playstation 5 digital firmware dump
  • Shibz1996
    • Jul 2024
    Please share Bios for CFI-121A. Tried one in the tread, showing invalid file error on PS5 NOR Modifier. Please help
    • ubreakifixer33
      • Jul 2024
      Hello still looking for cfi-1015b edm-010 bios firmware digital edition. Can anyone help with that?
      • Telscrt Telion
        • May 2023
        • Nigeria
        #103
        To reconfirm your PS5 BIOS file, use the PS5 Nor Modifier to obtain details like the MAC address and serial number. Then, obtain another BIOS file, whether digital or on disc, and place it in the PS5 Nor Modifier. Take note of the data serial number and use a hex editor to modify the new BIOS file. It's preferable if the new BIOS file is the same model as your own.
        In the hex editor, use your main BIOS file as the source to edit the new BIOS file.
        Insert:ThumbnailSmallMediumLargeFullsizeRemove
        Sc​
        Then, use the PS5 Nor Modifier to verify if the serial number and MAC address have changed. Finally, choose the model and edition to generate.
        • shvanmajd
          • Nov 2014
          • Iraq
          #104
          i have ps5 disk version cfi-1216a edm-031 61gg with 3 blod
          • cicetto
            • Nov 2015
            • 6
            • italy
            #105
            I've flashed a CFI-1016A, now PS5 boot but it won't to update with error su-101217-2, I've seen it has no wifi MAC Address.
            What can I do?
            • RotteNova383
              • Aug 2024
              hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciated
              • Cobbes
                • Mar 2024
                • 27
                If your PS5 ist starting to the home menue and the disc drive is able to accept and copy PS5 discs, the data itself of the NOR is ok. You wouldn't get to this point if the NOR data is not ok.
                What is exactly the problem and what is the error message from the disc drive?
                If your disc drive is accepting disc but have trouble to read it and shows the error "Can't recognize...", the laser is mostly done.
                • Mousetohome
                  • Sep 2024
                  Could someone help me out looking for a 1115B or this one to be fixed? I tried a 1116A no luck on it. Turned into a no power no beeps. I reflashed to this but still 3 beeps
                  Thank you!
                  • cicetto
                    • Nov 2015
                    • 6
                    • italy
                    #109
                    What can I do?
                    I've replaced wifi chip J20H100 but I've still no MAC Address in wifi and I can't update PS5
                    • Cobbes
                      • Mar 2024
                      • 27
                      I had a similar issue where the wifi MAC was not shown, but BT worked. After replacing the southbridge the wifi MAC was shown again.
                      • Cobbes
                        • Mar 2024
                        • 27
                        Thank you!
                        I would try the attached dump.
                        • Cobbes
                          • Mar 2024
                          • 27
                          The name of the dump ends with .BIN but must be .bin for the PS5 NOR Modifier.
                          • Darky777
                            • Sep 2024
                            • 5
                            • Mexico
                            #113
                            Hello! I am new here, but I´m looking for a good dump of a CFI-1200a disc version to get rid of a 3 BOD console. Thanks in advance
                            • Fotik
                              • Mar 2018
                              • Russia
                              #114
                              Hello, I need a dump for edm-030 cfi1200a. Thanks in advance.
                              • Alex9k
                                • Sep 2015
                                • Украина
                                #115
                                ps5 disk version cfi-1216a dump no tested
                                • waleedoo
                                  • Nov 2016
                                  • 71
                                  Model : PS5
                                  Board Name : EDM-020
                                  Issue : 3 BEEPS
                                  ProdID : CFI - 1116A​
                                  • mohammed aram
                                    • Apr 2015
                                    • 77
                                    • egypt
                                    #117
                                    worked for me edm-031 southbridge 61gg
                                    thank you
                                    • Joztu
                                      • May 2022
                                      • 46
                                      • Nigeria
                                      #118
                                      H
                                      • anthonybaystate
                                        • Dec 2023
                                        Does anyone have a PS5 Slim Digital Bios? EDM-040, CFI-2015B, thank you.
                                        • Gecko702
                                          • Oct 2024
                                          Hello, I just recently joined, I'm looking to fix my phat PS5 disc but id rather dump my BIOS and use a good working one just by hex editing, so how do I dump my .bin? I'm not sure if it has to do with the blue light of death and I get the UART code: "80830000 Shutdown or Freeze After SAM_IPL Loaded - GDDR6 Data Line Issue (Replace)" and yet cant go to safe mode and some times this code too: "C0020303 APU Not Responding - Trying Init or Reboot" not sure if my APU is dead or something with the BIOS? fuses are fine too, motherboard is EDM010 and CFI-1015A I just want to get my doubts cleared before I buy another PS5 thanks!
                                          • weisian
                                            VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                            by weisian
                                            I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                            1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                            2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                            03-12-2026, 05:54 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • FluxCapacitorish
                                            Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
                                            by FluxCapacitorish
                                            I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
                                            Symptoms:
                                            • Without USB: power LED flashes, TV immediately shuts off (bootloop)
                                            • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
                                            What I’ve confirmed:
                                            • Main chipset: VM6901
                                            • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
                                            • No SPI flash present on board
                                            • USB recovery bootloader is working and detects
                                            04-06-2026, 03:04 AM
                                          • Daniel_berl
                                            Requesting EC Firmware Dump (1MB - W25Q80DV) for Dell XPS 15 9570 / Precision 5530 - LA-G341P Rev 1.0
                                            by Daniel_berl
                                            I am working on a dead Dell LA-G341P Rev 1.0 (A00) board. Service tag 3MCP1X2
                                            I already have the 32MB Main BIOS dump, but I urgently need the standalone 1MB (8Mbit) EC / KBC Firmware dump for the Winbond W25Q80DV chip (UT2 / EC Flash).
                                            ​The laptop is showing 0 signs of life (no LEDs, no power response) despite normal 3.3V/5V standby rails present, so I need to reflash the 1MB EC SPI flash.
                                            ​If anyone has a working dump from a W25Q80 chip off an LA-G341P board, please share!
                                            ​Thanks in advance!
                                            07-31-2026, 07:23 AM
                                          • theaaronone
                                            Samsung Odyssey Neo G9 (LS57CG952NNXZA) BN41-03169A @ Winbond W25Q128.V -- Need Firmware Dump from working unit
                                            by theaaronone
                                            I have had this beast in pieces for days going through everything bit by bit - I finally got a chip to read off the main board and it has a high blank / ff count, so I'm wondering if anyone out there has this monitor in working condition that could provide a working firmware?
                                            • Board number: BN41-03169A
                                            • Monitor: Samsung Neo G9 57" LS57CG952NNXZA
                                            • Symptom: No power, FPGA DONE/ALIVE at 0V
                                            • Flash chip: Winbond W25Q128.V
                                            • I've got a dump showing 74% erased/0xFF
                                            • Requesting a good firmware dump from anyone with a working unit
                                            Thank you!!...
                                            04-23-2026, 08:37 PM
