i have a CFI-1015A PS5 Disk Version - Board EDM-010 . this is my ic dump . i need a compatible digital version dump.
playstation 5 digital firmware dump
My ps5 worked but no picture no displayRe: playstation 5 digital firmware dump
Here is a firmware dump for CFI-1015A. Note that it must end A. Copied from known working and it helped me fix a PS5 that had 3 beeps as soon as you plugged in the AC cable. I believe the board was originally also going to 30mA and then shutting back down.
Upon boot it is now asking me to reset the software, will update to see if software reset/update will work.Comment
My ps5 is having 3beeps of death immediately I plugged it, I've tried writing several dumps found here, but doesn't work, even tried changing it using nor modifier but doesn't work.
Please, I need firmware dump for cfi-1216aComment
Try,untested...
Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks so much for the file, I really appreciate the effort but the file didn't seem to work, when I wrote it to the BIOS, when I plug the console, it won't even respond, no 3 beeps, eject/power button not responding, it's like a dead console and when I rewrite the old BIOS back, I get the 3beeps immediately when plugged and nothing else
the console motherboard is edm-031 cfi-1216A
Or am I missing any required procedure?
Here's my own BIOS having the 3beepsAttached Filesif you find these attachements useful please consider making a small donation to the site
Here is a working dump from a edm-031 cfi-1216a with 69gg southbridge. Change at 0x001C7200 the console unique data (MainboardS/N and SerialNo)
Here is a working dump from an edm-031 cfi-1215b with 61gg southbridge. I'm not sure if it works without any issues on an edm-030.
Yeah, safe mode loads with the file you gave but then it shuts off, obviously it's not the correct one so i'm thinking that's an issue, great thing about this it's showing signs of life! Where before it wasn't showing anything.Comment
The southbridge starts working as soon as 12V are present. If an issue appears in the prestart phase, like corrupted nor data, the system normally wouldn't boot. If the ps5 is showing something on the screen, I would consider the southbridge and nor data as functional.Comment
by AhariHi all,
I...-
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by gun4asHello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
08-25-2025, 04:28 AM -
- Loading...
