Benq G2255 doesn't power on - amber power light when plugged in
  • rddube
    Aspiring Expert
    • Jun 2013
    • 959
    Re: Benq G2255 doesn't power on - amber power light when plugged in
    Eureka! It works. With the blue wire with 1K resistor into 3.3V and the BRT_ADJ wire with 10K resistor in 3.3V (I changed from 5V to 3.3V), with Frankie in C817 the lights come on and stay on!!!
    I am so excited that I didn't take any voltage measurements because it works!
    Ok, so do you want me to take measurements or do we go to the main board now and try and get that thing to run? Tks guys!
    • will62
      • 229
      • usa
      #222
      It only took us 12 pages. I commend you for sticking with it. We took the long way around to find out that there was no problem with the board, but hopefully you learned a lot about the inverter section. Don't need any measurements, just leave lights on for a good while to make sure they stay on.
      Now that we've finished the "easy" part, you ready to get to the main board?
      This thread got so long, you should probably start a new one for part II - main board. I guess you could put links in both.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 959
        Ooops, I checked if they were on, and they stay on (looking through the back near the wires going to the CFL), but when I looked at the screen they are flickering....could it just be resistor values on the jumpers?
        When I turn on AC they come on bright and then within a fraction of a second start to flicker, constant regular flicker?
        As far is sticking with it, you Will are the main reason why I did, you have been so patient and I have learnt so much, I have to really thank you for it. And yes, am I ready for the main board!
        But do I do any more tests to get rid of that flickering?
        • will62
          • 229
          • usa
          #224
          Flickering is not good. Like I mentioned a page or so back, what are the odds that both boards would fail for different reasons at the same time? The flickering could be related to not having the correct inputs on the jumpers. As long as the lamps are coming on, I'd leave it until you see what happens with good main board inputs. The flickering means that something is not happy, so I wouldn't leave them on for long periods, as I recommended above.
          If you're feeling adventurous, I guess you could go back and change each thing back to what it was until you hit which one was causing the lamps not to come on. Then you could zone in on that one cause and try to eliminate the flicker. (BRT_ADJ, POWER sav, capacitor)
          • rddube
            Aspiring Expert
            • Jun 2013
            • 959
            I think I will leave them for now and start a new thread for the main board. See you in a few!
            • rddube
              Aspiring Expert
              • Jun 2013
              • 959
              This thread continues here:
              https://www.badcaps.net/forum/showthread.php?t=67285
                master hoarder
                • May 2008
                • 12176
                #227
                Well, I have to say, I commend you ALL for being so patient and persistent... and it looks like it paid off in the end - you got the inverter working.
                Originally posted by rddube
                Maybe we should go to the lamp route, and use Budm's method with one of the F13TT lamps I have. I could plug it into the CN801 and see if the lamps go out?
                What do you think?
                It's definitely something you should consider trying in the future if you want to save time. Of course, you probably wouldn't have learned as much from that endeavor as much as you did from this one.
                That said, if you do plan to do more monitor repairs in the future, eBay and AliExpress also have cheap 1, 2 and 4-lamp pre-built inverters. These can be very handy if you want to test lamps. Here are a few examples:
                https://www.ebay.com/itm/1pc-5-28V-1.../173002933466?
                https://www.ebay.com/itm/2-Lamp-Back.../182959252359?
                https://www.ebay.com/itm/Universal-1.../263014692288?
                For $3-5 each, these inverters are pretty much a must-have for anyone that works on LCD monitors. Either that, or get some LED kits and retrofit the monitor with LED backlights. Of course that's easier said than done. Mostly due having to open the LCD. Speaking of which:
                Originally posted by Dumah Brazorf
                You can only open that panel, it's not hard but tedious. Changing the cfl desoldering the old and resoldering the new in the manner that fits inside the panel instead is a pain in the arse...
                +10000000000
                I did a CCFL replacement on a 22" HP, and to say that it was a pain in the butt is an understatement - it's lots of trial and error and cutting and trimming and refitting until everything can be closed back up. And on top of that, if you're not careful and don't have a very clean work area, those polarizing sheets in the LCD will pick up all sorts of dust, dirt, and linens - essentially really making the repair ugly if not careful. Luckily, I've read about other people making that mistake, so I was extremely careful and it all turned out okay. But it's definitely something I don't want to do again, if it can be avoided.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 959
                  Thanks Momaka for this info. I am certainly going to look into getting one of these.
                  A question come to mind however, how are they powered not AC ? Is it simply putting 5V - 28V DC input?
                  Funny, the third one does not ship to Canada?
                  Also, which one should I get...my former repair the cfl's had 2 connectors each, whereas the one I am working on now, there is only one connector top and bottom?
                  Tks again!
                    master hoarder
                    • May 2008
                    • 12176
                    #229
                    Yes, these inverters are powered by a DC input. Essentially they are made so that you can directly connect them to the existing power supply in the LCD monitor and completely replace the original inverter. If you look around, some of those inverters even have dimming control (so your logic board can control the backlight brightness), in addition to having an On/Off signal.
                    As to which one to get...
                    For testing, I recommend either only the 1 or 2-tube inverter - that way, you should be able to isolate which CCFL tube or assembly is having issues.
                    For full inverter replacement, the 4-tube inverter should be able to acomodate most monitors. Just keep in mind that there are different inverter designs on eBay: some might have the CCFL connectors in awkward spots that may not allow you to easily connect your CCFLs. In addition to that, the PCB sizes of different designs can vary a little - so depending on how much space you have in your monitor, you might need to get a specific size to make things fit.
                    Regarding the monitor that has only one connector on the top and bottom...
                    Are the wires going to each CCFL very thick, or is one thin and the other one thick? The former could indicate that there are two CCFLs in series for the top and the same for the bottom. I think those assemblies usually require an inverter that runs at a higher voltage. I've only seen it a few times though.
                    However, if each CCFL assembly has one thick and one thin wire (the latter case above), then you probably have a monitor with only two CCFLs total. If that's the case, then you can test that only with the 2-tube CCFL inverter.
                    No worries. There are 10s (if not 100's) of sellers for these things on eBay and Ali Express. So if you search around, you should be able to find a seller that ships to you. I just picked the first (cheapest) inverter that appeared on eBay for each type and posted it here. Mine cost me $5 when I got it a few years back. So if you look at the more expensive ones, you should be able to find one that ships to Canada.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 959
                      Ok, thanks for the guidance Momaka!
                      • huzo
                        HP 470 G5 blinking amber light no power
                        by huzo
                        The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                        So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                        I've tried flashing the bios...
                        interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                        06-08-2023, 04:08 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • lapfix
                        HP OMEN NO power no light
                        by lapfix
                        HP OMEN : DAG35DMBAD0
                        NO power ,no short ,no corrusion
                        Consumption : when charger plg in = 0.004 amp
                        Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                        when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                        No light at power button led
                        All coils resistances :
                        Pl 2001 =3v measured with kohm.
                        pl 2004 = 5v measured with kohm
                        pl 6001 = 49.7ohm
                        pl 4012 = vccsa = 24.4 ohm
                        pl 3001 =...
                        11-03-2025, 07:48 AM
                      • zwect
                        Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                        by zwect
                        I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                        Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                        Here is the original BIOS dump from the 25R256JVEN chip.
                        09-11-2024, 05:54 PM
                      • ipatch
                        troubleshooting microsoft surface pro 4 no power no led charge light
                        by ipatch
                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                        10-05-2023, 11:59 AM
