playstation 5 digital firmware dump
  • carlosandres28
    • Jan 2023
    Will someone have the BIOS Files available for the PS5 CFI-1015B EDM-010 since it has been impossible for me to find them anywhere
    • gettindrunk
      • Mar 2024
      • usa
      #82
      ps5 front usb not working
      • Cobbes
        • Mar 2024
        • 27
        You can try this one:
        • janpatirkckaram1992
          • Sep 2020
          • 9
          • Philippines
          #84
          im currently locking for a good bios dump CFI-1018A board code edm-010 100889011. Tia
          • consolmania
            • May 2024
            • italy
            #85
            Originally posted by englez
            Try,untested...
            Ss61 or 69?
            • wsewsad
              • Dec 2014
              • Austria
              #86
              please can somebody share dump for CFI-1216B Board EDM-033​ digital edition.
              • Dark Raven
                • May 2024
                • 5
                #87
                (New Member), Greetings Everyone, looking for some PS5 wisdom, I have a CFi-1116A (EDM-020) that someone (not me) has got it stuck in IDU mode and it's updated to firmware 9.20, would flashing the bios with a clean working dump get it out of IDU mode? any help would be very welcome.
                • Cobbes
                  • Mar 2024
                  • 27
                  You can turn off the IDU mode by reading the NOR data by a programmer, edit adress 0x001C9604 = 00 (IDU off) / 01 (IDU on) and write the NOR data back to the ic.
                  • Dark Raven
                    • May 2024
                    • 5
                    #89
                    Thank you Cobbes, it worked perfect and I've now been able to restore the PS5 to factory settings, I really appreciate your help & wisdom.
                    • rui4892
                      • Mar 2017
                      • 57
                      • Portugal
                      #90
                      Originally posted by stj
                      here:
                      dump cji-1116a successfully tested
                      • Dark Raven
                        • May 2024
                        • 5
                        #91
                        Need further help, I've got a PS5 disc edition EDM-020 that had the NOR IC missing when I got it, I got it back up and running by using a bios/NOR IC & matched disc drive from a scrap console, however although the disc drive works fine and I can install & run games from it, if I download a game from PSN when I try to run it a error comes up saying "can't connect to server to verify license", I'm guessing that because the NOR is not matched to the APU/serial number, if this is correct then how do I change the serial number on the NOR
                        • rui4892
                          • Mar 2017
                          • 57
                          • Portugal
                          #92
                          You can use PS5 Nor Modifier...search on Google, its free...
                          • Dark Raven
                            • May 2024
                            • 5
                            #93
                            Thank you rui4892, I have downloaded the Nor modifier so will give it a try, I'm not sure if changing the serial number will work or not seeing as the NOR & matched disc drive were from another console, only one way to find out, I will let you know how it goes, many thanks for the info.
                            • mohammad Khader
                              • Jun 2024
                              • kj,jhj
                              #94
                              cfi-2016 3 beeps NO POWER
                              • Dark Raven
                                • May 2024
                                • 5
                                #95
                                Still having problems with a PS5 "can't connect to server to verify licenses", tried restoring licences via system menu but it throws up an error code two thirds through (error code CE-105628-2​) anyone have any ideas to a solution? tried resetting console, reinstalling systems software via USB etc, the console will install and play games via disk with no problems, it's only games downloaded from PSN that throws up the error & won't start the games, the console updates fine.
                                • Jay S
                                  • Jun 2024
                                  Anyone have bios file for 1215a disk version? Have 3 beeps no power...
                                  • Ale><
                                    • Jun 2019
                                    • Poland
                                    #97
                                    for 1215a disk
                                    • Jay S
                                      • Jun 2024
                                      Originally posted by Ale><
                                      for 1215a disk
                                      Thank you! hopefully this works for me.
                                      • Salaf
                                        • Nov 2022
                                        Hello Guys,
                                        Hope you had a wonderful day.
                                        I am in need for a nor dump for CFI-2015, Digital version. EDM-040. existing nor is damaged.
                                        Any help would be appreciated.
                                        Thank you.
                                        • Salaf
                                          • Nov 2022
                                          Need help with, edm-040, cfi-2015.
                                          Getting:
                                          80801F12 Known Unknown 80801F12 (Kernel) - Report Findings - 1 sec blue light
                                          any leads would be appreciated with the fix.
                                          Ps5 draws: .2 - .3 and lowers to .07 Amps.
                                          During this stage,
                                          1. cxd90069gg ( southbridge ) heats up to 35c
                                          2. RT5126 heats up to 30c
                                          3. Da9081 heats up to 30c
                                          No shorts found on the main board.
                                          Any idea or leads ?
                                          • weisian
                                            VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                            by weisian
                                            I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                            1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                            2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                            03-12-2026, 05:54 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • FluxCapacitorish
                                            Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
                                            by FluxCapacitorish
                                            I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
                                            Symptoms:
                                            • Without USB: power LED flashes, TV immediately shuts off (bootloop)
                                            • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
                                            What I’ve confirmed:
                                            • Main chipset: VM6901
                                            • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
                                            • No SPI flash present on board
                                            • USB recovery bootloader is working and detects
                                            04-06-2026, 03:04 AM
                                          • Daniel_berl
                                            Requesting EC Firmware Dump (1MB - W25Q80DV) for Dell XPS 15 9570 / Precision 5530 - LA-G341P Rev 1.0
                                            by Daniel_berl
                                            I am working on a dead Dell LA-G341P Rev 1.0 (A00) board. Service tag 3MCP1X2
                                            I already have the 32MB Main BIOS dump, but I urgently need the standalone 1MB (8Mbit) EC / KBC Firmware dump for the Winbond W25Q80DV chip (UT2 / EC Flash).
                                            ​The laptop is showing 0 signs of life (no LEDs, no power response) despite normal 3.3V/5V standby rails present, so I need to reflash the 1MB EC SPI flash.
                                            ​If anyone has a working dump from a W25Q80 chip off an LA-G341P board, please share!
                                            ​Thanks in advance!
                                            07-31-2026, 07:23 AM
                                          • theaaronone
                                            Samsung Odyssey Neo G9 (LS57CG952NNXZA) BN41-03169A @ Winbond W25Q128.V -- Need Firmware Dump from working unit
                                            by theaaronone
                                            I have had this beast in pieces for days going through everything bit by bit - I finally got a chip to read off the main board and it has a high blank / ff count, so I'm wondering if anyone out there has this monitor in working condition that could provide a working firmware?
                                            • Board number: BN41-03169A
                                            • Monitor: Samsung Neo G9 57" LS57CG952NNXZA
                                            • Symptom: No power, FPGA DONE/ALIVE at 0V
                                            • Flash chip: Winbond W25Q128.V
                                            • I've got a dump showing 74% erased/0xFF
                                            • Requesting a good firmware dump from anyone with a working unit
                                            Thank you!!...
                                            04-23-2026, 08:37 PM
