playstation 5 digital firmware dump
  • Jenbe weFIXit
    • Jul 2025
    • nigriea
    #221
    Originally posted by Fenerlee11
    i need edm 020 cfi-1116A bios for no power 3 beeps
    TRY this is for CFI-1116A I DOWNLOAD it here hope it it works for you for me am still looking for the one for CFI-1115A EDM-020
    • teokarafou
      • Feb 2018
      • 23
      • Greece
      #222
      HELLO I HAVE A EDM-010 CFI-1016A WITH DAMAGED BIOS CHIP,CAN SOMEONE SHARE A WORKING BIOS?
      AND ALSO I NEED TO MODIFY ON NOR TOOL?
      I AM ASKING BECAUSE I CAN MAKE A DUMP FROM THE DEAD CHIP THAT HAS THE DATA
      • bharataus
        • Mar 2024
        • 7
        Originally posted by dimon-dlx
        Re: playstation 5 digital firmware dump
        Writing someone else's dump to PS5 is possible. I checked personally. You need to choose the right revision. CFI-10XX & CFI-11XX are not compatible! You need to write down W25Q16JV, she is responsible for turning on the power of the console. From the unique data there is a model, and a serial number. They can be corrected by hand in the HEX editor. I have written a dump from CFI-1102A to my CFI-1116B. Now PS5 wants a drive that doesn't exist Who can help with a dump from the Digital Edition of the second revision? I need CFI-1116B
        Hi Can you please share the dump of CFI-1102A - Thanks.
        • Argueta05
          • Jul 2025
          • Sonaguera
          #224
          Alguien Me Puede Ayudar Con El Bios De PS5 CFI-1015A. Modulo:C-25463
            SMDFlea commented
            Editing a comment
            post in English !!!
        • sebah jud
          • Ethiopia
          #225
          Originally posted by waleedoo
          Model : PS5
          Board Name : EDM-020
          Issue : 3 BEEPS
          ProdID : CFI - 1116A
          I need this file
          • Diesalweasel
            • May 2016
            • 49
            • United Kingdom
            #226
            hi i have a dump for edm 033 how do i add the dump to here please it has 3 beeps best regards
            • simkard
              • Jan 2022
              • 15
              • France
              #227
              Hello Everyone,
              I'm stuck with a CFI-2016A which has a license problem and doesn't register its disc drive (but it works 100% on another console).
              PSN logs in 100%, I can download content but as soon as I try to run/play I get "Can't use this content" / "Can't connect to the server to verify your license. Wait a while, and then try again."
              Of course, trying to restore license from the PS5 menu fails with error [CE] - [105628] - [2].
              Trying to reinstall system from SAFE MODE (forced) with option "Reset PS5 (Reinstall System Software) ends up at 29% systematically with error [CE] - [120239] - [7]
              I found a way to get it reinstalled with >>> SAFE MODE (forced) >>> [3.Repair Console Storage] or [4.Update System Software] >>> Reboot >>> asks for USB stick with necessary file >>> all goes well until arriving in PS5 menu where the console acts stable and well.
              Only game that starts is Astro's Playground but ends up crashing every single time at the same location in game with error [CE] - [108255] [1].
              I suspect NOR to be in cause as I don't know this console's past.
              My suspicions might be correct as after dumping the NOR, here are some observations :
              • Latest version installed : 25.05-11.60.00.05
              • PKG reported in NOR : PKG-3486
              • MAC addresses fields are full of [FF]
              • Model not present at 0x001C7230 (16 Bytes) : only a bunch of [FF]
              • Plastic case S/N not present at 0x001C7210 (17 Bytes) : only a bunch of [FF]
              • Strange string present at 0x001C7330 over 16 bytes : PS5GNPXXXXXXXXXX (where XXXXXXXXXX are numbers beginning with 3 zeroes // example : 0001234567)
              Does somebody has a CFI-2016(A) NOR dump with southbridge CXD90069GG, WiFi module J20H104 and same version (25.05-11.60.00.05) and PKG-3486 ?
              Thanks !
              • ll_r1d0_ll
                • Jan 2020
                • 12
                • Pakistan
                #228
                Hello everyone. I have a PS5 with 3 beeps issue. Since I am new with PS5 Bios Mod, could someone do it for me ? I have uploaded the original backup on my google drive The model on mobo is the following
                Motherboard model : EDM-033
                Model on the case : CFI-1200A
                Drive Link : https://drive.google.com/drive/folde...yo?usp=sharing
                Thanks in advance.
                • Cobbes
                  • Mar 2024
                  • 26
                  I cleared the UART error logs.
                  • ll_r1d0_ll
                    • Jan 2020
                    • 12
                    • Pakistan
                    #230
                    Hi. Thanks alot for this. Can you please confirm If anything else is required or shall I just flash it back to my PS5?
                    • ll_r1d0_ll
                      • Jan 2020
                      • 12
                      • Pakistan
                      #231
                      Anyone ?????
                      • Cobbes
                        • Mar 2024
                        • 26
                        If it is the original NOR dump you send, than you can write it direct back and test. If not, you can write it back for testing. If it works I would change the console infos Mobo S/N, S/N, Wifi MAC,...
                        • ian23
                          • Aug 2025
                          • 3
                          • cuba
                          #233
                          hello i have ps5 slim edm-041 with 3 beeps in fw 11.60 i need donor dump
                          • baticzek
                            • Mar 2024
                            • 5
                            • Poland
                            #234
                            I need bios EDM 033 Disc 61gg Wifi AW XM546 Cobbes
                            • jucadt
                              • Jun 2025
                              • 3
                              • Serbia
                              #235
                              Originally posted by SoJustMe
                              hi guys , need EDM-032 dump for 61GG please
                              i uploaded my currupted firmware
                              here u go, my disc failed so i turned it into digital. bin file may be for digital, u can reverse it back to dics. https://repair.wiki/w/PlayStation_5_...tal_Conversion
                              • idog
                                I fumble
                                • Aug 2022
                                • 14
                                • Netherlands
                                #236
                                I'm at a loss here. I have a PS5, EDM-020, CFI-1116A, disc version. It has the infamous 3 beeps when I connect a powercord to it and does absolutely nothing after that.
                                I took off the bios ic, read it, dumped it and checked it with the C0der amazing tool (which btw tells you your file is invalid if it ends with .BIN instead of .bin. Took me some head scratches why it didn't recognize my dump at first).
                                Looked fine, no signs of corruption tbh.
                                Anyway, I used the dump someone else here posted (granted, he did say it was "untested") and overwrote the values with the ones from my PS5 using the C0der;s tool and then I used hxd to also correct the mac addresses (which for some reason the tool leaves as read-only). Then loaded it back in the tool to check, all good. Next I erased the IC, wrote the new dump, verified, all good.
                                But it still does the three beeps.
                                Can someone please take a look at my bios dumps and see if anything is off or has anyone got access to a known good bin ?
                                3beeps.bin is the original one I dumped. shouldbecorrect.bin is the one that I wrote back to the IC but despite its name it's still not working
                                Thanks !
                                p.s. I did take the bios ic off again and dumped it again. It was 100% identical to what I had written to it. So the IC itself should be okay, I guess.
                                • idog
                                  I fumble
                                  • Aug 2022
                                  • 14
                                  • Netherlands
                                  #237
                                  Thanks !
                                  Or if someone (@cobbes maybe ? ) can tell me how to clear the error logs from the original bin ? I have ordered a UART adapter, but if I understand correctly, the errorlogs "live" in the nor anyway, so it's just a matter of FFFFFFFF-ing the relevant address range, I guess ?
                                  edit : Tried to do it myself by copying the 001c5000-001c58f0 range from the cleared file that Cobbes posted a few posts up into my original dump. Still the same three beeps. I don't know what to try next :/ I've attached my original with the cleared block.
                                  • idog
                                    I fumble
                                    • Aug 2022
                                    • 14
                                    • Netherlands
                                    #238
                                    I just keep talking to myself, but let's just keep updating.
                                    So, I ordered and received a UART adapter. Installed that today and using PS5 Wee tools I was able to connect. Cleared the errorlog and tried again, still 3 beeps.
                                    Took off the NOR ic again, and wrote back the original dump to it again, so I was back at square one. Placed it back and used UART again to read the errorlogs, and there were some errors, so I cleared those again. At this point I have the exact dump that belongs to this PS5, minus the errorlogs.
                                    And still.. 3 beeps.
                                    I think I have to start thinking about giving up. I do have some brand new ICs coming in, so I will give that a shot, but seeing as the UART reading and clearing the logs went well, I don't really think the IC is faulty.
                                    • jibril mohammed
                                      way big
                                      • May 2025
                                      • 8
                                      • Nigeria
                                      #239
                                      hey were you able to fix it? it could be that the bios ic itself is faulty and need replacement, the dumb file might be okay. just that the ic itself might be fried
                                      • idog
                                        I fumble
                                        • Aug 2022
                                        • 14
                                        • Netherlands
                                        #240
                                        Unfortunately not. I've ordered new ic's and even with those still the same three beeps. I have given up.
