i have a playstaton 5 that doesn't power up because the firmware update was interrupted. does anyone have a dump for it?
playstation 5 digital firmware dump
Re: playstation 5 digital firmware dump
Writing someone else's dump to PS5 is possible. I checked personally. You need to choose the right revision. CFI-10XX & CFI-11XX are not compatible! You need to write down W25Q16JV, she is responsible for turning on the power of the console. From the unique data there is a model, and a serial number. They can be corrected by hand in the HEX editor. I have written a dump from CFI-1102A to my CFI-1116B. Now PS5 wants a drive that doesn't exist
Who can help with a dump from the Digital Edition of the second revision? I need CFI-1116B
where did you download the PS5 bios? I have a PS5 CFI-1018A EDM-010 motherboard. can you please post your PS5 bios?Writing someone else's dump to PS5 is possible. I checked personally. You need to choose the right revision. CFI-10XX & CFI-11XX are not compatible! You need to write down W25Q16JV, she is responsible for turning on the power of the console. From the unique data there is a model, and a serial number. They can be corrected by hand in the HEX editor. I have written a dump from CFI-1102A to my CFI-1116B. Now PS5 wants a drive that doesn't exist
Who can help with a dump from the Digital Edition of the second revision? I need CFI-1116BComment
hello, can you share a spi dump? im looking for a dump and i cant find any. i have a EDM-010 motherboard disc version CFI-1015, possibly with a spi rom corruption, all standby rails OK, no shorts, three fast beeps when conected, no reaction to power button, no lights no anything, only three fast beeps when you plug the power cord to the AC. When powered the motherboard with lab power supply the motherboard will consume around 25-30 miliamps for about a second an then the consumption will fall to 4-5 miliamps. Looking for a working dump to test.Comment
guys i have the same problem with ps5 bios CFI-1016A
3bod i replace the bios with out reflash it now working my ps5 but it stuck on instaling the game data i am searching for bios file if some one can help i am so thank full
sorry for my englishComment
here is a version CFI-1015 dump it s workin , i have been tried it on another ps5Attached FilesPremium supporters get full download access and other benefits.
i think he needs the non-dvd version
cod3r has it.
https://www.youtube.com/c/TheCod3r/videosComment
Tried this bios on my 1015a and I got 3 beeps as soon as the board got power, flashed my bios back and the console attempts to turn on but gets 3 beeps before booting to os.Comment
it s really working one, did u replaced the block wich contain your serial number ?Comment
So, I have some BIOS files, but how can you confirm which console they are from? I assume these are encrypted and need to be reversed some kind of XOR value and possibly byte swapping, but I have no idea where in the hex to start looking.
Anyone got any info on this?Comment
by weisianHi all,
I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...-
by AhariHi all,
I...-
I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
Symptoms:- Without USB: power LED flashes, TV immediately shuts off (bootloop)
- With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
What I’ve confirmed:- Main chipset: VM6901
- Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
- No SPI flash present on board
- USB recovery bootloader is working and detects
2 Photos -
by Daniel_berlHello everyone,
I am working on a dead Dell LA-G341P Rev 1.0 (A00) board. Service tag 3MCP1X2
I already have the 32MB Main BIOS dump, but I urgently need the standalone 1MB (8Mbit) EC / KBC Firmware dump for the Winbond W25Q80DV chip (UT2 / EC Flash).
The laptop is showing 0 signs of life (no LEDs, no power response) despite normal 3.3V/5V standby rails present, so I need to reflash the 1MB EC SPI flash.
If anyone has a working dump from a W25Q80 chip off an LA-G341P board, please share!
Thanks in advance!
Channel: BIOS Requests ONLY!
by theaarononeI have had this beast in pieces for days going through everything bit by bit - I finally got a chip to read off the main board and it has a high blank / ff count, so I'm wondering if anyone out there has this monitor in working condition that could provide a working firmware?
- Board number: BN41-03169A
- Monitor: Samsung Neo G9 57" LS57CG952NNXZA
- Symptom: No power, FPGA DONE/ALIVE at 0V
- Flash chip: Winbond W25Q128.V
- I've got a dump showing 74% erased/0xFF
- Requesting a good firmware dump from anyone with a working unit
04-23-2026, 08:37 PM - Loading...
