  • Ahari
    Ahari
    • Aug 2025
    • 10
    • South Africa
    I have:
    • My board's original backup dump (which has MY ME firmware, serial#, MACs)
    • The J06 BIOS payload (.684) file
    What I need:
    • A full 8 MB SPI dump from a working Gen8 (same board revision) that includes a valid Intel Flash Descriptor, ME firmware, and backup BIOS region.
    Once I get a working dump, my plan is:
    1. Merge my board-specific data (serial, UUID, MACs) into the donor dump.
    2. Inject the latest J06 BIOS payload into the BIOS region.
    3. Flash the merged image using a CH341A programmer.
    If you have a working dump or can share a pre-flashed 25Q064A chip, I'd really appreciate it.
    Thank you!
    — Ahari
  • danito
    • Jun 2016
    • 1259
    • Romania
    Originally posted by Ahari
    I have:
    What I need:
    Thank you!
    — Ahari
    post the original bios of the server even if it is corrupted,the motherboard model and serial number.
    • Ahari
      Ahari
      • Aug 2025
      • 10
      • South Africa
      Hi danito, thanks for replying. The system won't let me attach the file. Maybe because I'm new here? The board is stamped with HP logo and the only numbers are on a sticker:
      PN: 715062-001
      CT: PDNVDB1WG5L05B
      SP#: 724495-001
      REV B1
      Is that what you need? I hope it helps!
      Regards, Ahari
      • Ahari
        Ahari
        • Aug 2025
        • 10
        • South Africa
        I hope this works for my BIOS file that I took off the chip before I did anything:
        • Ahari
          Ahari
          • Aug 2025
          • 10
          • South Africa
          Thanks SMDFlea! Do I need to just zip everything in future? Or did you just fix it for me? 😎
            SMDFlea commented
            Editing a comment
            zip all bin files in future please
        • Ahari
          Ahari
          • Aug 2025
          • 10
          • South Africa
          Thanks. Will do
          • hoaca388
            Badcaps
            • Jan 2022
            • 12435
            Thanks. Will do
            Your serial number ?
            • Ahari
              Ahari
              • Aug 2025
              • 10
              • South Africa
              I thought the serial number was one of those on the sticker. Do you mean the serial number of the box? If so, it is: CZ134499EJ
              I hope that is what you need?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12435
                No hope
Name:	2025-08-14 12_51_29-Settings.png
Name:	2025-08-14 12_53_46-Official HP® Desktop Drivers and Software Download _ HP® Support.png
                • Ahari
                  Ahari
                  • Aug 2025
                  • 10
                  • South Africa
                  No hope
                  Okay, I think I see the problem. This is a microserver and the support page is on the HP Enterprise webite at support.hpe.com. The PID no is 712317-421 and the link: https://support.hpe.com/connect/s/se...erOfResults=25 will give you the search for this machine. The software updates are here: https://support.hpe.com/connect/s/pr...oftware&cep=on
                  I hope this helps. Thank you for your efforts.
                  • Ahari
                    Ahari
                    • Aug 2025
                    • 10
                    • South Africa
                    I have tried flashing all the BIOS available at the HP site, but have only had success in updating the iLO firmware. With the help of ChatGPT, I have tried all the methods for flashing the BIOS: USB stick, iLO firmware update, Cold boot method (holding the power button with the usb stick in specific port) with no luck. I have tried using dip switch 6. 1&6 as well as 1,5 &6 while trying to flash. I have also desoldered the chip and soldered it onto the programmer, which is where I got the BIOS bin file from. I have done the desoldering twice with different firmware. Nothing. ChatGPT says my BIOS is missing something that can only be replaced by getting hold of a full BIOS dump, which lead me here asking for help.
                    I really hope you experts can help me get this going...
                    • Ahari
                      Ahari
                      • Aug 2025
                      • 10
                      • South Africa
                      I have since taken the board off it's mounts and found this printed on the back: a11sbt2 mb 11074-1 48 5p601 011 inside a big white square. Does that help?
                      I have also confirmed the PCH chip to be a BD82C204 SLJ4H.
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
