can be converted from graphic version to non graphic
    Originally posted by megaraider
    Because an user requested them to me by pm, samanthban,
    i'm posting the mobo images from n5010milind.pdf
    Thanks my friend
    sigpic
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      after this, do you see DSC vga in device manager or is it like it does not exist?
      Im Back... sort of...
      • jaikumarpeddy@gmail.com
        JCS
        • Sep 2015
        • 12
        • India
        Thank you friends for your guidelines and images.
        I will try this. Hope I get success in it.
        • ibrahim03
          • Oct 2015
          • 143
          • egypt
          thanks for sharing
          I will try this .
          • minhaj
            • Jul 2015
            • 13
            • india
            thanks for sharing bro
            • aamkaachaar
              • Jun 2013
              • 4
              • india
              #26
              problem with Dell n5010 converted from graphic version to non graphic
              hi Guys
              i followed all the instructions and did the conversion...
              Display comes fine and i can enter bios and do saves settings and all...
              But ..... the laptop doees not boots up to post screen ......
              neither it is able to boot with USB, CD , HDD or any other media ...
              the display just hangs on a plane white screen after the Dell logo...
              Alt+ CTrl + Del has no action.....
              Even tried to flash the Bios ...with a good one .....but no use .....
              the problem is the same ...
              Thought that might be problem in particular motherboard ... i tried the same on another board
              but ...struck on same page .....
              any ideas guys
              Waiting
              • polytek
                • Dec 2013
                • 496
                • TUNISIA
                #27
                try to flash the ec bios U6202 it's near the cpu socket (MX25L2005C)
                • ibrahim03
                  • Oct 2015
                  • 143
                  • egypt
                  #28
                  Re: problem with Dell n5010 converted from graphic version to non graphic
                  I have the same problem.
                  • tirtha
                    • Oct 2015
                    • India
                    #29
                    Did it worked properly after the conversion?? Please reply if any one does it.
                    • ibrahim03
                      • Oct 2015
                      • 143
                      • egypt
                      #30
                      If there was one can communicate with this Chinese site, there is his subject shows the success of the experiment
                      http://www.chinafix.com/thread-875435-1-94.html
                      • ibrahim03
                        • Oct 2015
                        • 143
                        • egypt
                        #31
                        Are there any solutions ؟
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          #32
                          It is never going to work. There are a lot more thinks to do to make it work.
                          • samanthban
                            • Feb 2014
                            • 253
                            • Sri lanka
                            #33
                            This is from another site some one can try and let us know
                             PU5301 > TPS51611
                             PR5311 > 90.9K
                             PC5313 > 2.2U 10V
                             PC5314 > 68P50V
                             PR5312 > 1.69K
                             PC5315 > 22U 10V
                             PR5325 > 18.7K
                             PC5317 > 3300P 50V
                             PR5301 ,PR5302 > 0 OHM
                             PR5327 ,PR5332 > 330 OHMS
                             PC5320 ,PC5322 ,PC5323 ,PC5324 ,PC5325 ,PC5314 > 33P 50V
                             PC5321 > 22U 50V
                             PR5331 > 29.4K
                             PR5330 > 86.6K
                             PR5328 > 24.3K
                             PR5323 > 2.2 OHM
                             PC5301 > 2.2U 10V
                             PC5316 > 22U 16V
                             PU5302 > SI7686DP
                             PU5303 > SIR460DP
                             PC5302 ,PC5303 > 10U 25V
                             PL5301
                             PTC5301 ,PTC5302 >330U 2V
                             PR5313 ,PR5314 ,PR5317 > 0 OHM
                             PR5319 > 1.69K
                             PR5334 ,PR5335 > 100 OHMS
                            And also
                            1. R2001 > 2.37K
                            2. R1305 > 4.37K
                            3. R2603 > 0 OHM
                            4. L2602
                            5. RN2001 > 0 OHM
                            6. RN2004 > 0 OHM
                            7. RN2002 > 2.2K
                            8. RN2005 > 1500 OHMS
                            9. RN2006 >2.2K
                            10. R5407 > 0 OHM
                            11. R2309 > 10K
                            12. RN7702 > 0 OHM
                            13. R2601 > 0 OHM
                            14. RN5501 ,RN5502 , RN5505 , RN5507 , RN5509 > 0OHM
                            15. R2611 > 0 OHM
                            16. R2201 > 0 OHM
                            17. R2205 > 0 OHM
                            18. X2301 > 25 MHZ
                            19. R2303 > 1M
                            20. C2307 ,C2308 > 12P 50V
                            21. R3903 > 0 OHM
                            22. R3904 > 0OHM
                            23. Q3902 > PMBS3904
                            24. RN7704 > 33 OHMS
                            25. R3714 > 10K
                            26. RN7702 > 0OHM
                            27. RN2201 , RN2202 , RN2203 , RN2204 > 0 OHM
                            28. Q7701 > 2N7002EDW
                            29. RN7707 > 2.2K
                            sigpic
                            • laptopsrinivas
                              • Nov 2015
                              • 11
                              • india
                              #34
                              I finished the job. Unfortunately the laptop is giving white display. I can see that functioning of the laptop is ok.
                              I think i made some mistake. can any body help me.
                              • ravi441
                                • May 2014
                                • 4
                                • india
                                #35
                                i fallow n5010 milind schematic,i can converted graphic to nongraphic.display is ok but not booting with hard drive and pendrive.please help me.advance thanks
                                • vignesharivuslm
                                  • Nov 2014
                                  • 31
                                  • India
                                  #36
                                  I did the conversion to 4 motherboards but it gives white display to me, and programmed a working file to the 256 kb bios and 4 mb bios... and i want to say i removed graphics chip same output and after removed graphics chip and vram's all and get same output, why not comes display please help me.
                                  • crowntoy99
                                    • Oct 2012
                                    • 264
                                    • india
                                    #37
                                    hole
                                    gys any one success complete thes dell n5010 can be converted from graphic version to non graphic
                                    • ibrahim03
                                      • Oct 2015
                                      • 143
                                      • egypt
                                      #38
                                      is there anything new ?
                                      • nasnus123
                                        • Jan 2016
                                        • 28
                                        • india
                                        #39
                                        Hello dears,
                                        I tried those steps and its grate work I got display and able to enter bios settings, but Hdd not booting after showing in bios, please give me replay for this problem
                                        Thanku
                                        • harshad1975
                                          • Jan 2015
                                          • 7
                                          • India
                                          #40
                                          lag:
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • minaedward
                                            Dell N5010 keyboard
                                            by minaedward
                                            Hi all
                                            I have a dell n5010 that shows black screen after the dell logo and freezes
                                            But when I remove the keyboard it works fine and boot the windows
                                            The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
                                            But after the dell logo it causes the laptop to freeze
                                            Any ideas why ?
                                            09-29-2024, 05:24 PM
                                          • sahamipoor
                                            how to Set graphic Discrete mode motherboard(no UMA) Dell XPS L502x - DAGM6CMB8D0
                                            by sahamipoor
                                            hello...
                                            the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
                                            i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
                                            according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
                                            1- EXT_LCD_PWM no voltage to enable pwm
                                            2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
                                            and screen is turn off and fan is high Speed!!
                                            Question:
                                            I need to Use Discrete graphic nvidia EXT_LCD ports...
                                            03-12-2024, 02:51 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
