playstation 5 digital firmware dump
    • 31246
    Re: playstation 5 digital firmware dump
    upload the original and the one you need to modify - i'll see if i can use a hex editor on it
    • Aimaxe
      Aimaxe commented
      Editing a comment
      help with a good dump for CFI-1016A ?
  • Comp_Pro
    • Jun 2020
    • 33
    Here is a firmware dump for CFI-1015A. Note that it must end A. Copied from known working and it helped me fix a PS5 that had 3 beeps as soon as you plugged in the AC cable. I believe the board was originally also going to 30mA and then shutting back down.
    Upon boot it is now asking me to reset the software, will update to see if software reset/update will work.
    • J3isono
      J3isono commented
      Editing a comment
      THANKS MAN!!! i flash my ic and my ps5 turn on!!! thanks
    • 31246
    thanks for sharing
    • Comp_Pro
      • Jun 2020
      • 33
      Can confirm cloning the firmware worked on an identical CFI-1015A. I did not do any serial number changes or anything, just a straight clone. Upon first boot I did have to reset/restore the system however.
      • ntsimon
        • Oct 2023
        • India
        #45
        Thanks so much, that was the exact file I was looking for!
        • Comp_Pro
          • Jun 2020
          • 33
          NP! Glad I could help.
          • krichtot
            • Oct 2021
            • 20
            • belgium
            #47
            Originally posted by jacobtc
            does anyone have a clean 1016b bios? I've attached the one from my ps5 digital.
            if you still searching
            i patched your orig bios and theres another one
            try this
            • xspectrum21
              xspectrum21 commented
              Editing a comment
              This one worked for the 1015B THANKS!!!!
          • FiXiNGA
            • Nov 2023
            Hi I also facing problems with a EDM-020 and CFI-1116A Board.
            Used this but it is not working.
            Does anyone have a good known bios for 1116A Boards?
            Thanks in advance!
            • FiXiNGA
              • Nov 2023
              Originally posted by stj
              tell me if it works
              For me not. Does anyone have a good one?
              • Drising
                • Oct 2023
                • medrano
                #50
                Hello everyone !!
                I need a firmware dump for the CFI-1115A
                Can you help me out?
                Thanks in advance
                • Aimaxe
                  • May 2015
                  • Italy
                  #51
                  anyone help with a good dump for CFI-1016A ?
                  • Chikaubah
                    • Jan 2023
                    • Nigeria
                    #52
                    Can someone help me with
                    CFI-1216a bios file
                    and secondly i have ch341a when I connect chip to the flasher it doesn’t detect could it be because I downgraded my flasher from 5v to 3v or is there a specific volt to use or method someone please help here
                    • Chikaubah
                      • Jan 2023
                      • Nigeria
                      #53
                      Thanks in advance!
                      can u show me the tools you are using please mine not detecting on ch341a proggrammer
                        • 31246
                        be carefull that it's not a 1.8v flashchip
                        • gadgetbloke
                          • Oct 2019
                          Does anyone have the BIOS file for a PS5 CFI-1116A? I can't find it anywhere! Any help would be greatly appreciated.
                            • 31246
                            i got a 1116B - you could use it to see if the console starts - but your optical drive wont work with it.
                            • crasher381
                              crasher381 commented
                              Editing a comment
                              Could you share that one? I want to try it with me 1115A, it's a EDM-020 board. There's a utility called PS5 NOR Modifier to change the serial number and to change to and from disc version
                            • gadgetbloke
                              gadgetbloke commented
                              Editing a comment
                              Thanks for the offer, but it's the 1116A I need. I bought a pre-programmed BIOS IC from consolefix, and after 3 weeks the repaired PS5 has lost it's HDMI output. I just wanted to confirm this was nothing to do with the repair I'd done. You know what customers are like! The HDMI socket itself is perfect, so I am now going to try replacing the MN864739 IC. It just seems a coincidence that it should fail so soon after replacing the Bios IC!
                              Regards
                              Pete.
                          • englez
                            • Jul 2012
                            • 30
                            • Serbia
                            #57
                            I also could not find CFI-1116A dump.I had PS5 CFI-1116A disk version with 3 beeps when pluged in.I took stj's dump CFI-1116B (thanks stj), loaded and console started.Then with PS3 NOR Modifier (thanks crasher381​) changed CFI-1116B in settings to CFI-1116A with my serial and to disk version and wrote new dump.Console started an can play games from disk
                              • 31246
                              here:
                              • gadgetbloke
                                Editing a comment
                                Thanks so much for this. Really appreciated!
                            • xspectrum21
                              • Dec 2023
                              Anyone have anything for CFI-1015B ?
                              • ChocoboGS
                                • Aug 2023
                                • 7
                                • Indonesia
                                #60
                                Anyone have CFI-1218B ?
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • Tamo Neko
                                  Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                  by Tamo Neko
                                  I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                  What Happened:
                                  I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                  • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                  • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                  What I Need:
                                  • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                  02-12-2025, 11:29 PM
                                • jorpec
                                  Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                                  by jorpec
                                  Hi, all
                                  I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                                  10-17-2025, 03:51 AM
                                • Mephysis
                                  DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                  by Mephysis
                                  Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                  I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                  03-27-2025, 02:34 AM
                                • gun4as
                                  Need firmware dump for LG 23MP48HQ-P
                                  by gun4as
                                  Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                  08-25-2025, 04:28 AM
