playstation 5 digital firmware dump
    • 31707
    Re: playstation 5 digital firmware dump
    no encryption, just look at address 001c:7200 for the version info
    • Mario875
      • Jun 2023
      • 15
      • Far Away
      Thanks! I can see the info at 001C7230, but on 001C7200 & 001C7210 there appears to be some kind of string, is that the disc drive key?
      Or if not, can you confirm the location of the disc drive key?
      EDIT: Looks like the .bins I have are as follows:
      1. CFI-1015A
      2. CFI-1016A
      3. CFI-1016A (2nd one)
      4. CFI-1016A (3rd one)
      5. CFI-1016A (4th one!!)
      6. CFI-1016B
      7. CFI-1116B
      So that's 5x disc edition ones and 2x digital edition ones.
      Just need to figure out where the keys are stored now.
      • crasher381
        crasher381 commented
        Editing a comment
        Could you share the 1116B file, I want to see if it will work with the 1115A I have. Thank you
      • 31707
      001c:7270-7281 may be drivekey.
      i deduced that from the fact that every disc dump is different, but every digital dump is just "FF"
      • pahblo
        • Jun 2023
        does anyone have a cfi-1015b bios bin file or know where i can find one
          • 31707
          try using 1015A and filling in the drivekey bytes with FF
          • omegen
            • Apr 2023
            • israel
            #26
            Hello
            have 2 ps5 with different problems:
            first - pressing power, there is one beep, no image and no cooler;
            if press each second, have beep each 7-9 seconds. Checked ssd voltages -.9, 1.2,2.1 one each ssd chip after beep for few seconds, then 0.
            Cpu V not initiating, no shorts.
            Second - turns on, gets red screen and shuts off randomly - can be 1 minute or 15 minutes, on game or just paused. Did software restore latest - same.
            tnx
            • Tiago199988
              • Jan 2020
              • Portugal
              #27
              Originally posted by Mario875
              So, I have some BIOS files, but how can you confirm which console they are from? I assume these are encrypted and need to be reversed some kind of XOR value and possibly byte swapping, but I have no idea where in the hex to start looking.
              Anyone got any info on this?
              you can use this tool https://www.consolefix.shop/blogs/la...0-0-0-released just load the file and it will tell you
              • ZOrd_Z
                • Jul 2013
                • 82
                • Portugal
                #28
                Hi.
                Does anyone have a dump for CFI-1016A. I used CFI-1015 provided here, it got better, now makes 3 beeps... Used ps5NORmodifier.
                Thanks....
                  • 31707
                  • ChocoboGS
                    • Aug 2023
                    • 7
                    • Indonesia
                    #30
                    Does anyone have nor dump ps4 cfi-1100? My ps5 pulsing blue light, all voltage normal, no short component. Thanks ^_^
                    • ChocoboGS
                      • Aug 2023
                      • 7
                      • Indonesia
                      #31
                      sorry ps5 CFI-1100
                        • 31707
                        thats a japanese 110. you could try a european 110 (1106) but i dont have any 110 dumps
                        • ChocoboGS
                          • Aug 2023
                          • 7
                          • Indonesia
                          #33
                          same, I don't have a back up nor CFI 11xxx
                          • lilkobe
                            • Nov 2015
                            • new york
                            #34
                            Hi Mario,
                            I need a firmware dump for the cfi-1116B.
                            Can you help me out?
                            Thanks in advance
                            lil-kobe
                              • 31707
                              tell me if it works
                              • pRoZz1ni
                                • Sep 2023
                                • Portugal
                                #36
                                Hi! I have the CFI-1016a version and the light failed when I was playing. Now the console won't turn on. From what I saw the problem is with the firmware. I've already flashed the various versions that were posted here on the forum and the best I got were the 3 beeps when the power cable was connected. Any other dumps you can post?
                                *I changed the serial number with PS5 NOR Modifier 1.0.
                                • ZOrd_Z
                                  • Jul 2013
                                  • 82
                                  • Portugal
                                  #37
                                  Corrupted CFI-1016A, PS5 does nothing. If some one can restore this one, thank's....
                                  • jacobtc
                                    • Apr 2016
                                    • 289
                                    • Denmark
                                    #38
                                    Does anyone have a clean 1016B bios? I've attached the one from my PS5 Digital.
                                    • ChocoboGS
                                      • Aug 2023
                                      • 7
                                      • Indonesia
                                      #39
                                      Anyone have a bios for CFI-1100A?
                                      To check the bios detail, just use PS5 NOR Modifier from TheCod3r
                                      • Mistreics
                                        • Sep 2023
                                        • Italia
                                        #40
                                        Hi, I have a problem. I have a PS5 digital with 3 beeps that won't turn on. I read the firmware and verified that it is a CFI-1016B. Thanks to you, I also recovered a working firmware but I don't know how to overwrite the original serial number of the PS5 because NOR MODIFIER does not have the 1016B in its "board version". Can anyone explain or help me?
                                        • weisian
                                          VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                          by weisian
                                          I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                          1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                          2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                          03-12-2026, 05:54 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • FluxCapacitorish
                                          Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
                                          by FluxCapacitorish
                                          I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
                                          Symptoms:
                                          • Without USB: power LED flashes, TV immediately shuts off (bootloop)
                                          • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
                                          What I’ve confirmed:
                                          • Main chipset: VM6901
                                          • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
                                          • No SPI flash present on board
                                          • USB recovery bootloader is working and detects
                                          04-06-2026, 03:04 AM
                                        • theaaronone
                                          Samsung Odyssey Neo G9 (LS57CG952NNXZA) BN41-03169A @ Winbond W25Q128.V -- Need Firmware Dump from working unit
                                          by theaaronone
                                          I have had this beast in pieces for days going through everything bit by bit - I finally got a chip to read off the main board and it has a high blank / ff count, so I'm wondering if anyone out there has this monitor in working condition that could provide a working firmware?
                                          • Board number: BN41-03169A
                                          • Monitor: Samsung Neo G9 57" LS57CG952NNXZA
                                          • Symptom: No power, FPGA DONE/ALIVE at 0V
                                          • Flash chip: Winbond W25Q128.V
                                          • I've got a dump showing 74% erased/0xFF
                                          • Requesting a good firmware dump from anyone with a working unit
                                          Thank you!!...
                                          04-23-2026, 08:37 PM
                                        • pcconnect
                                          Lexicon PCM96 firmware dump
                                          by pcconnect
                                          hi,
                                          long shot but with a hope... device stuck at logo and doesn't respond to any button. Tried to update firmware by System Architect via LAN but it won't talk. IP detected but no ping, no communication at all. According to the manufaturers web the firmware can only be updated by the software and the dump isn't available anywhere. I guess it can be flashed using CH341 with the right dump.
                                          Any chance someone is in possesion of this device and can read the bin/rom from the ic? I believe the ic is U44 marked ATMLH338 2GB 2 2Y0941 and is located near the CPU.
                                          Thanks and I appreciate...
                                          04-03-2026, 03:35 AM
